Question about Acer Aspire 5610-4648 Notebook
Acer notebook model 4920 blue screen occurance
Its been 3 months since i got the laptop.few days earlier i had a problem with my keyboard and mouse pad.i formatted my os and it got fixed.now i am seeing blue screen for 2 seconds often.how shud i fix it?
  • Roberta Smith
    Roberta Smith May 11, 2010
    when do you see the blue screen and perhaps write down and post here what the error message is.
    Robert
  • 44 Answers
  • 46 Answers
Go to the manufacturers website and download the latest video driver for the computer.
Posted on Sep 26, 2008
Touch paid not working
All Acer suffer from that problems.If the mouse/touchpad is not working, ensure that it is turned on. Press and hold the blue "Fn" key located in the lower left hand corner of the keyboard. and tap the "F7" key one time.
fn-f7.jpgA message should flash across the bottom center of the screen stating "touchpad enabled".If this does not address the issue, the notebook may need service.
Apr 30, 2012 | Acer Aspire One D260 Netbook
I have an Acer Aspire 5742Z whose mouse keeps jumping around
You will want to try an external mouse and see if that solves the issue, if so then you have an issue with your touch pad on the keyboard.
Aug 28, 2011 | Acer Aspire 5742Z-4200 Notebook
Wont load windows...just a blue screen with the mouse icon. Alt-f10 doesnt work at the acer screen
Windows is probably getting stuck on start-up and this is likely due to a driver problem. The presence of a blue screen with the mouse pointer icon on it has a description called BSOD (Blue Screen Of Death). BSOD was common in earlier Windows versions as they were not robust enough to withstand misbehaving applications. Current Windows better isolate applications so that BSOD does not occur but it can still happen during the start up process. My suggestion is that you should try running Safe Mode then do a System Restore to an earlier date when the system used to start properly. Strongly suggest that you have the system plugged into its AC adapter before doing this. The following is based on Windows XP (you didn't indicate what O.S. you had).
1. do a power-on and press F8 repeatedly to get the Windows Advanced Options Menu
2. use the up-down arrow keys to highlight Safe Mode and press the Enter key
3. on the Windows log-in screen, click your user name icon to log-on
4. on the Desktop window, click the No button to indicate a choice to use System Restore
5. on the Taskbar, click on the iconized System Restore to open the System Restore window
6. click the Next button to get the Select a Restore Point window with the monthly calendar
7. on the calendar, click a bold date then click the Next button
8. on the Confirm Restore Point Selection window, read and if it is OK click the Next button
9. during System Restore, the system will be shut down and restarted. Let this proceed normally.
Apr 30, 2011 | Acer Aspire One PC Notebook
I am having aspire 4920 model. it is not turning on. at start up keyboard lights are on but there no screen
sounds like your screen has lost connection through the wire.
1. unplug your battery
2. unscrew the screws on the back of the laptop
3. make sure your cables are connected(dont touch unless it does look like it is not in)
Hope this helps
Mar 22, 2011 | Acer Computers & Internet
Unresponsive keyboard + mouse pad
I guess you have a mechanical problem, sounds like the mother board have some issues on starting all devices.
If you could use keyboard to go in the bios, and see the screen, if would be the OS that need to be repaired.
Aug 04, 2009 | Acer Aspire 5100 Notebook
Mouse frozen of my latop ACER TravelMate 252LC_DT
if your mouse driver installed remove mouse driver and instal new driver....http://support.acer-euro.com/drivers/downloads.html
Mar 15, 2009 | Acer TravelMate 240 Notebook
Laptop Mousepad and Keyboard stuttering, slow
This may be a battery power monitor issue. Try disabling the "Mircosoft ACPI- Compliant Control Method Battery" device. This is located in Control Panel-->System-->Hardware Tab-->Device Manager-->Batteries. Had similar problem with 2 Acer Aspire series laptops (diff models). 2 and 3 year old. Original batteries (both still hold charges for 1.5 hrs of normal usage). Running WinXP, one with SP2 and other had SP3. Both came in the last month with slow jerky TPAD function and nearly non responsive keyboard access. Checked the usual; virus, spyware, hijacking, driver conflict etc. Cloned drive and factory installed..still same problem with kb & mouse. However an external USB keyboard and mouse functioned normally (no lag). Noticed with Battery removed kb & mouse was normal. Finally found disabling ACPI control battery device resolved this issue while allowing laptop to run on either battery or AC.
Jan 30, 2009 | Acer Aspire 1640Z Notebook
Acer 3050 notebook.
sometimes corruption in windows can occur this kind of problems...but for now you can use a USB DRIVER LESS keyboard...to log in
Sep 06, 2008 | Acer Aspire 3050-1733 Notebook
Help out somebody!!
I have the same problem. Keyboard and Mouse do not work from the boot the first second of the boot sequence so I can't even enter BIOS.
Apr 11, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5610-4648 Notebook Logo
140 people viewed this question
Brian Sullivan
Brian Sullivan
