Question about Garden
3.5 briggs my 3.5 briggs runs rough when handle is push down to lift front of engine runs better for few seconds then goes rough again
  • 48 Answers
Sounds like the carb bowl is full of water - loosen the bottom bowl nut to drain till fuel runs clear - check fuel tank also water will lay on bottom
Posted on Oct 21, 2008
Briggs stratton problems
Is there a screw setting on the carb? if so turn it to the left and this allows more fuel to make it run better. Turn a little at a time and you will hear the engine rev better.
Jul 19, 2014 | Briggs & Stratton Garden
Briggs and stratton sp 460 engine will idle but not rev
I suspect the push rod for your throttle isn't pushing the throttle lever down on the carb. When you move the lever up on the handle bar then it should move the lever down on the carb. The push rod my be bent, broke or rusted in place.
Mar 16, 2014 | Briggs & Stratton Garden
Briggs and stratton runs good for 5 minutes then starts to smoke
My first thought is that the throttle lever is being pushed so far forward ( max RPM's ) that you are running the engine 1/2 or better choked
Look at the choke butterfly with the throttle in your normal run position it should be completely open
This may require and adjustment in the control rods or might be as simple as not pushing the throttle wide open
Apr 06, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I need more suction. The Head is too high on my carpet.
A slitght adjustment can be made by either screwing on short transparant internal hose on top of floor head tighter or undoing it turn.
Do this on A table as you need to get down to be able to view sole pate movement
Each time you adjust hose stand vac up on the table & pull handle back as if cleaning carpet you must not push head of vac down on the table.
Now look at sole plate usually when they are wrong the sole plate bottom back end tilts up lifting brush from carpet.
Now tap front of head down if sole plate springs back up lifting brush up again adjust hose a bit more.
What you are trying to do is get sole plate as horizontal as you can.
If you really cant get it to pick up dirt any better try fitting new hose they are more sprigier from new,
Jan 02, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Drivers side widow will not go down more than 2 inches
A) Remove the screws in the following locations:
  1. Door handle
  2. door grip
  3. Middle of panel, 3/4 down the panel from the top
B) Removal of door Handle
  1. Use caution
  2. Slide the door handle in the direction of the motor
  3. The door handle is now freed from the door
C) Partial removal of door panel
  1. Insert a dull instrument into the port that is located on the panel roughly half way down the panel and the side the furthest from engine.
  2. Carefully pry the panel loose.
  3. With your hands, remove the panel by its contour. There are roughly 10 or so plastic plug
D) Tricky Part; Removal of door Handle
  1. Free the door handle from the panel, by carefully pushing it through the panel on an angle...
  2. You can now push the panel up beyond the door lock button.... then...
  3. The wiring haness is now exposed.
E) Wiring Harness
  1. You now un plug the wiring harness from:
  • Door handle
  • Lower courteosy light
  • Electric window controls (three wires)
F) Final steps
  • Lift the panel up and over the door lock button.
Now to your window problem.
When I examined the problem that I had with my Odyssey, I found the following:
  1. Two bolts were missing;
  2. The other tow bolts were lossed;
  3. The motor had shifted positions.
Nov 15, 2008 | 1995 Honda Odyssey
Add toner
replace toner supply unit. inside of the unit are 4 mylars to push toner towards hopper exit gate. looks like them mylars are ripped off and the toner is not getting to the dev unit
Oct 20, 2008 | Ricoh Aficio 1035 Copier
How do I fold my Zooper Sport?
OK, I finally figured out how to fold & unfold this ******!
To fold: Stand behind your stroller. Go to the joint in the middle of the push handle. You have to simultaneously push up on the button underneath the joint and pull back on the little trigger at the front of the joint. I've found that this will require both hands. Doing this will unlatch the joint, and you now need to push it forward to fold the handle into a "V" shape. Now look down to the crossbars just above the rear wheels, and you'll see a handle (kind of like on a sutcase) above a sort-of triangular-shaped piece of plastic. Lifting up on either of these will collapse the frame the rest of the way. Push the rear wheels as far forward (toward the front wheels) as you can, and it will latch shut. If you swivel the front wheels around to the rear, the stroller will stand on its own
To unfold: From above and behind your folded stroller, with it standing on its front wheels (as described above), place both of your hands on the side/corner joints of the rear push bar. From the top, run both of your thumbs down the back side of both rails. Your thumbs should hit a 'bump', then a slightly smaller 'bump' immediately underneath the first. That second 'bump' on each side is the latch that keeps your stroller folded. Squeeze both the latches on each side with your thumbs, and you should hear them unlatch. Now the frame is free, and you have to push down on the suitcase handle in the middle while lifting up on the center joint of the push bar. Pull back on the push bar until it latches, and then keep pushing down on the suitcase handle until the whole thing latches.
Jan 24, 2008 | Zooper CoolZone Sport Stroller
Garden Logo
304 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
