Question about Hoover Washing Machines
I HAVE FRONT LOADING 800F1 THE FRONT DOOR WON'T SHUT AND LOCK. ANY SUGESTIONS BRUCE
  • 750 Answers
Dear publican,
Welcome to fixya.com
I'm Huuum and happy to assist you,
You said, I HAVE FRONT LOADING 800F1 THE FRONT DOOR WON'T SHUT AND LOCK. ANY SUGGESTIONS BRUCE
If the washer will not turn on due to the open and unlocked door!
Then the door mechanism and door switch that that activates the washer to start have failed.
You can do it your self if you know how or call service and they will get you on your way to clean laundry!
Cheers , Bless You Huuum
Please remember to leave a rating when your finished Thank You
Posted on Sep 23, 2008
I have a small older bosch front load washer that after 3 loads ,when the door isclosed the water does not come on
I never had a front load washer but I have changed several lid switch. When the door is not closed on a top load washer a switch in the door area will shut the washer down. I did run across this on a search of front load washer..
The door lock secures the washer door shut during operation. Once the washer door is closed, the washer can begin operating. If the door lock is defective, the washer door will not latch properly. The door lock can fail either mechanically or electrically. Inspect the door lock for damage. If the door lock is damaged or does not latch properly, replace it. To determine if the door lock has failed electrically, use a multimeter to test each of the door lock switches for continuity. If one of the switches does not have continuity, replace the switch.
I saw in another post sometime the switch is under rubber
but I am just repeating what someone else said. Hope can be of some help.
Aug 12, 2017 | Bosch Washing Machines
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
Error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Mar 09, 2013 | Maytag Neptune MAH5500B Front Load Washer
Washer won't start
Sounds like the door lock may be faulty or it isn't closed fully. If it has a child lock check you haven't set it by mistake, you have to hold the start for 5 secs+ to override it.
Mar 07, 2013 | Bosch Axxis WFL 2060 Front Load Washer
Why won't my door lock?
If the door lock will not engage, then the door lock will need to be replaced. Here is the lock to order.
Nov 18, 2012 | Frigidaire ATF6000ES Front Load Washer
Affinity frigidare front load washer won't start. It beeps with message flashing (DR)
Hello zabbster - Typically the DR or DO error code indicates that the door switch is not closed. Make sure that the door lock is completely closed. If the door is closed, make sure the door latch is not broken. If the latch is broken, you may possibly need to replace the door lock switch.
Sep 25, 2012 | Frigidaire Affinity ATF7000E Front Load...
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
My kenmore front load washer doesn't want to start all lights are working but nothing happens even the door won't lock
your door switch is the problem,where the door latch goes into the machine a little switch sites behind this a safety feature and if this is broke the machine will still switch on but will not work it will need replaced they are cheap.adrianxxx
Jun 02, 2012 | Kenmore 44072 Front Load Washer
Door remains locked
Welcome to fixya
I have a solution for this
Content
By removing power completely from this unit, you will be able to reset the lock device. If it still fails, then you will need to check the door once its open for debri in the locking mechanizism.
More information is available in the comments
My name is Bruce
Jan 20, 2011 | Miele Novotronic W1918A Front Load Washer
Passenger door lock jammed
Your door latch assembly may be compromised. It could be rusted, the electric solenoid (if it has one) may be seized. Or the rods from the key are bent. Are you using th key in this door regularly? If not, the tumblers in the lock may be seized. Spray some WD-40 in the lock where the key goes, and jam the key in & out repeatedly, and retry. Remove the door panel & spray the interior of the latch, also. Hope this works for you; or, you are going to need new latches.
Aug 24, 2008 | 1997 Toyota RAV4
Washing Machines Logo
197 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
