Question about Gateway 19" Flat Panel LCD Monitor
Colored-Vertical lines! My computer was mfg. in 2005, so the monitor is prob. just too old, and needs replaced completely....but would love to find a quick, easy, fix!! I have an FPD1960 TFT LCD Color Monitor (19" Flat Panel--Model 900G). When turned on screen completely full of colored/ vertical lines (which DO NOT go away)! Some are thin and some are thick, and it kinda looks like a colored UPC code! Is it a lost cause or can this problem be fixed?? Thanks, 'Becca
  • 1 more comment
  • Anonymous Nov 16, 2008
    I have the same problem> I started using this monitor in June of 2008, now in November 2008 I have the same vertical colored lines!!
  • amjed01 Feb 09, 2009
    I think I have a similar problem in my Toshiba Tecra M2 14" TFT monitor. Two black vertical lines (see the attached/inserted photo).
    It started a year ago, so I started connecting the labtop VGA output to an external monitor without any problem. But it would be nice to find a quick affordable fix. Please don't tell me a new monitor is needed, as this could cost over $150 or more!!!
  • Steven Brown May 11, 2010
    Can you post a screen shot ?
    A television repair technician needs to see the screen for themselves in order to help correctly.
4 Suggested Answers
  • 9 Answers
SOURCE: Gateway FPD1960 19" CD has a red tint to all oc screen when I turn it on.
Make sure your VGA cable is seated properly. If it is seated OK, it could be the start of a problem with a backlight. When a backlight goes bad, it typically shows up as pink/red color where white should be displayed.
Posted on Jun 09, 2008
  • 4 Answers
SOURCE: Gateway 19 in flat monitor Model 900G
I need the power cord. Please sell/give to me?
Posted on Oct 12, 2008
  • 226 Answers
SOURCE: Gateway fpd1960 tft lcd monitor has blotchy color lines across screen.
You likely have a bad 'controller' board, the one that converts the analog monitor signal into Row and Column addresses to tell the screen which pixels to light up, and which color. You may have a loose connection where ribbon cables connect to the board or the LCD panel, but you'd have to take it apart to see.
Likely the monitor part would be prohibitively expensive when you add in labor costs. If I owned it, I'd take it apart a bit and check for loose things...
tom
Posted on Jan 04, 2009
  • 561 Answers
SOURCE: Monitor will not power on - faint flickering when
Hi
i recommend the following
1) if your monitor has a 3 pin kettle type lead, please replace and see if this sorts the issue, if it is hardwired then unfortunatley your monitor is faulty and will need to be replaced/repaired
Please leave feedback/vote if this has been useful
Posted on Feb 11, 2010
Colored vertical lines on my monitor
Depending on the age of the monitor, it most likely will be Capacitors that are leaking. I have repaired many different brands of monitors and have seen problems very similar to yours. 99% of the repairs I do are capacitor Issues. It's well worth replacing them IF the screen is still in very good shape as far as brightness and contrast. most repair kits usually cost between 12 and 20 dollars.
Hope this helps!
Dec 08, 2013 | Acer Computers & Internet
Computor keeps trying to restart,monitor only shows vertical lines,first black and white then colored lines,
Probably the problem is not with the monitor. Your computer is defective and probably the lines appear because your VGA is defective.
To make sure your monitor is OK, you can connect it to another computer.
First check replacing the RAMs and then VGA.
Sep 21, 2011 | HP Vs17 17" LCD Flat Panel Monitor
Well !! my computer is 2 yrs old and there is a shade difference in the screen,a vertical line has appeared and the upper part of the screen has faded,the mouse is also not working on the upper part,it is...
Unfortunately, the screen has failed. If it is still under warranty, contact the MFG for a replacement. If it is out of warranty, you may be able to buy a replacement screen from the MFG. An alternative is to connect an external monitor. Buying a new LCD monitor will probably cost less than a replacement screen. But you will give up the mobility of the laptop.
Feb 18, 2011 | LG Computers & Internet
Vertical colored band down right side of monitor
you may haave a bad disc capacitor. they are little round , mostly tan , soldered onto the board. when the go bad you usually get a line down the screen. youw ill have to replaace them one at a time till the line is gone. you may also have a bad screen.
Nov 29, 2009 | Dell Computers & Internet
Colored vertical lines on monitor
Have you unplugged the power cord to the LCD? Let it sit for a minute, then try it. ALWAYS buy a UPS and plug any computer devices into it. Doesn't have to be big, a $50 unit will protect it from dangerous voltage surges.
Jul 24, 2009 | Dell E171FPb 17" Flat Panel LCD Monitor
Vertical white line near the left end of the screen.
Usually when there are colored lines on the LCD its because the screen is going bad. Quick way to verify this, try a different monitor on your computer and if the line goes away then you know for sure the monitor is bad.
If you try a different monitor and the line remains then you know that the video card is bad.
Jun 03, 2009 | Mitsubishi Power Adapter for DiamondPoint...
Magenta vertical stripe sets plus grid dots problem
Try using a diffrent computer on this and see if its not the video card doing it or if not its the controller board inside that connect to the video card that would need to be replaced at this time, if there are no dead or stuck pixels it might be worth replacing rather then buying a new one.
May 14, 2009 | Acer P191WBD LCD Monitor
CRT Monitor Displays only a thin bright horizontal line
Vertical IC loose connection. Best is to reflux it or resolder. It is in internal circuitry inside the monitor commonly an upside single line IC.
And its a minor repair only. But I recommend it to be serviced by a qualified technician. Inside it are plenty of nasty voltages. It might caught you.
Apr 10, 2009 | Computers & Internet
Gateway 19" Flat Panel LCD Monitor Logo
74 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
