Question about iRiver E10 Digital Media Player
"OK to disconnect" msg remains on screen after disconnected from pc. I went thru the motions of disconnecting the E10 from the pc as per norm and now i've got this msg on screen permanently. I can't even turn it off! Please help. Lisa
    Brigadier General:
  • 5,158 Answers
Take the battery out if that isn't too hard to do on them..... and leave them out for about ten minutes or so..... replace them and turn it back on....if the battery cannot be easily removed look for a reset button on the device. you may loose data but at least the device should work again.
Robert
Posted on Sep 23, 2008
How to fix iriver E10 it says on the screen is emergency usb
  1. If your PC does recognize the iRiver as a USB device/drive, there is an issue with the Hard Drive.
  2. If your computer doesn't recognize the iRiver as a USB device/drive and can read the files, there is an issue with the Circuitry in your e10.
  3. Turn the lock off and connect it to the usb port and press the reset button (small hole in lower left of unit, use a small object like a paperclip. The screen should change eventually to the "USB connected" screen. Disconnect the USB at the PC to get the "Ok to disconnect" message. Pull out the usb cable and hold down the "off" button. Eventually the unit will turn off. Turn it on and then off to verify it is working.
If nothing works, your iRiver needs to be returned to the manufacturer.
Feb 22, 2011 | iRiver E10 Digital Media Player
Does not open the iriver E10
I have an frigidaire front load Mod.# GLTF2940ESO with an recurring E10 error message. HELP!!
E10 code indicates there is no water supply.This can be confirmed by :
  1. Shut off the faucet to stop water supply to the washer.
  2. Disconnect and pulling the supply hose off the washer to confirm the E10Code
    • Opening the faucet and watch for running water
E10 also means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Apr 11, 2010 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Affinity ATF6000Es1 washer- Keep getting an alarm and an E10 code and have to restart the washer each time the code comes up.
Oct 18, 2009 | Frigidaire Affinity ATF6000F Front Load...
Wash starts, then stops postin E10 and now soap does not dispense
Aug 02, 2009 | Frigidaire GLTF2940F Front Load Washer
Frigidaire front load washer - e10 and water hose shaking
Sep 10, 2008 | Frigidaire CWS3600AS Top Load Washer
Error code e10 and ef0
Aug 12, 2008 | Frigidaire Washing Machines
Frigidaire Affinity Front load washer, Starts to Fill, then Flashes E10, Was wondering what this code is referring to
May 19, 2008 | Frigidaire ATF6000ES Front Load Washer
E10 error code?
We had the E10 error code. I took off the water intake hose as the washer and the screen there was full of sand from our well. I cleaned the screen out and the code disappeared.
Apr 25, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Zanussi IZ161S Water filling problem
Check the drainpump. It may be clogged with lint or something, or blocked.
Jan 14, 2008 | Zanussi IZ161S Front Load Washer
iRiver E10 Digital Media Player Logo
69 people viewed this question
Top iRiver Audio Players & Recorders Experts
aliasger yq
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
