Question about HP Pavilion 525c (DD210AR#ABA) PC Desktop
Pavilion 525C won't start
Recently I changed the hard drive of my pavilion 525c because it was damaged. After that I pushed the power button and the fans turn on, the lights od the cd rom drive and the dvd rom drive is turn on, and power button is turn yellow. Suddendly the power button shuts down but the fans still on and the cd and dvd drives still function. The screen is always blank it does not recognize any signal from the computer.
What could be he problem? Thank you for your attention.
  • masterkeysys Sep 24, 2008
    Az:
    I would configure the configuration of the bios but when I don't have any signal on my monitor from the computer. If the lights and the fans of the pc are working including the cd and dvd drive the mainboard is fine or am I wrong? Any idea would be great. Thank you for your help.
    Sergeant:
  • 300 Answers
HP Pavilion 525c/525c-b
Model Comments - 266MHz FSB, NVIDIA nForce2 IGP Chipset
After installing a new harddrive
The system may not boot and may need to be reconfigured.
You may have setup your new harddrive incorrectly.
Your system BIOS may require you to check it's settings due to the addition of new hardware.
It's recommended that you check your system bios configuration for errors after installing new hardware.
Az.
Posted on Sep 23, 2008
How do I fix the following problem: Ultra DMA
It could be caused by a fault cable.
You may also try to remove the CMOS battery, in order set the BIOS settings to default and reconfiguring it.
This may help just in case some settings is causing this problem
Mar 09, 2010 | HP Pavilion 525c (DD210AR#ABA) PC Desktop
Can i replace my 330c head unit with the 525c using the same wires antennae etc lowrance
Hope its not to late, before you replace (buy a new one) call Lowrance. I have a 525 and working through some problems and they advised me that they would replace my unit for $200 no questions asked. To answer your question not 100% positive but I did see a recent question where Lowrance lost his unit and sent him the 525 as a replacement and the connections were different. I believe my 525 has a 5 pin system with one notch. Does yours have a external gps module? The 525 does!
Mar 01, 2010 | Lowrance Lms 525c Df 5" Df Sonar...
Can you recommend the correct external hd to use for this old pc? Thanks a lot.
Anything up to a 1 TB external drive will work fine. You will only have a speed issue as it's USB 1 and not USB 2 unless you put a new USB port card in the machine.
Jun 13, 2009 | HP Pavilion 525c (DD210AR#ABA) PC Desktop
Can I add a hard drive to my old hp pavilion 525c which is still running XP and running well?
Best way to do it if you aren't familiar with the internals of a PC is to use an external drive. If you have a drive aleready you can get an external drive case and put your own hard drive into it in about 5 minutes.
Restart issue
Sounds like your computer constantly loads up some kind of ghost image that restores your PC to a previously set default installation. If you can't figure out what program you have that might cause this (and it's not normal, some kind of software has to be causing it) the only thing left to do is a full format and re-install to get rid of the offending program.
Mar 04, 2009 | HP Pavilion 525c (DD210AR#ABA) PC Desktop
Red screen
Open command prompt on a admin user and input the following
bcdedit.exe -set
loadoptions DDISABLE_INTEGRITY_CHECKS
If you get a message saying you were denied this means that you are not on a administrator account
Feb 02, 2009 | HP Pavilion 525c (DD210AR#ABA) PC Desktop
Computer powers on but does not boot - no videe output.
replace the ram if its bad you wont get any video..if that does not work it is the CPU..
Nov 17, 2008 | HP Pavilion 525c (DD210AR#ABA) PC Desktop
HP Pavilion 525c (DD210AR#ABA) PC Desktop Logo
118 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
