Question about Maytag Washing Machines
Maytag computer coin washer model la23cd. I have set the wash for $2.00 and the factory set is # o.75 . a few times this year i have found the set has dropped to $0.75, I reset to $ 2.00 and then it drops back to $0.75. What is the problem and how do i fix the problem. I thank you Alex
    Top Expert:
  • 21,873 Answers
Any time the machine looses power, the price will revert to the factory setting.
Posted on Jun 22, 2012
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
catriver
  • 878 Answers
SOURCE: Maytag MAT12CSDAW
Leep, open the hatch that the timer sits under. You will see the timer and actuator that the coin tray pushes to start the wash cycle. You can rotate this cam clockwise until it gets to it's home position, ususally right around the 12:00 position. Good luck
Posted on Jun 20, 2006
Washer_tech
  • 164 Answers
SOURCE: Maytag Neptune Washer, model number MAH5500B
check for a kink in the drain hose. if not remove the front of the machine, remove the the hose that connects to the bottom of the tub and the other end that connects to the pump. feel inside the tub for any obstructions and look into the pump for any obstructions.
Posted on Jul 01, 2007
  • 183 Answers
SOURCE: Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Posted on Dec 27, 2007
Krazytech
  • 725 Answers
SOURCE: How to Reset a GE top load Invensys washer timer?
remove slide cover .. move the slide lever back untill it is on #1 or the lowest setting... hope it helps
Posted on Nov 17, 2008
Won't drain or spin and makes a noise in drain pump
you probably have a coin stuck in the water pump...i had the same thing happen to me last year...5 min fix...cost me $75 service call...i know better now...easy fix ...
Aug 30, 2010 | Maytag MAH8700A Front Load Washer
We have a maytag neptune washer and on evey setting, it's telling us d5 - what does it mean?
D5 means blocked coin 1 or coin drop control circuit failure, coin recognition and price display disabled while blockage persists.
Nov 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune frontload washer code nd
Yes maam, I sympathize with the situation. The "nd" code on the Neptune is usually a pump related issue. Check the drain line for kinks first, and then the pump will have to be checked. No matter how diligent we are, inevitably hard objects like pins, coins, etc., make it into the washer. Remove the hoses from the pump and using a flashlight, look into the suction port and check for any obstructions. Also check the pump impeller for any broken/missing blades and ensure that the impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hard objects that make it to the pump can damage the impeller blades on the pump. Sorry for your trouble and I hope this helped. Best wishes.
Aug 27, 2009 | Maytag MAH8700A Front Load Washer
Maytag mah4000aww wont stop running.
It sounds like your timer needs to be replaced. The timer runs the washing machine in a pre-determined pattern. It provides the electricity to all of the washing machine components at the correct time and for the correct length of time.
Jun 07, 2009 | Maytag MAH6500 Neptune Front Loading...
Need to reset price for washer and dryer
if its not working board might be bad
May 18, 2009 | Maytag Washing Machines
Maytag commerical washer model MAT10PSAAW COIN MACHINE . THE COIN VALUE IS 1.00 IT SHOWS 2.45 THE FAULT CDE IS dA5 how to reset to working status
I have been answering other peoples problems on this site I am a electrician . I still haven't fix my freind washer yet because the Code reads dA5 If I new what this code ment I could fix rhe machine . The machine is a maytag model number MAT10PSAAW SER AO592928MF
THE MACHINE IS A COIN WASHER 1.00 COIN . IT SHOWS 2.45 if I could get it back to read 1.00 ,I think it would work . Again the code is dA5. I have been searching the net . knowone yet with a clue .
Nov 26, 2008 | Maytag Washing Machines
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
Washing Machines Logo
168 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
