Question about RCA TruFlat 27F520T 27" TV
Input button says there is a setting for computer but manual does not give instructions
I want to hook up my tv as a monitor for my computer occationally but not sure how to do this has anyone tried this
    Sniper:
  • 57 Answers
There are a number of methods that will allow you to make the connection. Many computers have incorporated composite (RCA) or S-Video (TV-Out) output that will either mirror or, better yet, extend your desktop beyond the monitor. For desktop systems, there are numerous AGP video cards available that offer a variety of video outputs. For example, ATI's Radeon X1950 PRO video card includes composite, s-video, and component video connections for analog signals. Of course, it all depends on what inputs your television can accept. If it has multiple input ports, remember that there is a hierarchy in terms of signal quality among the three typical types of connections, which, from lowest to highest, is composite, S-Video, then component video. So opt for the highest quality connection supported by both devices. Many older or more basic televisions may only have a coaxial cable connection. In this case, there are video cards with coax outputs and scan converters that will pass the signal through a coaxial cable directly to your television. Oh, and remember that you'll also need to connect your sound card's LINE-OUT connector to the TV for sound.
The tricky part may be finding the right cables to go from the computer to the TV, since there are several types of RCA (1 or multi-port) and S-Video (4-pin and 7-pin) connectors. One product I found, the Pro S-Video to 3 RCA cable allows you to connect your desktop or laptop computer's S-Video to your TV. These adapters are compatible with both S-video 4-pin and 7-pin receptacles and also connect your PC's stereo audio output to the TV.
But don't run out and buy any special video cards or cables yet... There are certain limitations of using older CRT televisions as computer displays that can easily render the advantages of size and affordability almost completely negligible. Perhaps the greatest constraint is the relatively low resolution of standard, tube-based televisions. Because of their design to accept NTSC (North American), PAL (European), or SECAM signals, good old-fashioned analog television sets generally cannot display resolutions greater than 640x480. That was barely adequate for a 14-inch monitor ten years ago, so just imagine how it might look on a 32-inch TV screen. Have you ever tried to read those fuzzy disclaimers at the end of a TV commercial? Viewing your computer's video signal through a CRT television will not yield the detail and clarity that you would normally expect, although for games and video playback it can produce acceptable results.
Posted on Sep 23, 2008
Where can i find the INPUT button on my soyo mt-sygwt2697nb LCD TV
Use the remote to choose the input. You can also use the menu button to find the inputs.
Sep 15, 2016 | Soyo Televison & Video
I cant connect my tv to computer
Hello
All modern TV's can be used as computer monitors - you just need the correct cables and select the correct input on the TV.
What cable are you using to connect your PC to your TV? VGA or HDMI? Your listed TV has both ports but your computer may not have a HDMI port. Either way, connect the correct cable from your PC to your TV and note how the port is labeled.
Turn the TV on and then find the "Input Select" button on the remote and press it until the above port appears on the screen.
If you use the VGA port, you will need to hook up the audio from the PC to the "PC/DVI Audio In" port so the sound will play on the TV speakers.
You can find the manual for your TV here:
http://www.sansuiproducts.com/products.html
Hope this helps!
Nov 09, 2013 | Sansui Televison & Video
How do i hook it up to my computer without a remote
"How do I hook up my computer without a remote?"
Two possibilities come to mind:
1. With a VGA (15 pin), HDMI, or DVI connected computer there should be a keyboard key combination (typically a Function button (Fn ) and one of the F1 thru F12 keys) that will activate the option for switching the video signal to the external monitor/TV, or in the case of a laptop, viewing the image on both screens. The TV's "INPUT" button, if there is one, will need to be pushed several times to cycle through the available input signals until the computer video signal input is seen.
2, Alternately, if there is no "INPUT" button, it may be possible to purchase an inexpensive universal remote (ones seen even at a local $1 Store) in able to access the TV menu. The remote will have programming instructions and codes for most major TV brands, and an Internet search, or the TV manufacturer, should provide for additional codes for your specific TV model if necessary.
Kindly post a reply if either of these options do work for you.
May 27, 2013 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Need hook up for computer
Hook up to Computer
• Identify ports that you have on your computer , look for Video Out
( read your computer manual )
• Identify Audio and Video inputs of your TV
( read your TV manual )
To hook up ,
• Computer Video Card Out
( set it to use a secondary monitor )
to TV Video In
• Computer Sound Card Spk Out to TV Analog Audio In
Aug 03, 2012 | Hitachi Televison & Video
Hi, I have buy a Frontech External TV Tuner card. On connecting to my LCD monitor (AOC) the monitor displays "Input Not Supported", but if my computer is running fine from the card (as manual...
TV tuner cards receive an input. Your monitor should still be connected to your computer using the VGA/DVI/HDMI output. The software for the TV Tuner should take the input from the external cards input and output it to your monitor like any other desktop application.
If your Monitor is giving you input not supported from your standard video output then you may have your resolution set to high,or the monitor frequency set too high (max of 60hz typically for LCD)
Sep 06, 2011 | Computers & Internet
I GOT THIS MONITOR/TV FROM DAUGHTER, I DON'T HAVE MANUAL. HOW DO I HOOK IT TO MY COMPUTER TO USE AS MONITOR. WHAT CABLES AND WHAT PORTS? THANK YOU
Tries Element website itself if ur LCD tv model still in the market u can download manual for free not look for their phone number like 1-800..call them pay them a fee they'll send out a copy of the manual to u.U have a LCD monitor now hook up to ur computer right now to used as a monitor now wright?Yes.Take that VGA cable out from ur computer and ur old LCD monitor VGA cable out of the VGA ports just take ur hand and unscrew the VGA cable.Used ur old LCD monitor VGA cable and hook up to the LCD tv VGA port and to ur computer VGA computer graphic card port or computer monitor port hook up the other end.Turn on ur Computer and tv on used the sides button of the tv find one that said INPUT push it a few times should find ur tv mode 1,2.3 ur computer is on as a monitor.
Aug 19, 2011 | Element Electronics FLX3210 32 in. LCD TV
Input not supported message appears when I hook the monitor to my dell computer.
This could be many things:
A. Your monitor is capable of receiving more than one kind of video signal - like a TV - and you need to change the input source (see manual).
B. Your computers video card is capable of outputting more than one type of video signal, and needs to be set for your monitor (Control Panels).
C. You are plugging the monitor into the wrong video port.
Apr 25, 2010 | Compaq Computers & Internet
Polaroid TLA-01511C
Tried to use my TV as a computer monitor. When tries to boot up, will go to "No Signal". All hooked up correct. Is ther something I need to do tobe able to use the monitor with my computer. I have a Dell Desk Top Computer.
Jun 16, 2008 | Polaroid TLA-01511C 15 in. LCD Television
Hooking up a ps2 to my monitor.
ok " your tv monitor has a remote, look on the remote and push the input button .
also make sure video cable for ps2 is pluged in to the tv video
input plug, female RCA plug should be yellow
Jan 21, 2008 | Polaroid 15'' HDTV Monitor FLM-1511
Samsung shr 1040 4 channel dvr
Try this it will work:
Press and hold "ch1 and mode" buttons at the same time and hold for about 45 sec. This will change yoursetting to VGA . You can fined this info in your user manual on page # 6-13 see note at bottom of page for "HIDDEN KEY" shortcut's
It's a good system dont give up.
Aug 17, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
RCA TruFlat  27F520T 27" TV Logo
158 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
