Question about Amana AFB2534DE Bottom Freezer French Door Refrigerator
Brand new Amana French Door Fridge not cooling ... two in a row!!!
This is ridiculous! Got my first AFB2534DES two weeks ago. Waited 24 hours still not cooling. I have to give credit to my retailer who went thru lots of trouble to get me a new unit from another store and do a on-site exchange for me. BUT, same thing with the second unit!!! It has been over 10 hours and it is just blowing room temperature air. Fan is running continuously but just no cool air coming from either the refrigerator or the freezer. What can be wrong? What can I check? I thought Amana (same as Maytag) is a reputable brand!
    Master:
  • 604 Answers
Take it back and never leave the store without testing it
Posted on May 05, 2017
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
fridgetech
  • 473 Answers
SOURCE: refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Posted on Nov 16, 2007
Techsim
  • 59 Answers
SOURCE: Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Posted on Nov 02, 2008
Sea Breeze
  • 4654 Answers
SOURCE: refrigerator not cooling
You model if the ARB1950C has a defrost timer inside the fresh food compartment and behind the temperature control panel. Need to see if you can manualy turn the timer clockwise until the compressor stops. During that time of 25 minutes the freezer should be in defrost. I believe your timer needs replaced based on how you explained what is happening. The part number for your timer is 67001036 and can be found at the links below. If it stays longer that 25 minutes then it's sticking in the defrost section of the defrost timer and will need to be replaced. If your refrigerator does not restart after about 25 minutes then slowly turn the timer through the opening in the plastic cover. There may be a plug covering the hole to make the hole not so visible. If you should have problems fell free to let me know, Thanks Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Posted on Aug 17, 2009
Bat1956
  • 585 Answers
SOURCE: refrigerator not cooling...makes hissing noise
From your problem description I would say it sounds like maybe the condenser fan is not running. If that fan does not run, the compressor will overheat, and get very unhappy, LOUDLY. There is a fiberboard cover on the back of the unit, unplug the unit, remove the cover and inspect the fan, it should turn freely if you nudge it with your finger. If it does not turn freely, you will need to make it so by lube, removing foreign object (dead mouse once for me) dust dragons etc... or replace the fan if necessary.
Posted on Dec 16, 2009
Fridge won't cool past 57 degrees
Guessing ether a fan, damper our defrost issue. Sorry cant be much help.
Aug 19, 2012 | Samsung RF266ABRS Bottom Freezer...
I have a RFG297ACRS (Canadian Model of AARS). Bought new and delivered yesterday. Waited 2 hours before plugging it in as directed by the delivery guys. Plugged in 24+ hours ago but until now it's still...
must be on demonstation mode, manual says the following: press ENERGY SAVER BUTTON AND FREEZER/HOLD 3 SEC FOR POWER FREEZER BUTTON simultaneously for 3 seconds until an alarm sound is heard.
Jan 05, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
Slightly different model looks the same JFC2087HRS French Door. Refigerator section stops cooling and a 24 hour defrost gets it going again. Problem is I had it fixed for this about a month after I got...
after that many repairs you we can say that it has a defrost problem. the freezer will not defrost it self if off for 24 hr . but if the coil is defrosted then we know that we have a complete defrost . now I would replace the derfost terminator and if the problem came back replace the adapitive defrost control .. now with your history if either has not been replaced the replace both of them and your done . this should correct problem .. mm .. hope this helps .. ****
Oct 07, 2010 | Jenn-Air Pro-Style JFC2089H French Door...
The freezer has stopped cooling...meaning the fridge has stopped too. The fan continues to run, but blows warm air. Twice before the fan had frozen and stopped blowing the cold up to the fridge...we had...
replace the p.t.c. overload on the compressor body of the units compressor in the rear lower end of the unit,its not letting the compressor start and then not cooling
Jul 25, 2010 | Amana AFD2535DES French Door Refrigerator
Brand new Amana French Doors Refrigerator is too cold.
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Dec 11, 2008 | Amana 25" Cu Ft French Doors Bottom...
Refrigerator compartment not cooling
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
Samsung french door fridge not working?
I had the same problem ("OF" on display and not working) and just found a fix and it worked (on SAMSUNG site).It was correctly stated that fridge is in "demo" mode. You need to push and hold POWER FREEZE and ENERGY SAVER buttons (not "Fridge button and the Power Cool buttons" as it was suggested above).
Oct 14, 2007 | Samsung RM255LASH Side by Side...
Mar 06, 2007 | Amana AFD2535DES French Door Refrigerator
Amana AFB2534DE Bottom Freezer French Door Refrigerator Logo
75 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
