Question about Seagate Computers & Internet
Formating hardisk with sata connection
My pc have hardisk with s-ata connection how can I format it?
  • Roberta Smith
    Roberta Smith May 11, 2010
    does your motherboard support a sata hard drive ?
    Robert
    Genius:
  • 1,124 Answers
1) Be sure that your motherboard support SATA - See Bios
2) Using the Win XP installation CD you can format the drive. If you cannot load windows during the installation hit F6 to charge the SATA drivers.
If your sata drive is working like a second disk, you can format it directly from windows.
Start>> Control Panel >> Admistrative tools >> Computer Management
Or using any partition tools...
Posted on Sep 24, 2008
Desktop hardisk attech to my laptop
Get a usb enclosure for the hard drive, make sure you get the correct one, SATA or IDE (ATA).
Jun 12, 2013 | Computers & Internet
Tip
How to format the hard disk ? here are the ways
what is hard disk? hardisk is an internal storage device by which we can store the data and also get back the data when we needed. hardisk is like a grama phone. you can create a partition on it also. so here are some tips how to format your hard disk. 1) plug in your hardisk by a external cable and wait for while to install the drivers . and then just double click on my computer and right click on the drive letter which you want to format and then hit format. now you have a option there select ntfs and defail and you have one more option called perfome quick format . if you click on this the formating will done quickly . and then start. done. <br /> 2) right click on my computer goto manage goto disk management and there you can see the drive letter just right click on it and format it . you can also remove the partion or create partion from there. <br /> 3) insert the xp boot disk and follow the instrucktion and after that you will get an option to select drive . just click on it and hit format . you have two types of formating ( quick) and full. <br /> 4) insert the win98 boot disk or insert hiren's boot disk and then go to dos ( for hiren boot disk only) after you completly boot from cd rom then you have an A:\ drive . this is called RAM drive. just write the command FDISK and hit enter and then Y and hit enter and then 4 to display partion. you can create a new partion from here also. after making any kind of changes you have to restart the pc . after restarting A:\ will appear. write down the command FORMAT C:\ and hit enter and Y thats it. <br /> there are many ways to format your drives. there are lots software also available in the market to format it. but the best way is 4) because it do the slow formating and also recover the allocation unit.
on Apr 25, 2011 | Computers & Internet
Sata hardisk is not working "usb not recogenised"
Connect hardisk directly to computer without usb
go to start > run > cmd
type chkdsk /p enter
it will fix your problem
remove hardisk via safe remove
and connect via usb cable
Jul 29, 2011 | Conrad WD HDD 250GB SATA 35" WD2500AAJS...
Hi,I've an external case (diamondmax 11 Model:6H500F0)--500GB SATA 3.0GB HDD. And I wanna to activate it,but I Dont have the Installation CD,plz I need your help URGENTLY. (I've an widows XP for my...
Maxtor DiamondMax 11 is a SATA Hardisk and you need SATA External Case. After adding the Harddisk, all you have to do is connect it to the system via the cable of the external case. There is no need for additional drivers/ CD as all the external harddisks are 'plug and play'and the Operating System detects them automatically.
Hope it helps! Good Luck!
CreativeTECH
Apr 09, 2011 | Maxtor DiamondMax 11 400GB 7200rpm 133MBps...
I need to do a low level format for my hard disk. Bad sector problem. Do you guys have any application for that particular kind of formatting?
Bad sector on hardisk there two kinds of that is software and physical. physical badsector caused from plate of hardisk damage is caused by dirt, fallen down, collided, to be incised, etc. While software badsector can be caused when hardisk busy sudden die, cause of usually broken electrics current.
For the bad sector damage of physical of hardisk, we require a really of expert to repair the hardisk. While damage of software we can repair xself use software or tool. One of the software which can be used to repair bad sector on hardisk that is HDD Low Level Format Tool.
Using this software hardisk can be low level format. Require to be paid attention that using low level format on a hardisk, causing all data in hardisk will lose and cannot be recovery again. But this way will be more effective eliminate sector bad.
HDD Low Level Format Tool Support Hardisk SATA, ATA or SCSI, can is also used on removable media like flashcard, flasdisk and etc. To run this software is very easy, that is :
  • Download HDD Low Level Format Tool from the link above and install it till finish.
  • Run HDD Low Level Format tools
  • Select a hardisk which will repair then click continue.
Select LOW-LEVEL-FORMAT tab", if you sure To format the hardisk click "format this device" button and await till finish. ad for hardisk repaired hence required time will longer.
HDD LOW format level can be download from following link,
http://hddguru.com
note : If on hardisk have detected badsector, before doing above steps, first step to backup all existing important datases
Premium experts are not paid for free questions so require your appreciation in form of a 4 thumbs rating
THANKS
Oct 03, 2010 | Computers & Internet
HP dc5100MT motherboard
Based on what I have read about the HPdc5100MT motherboard it only supports SATA hard disk. Not sure how you are able to use a 80GB IDE.
See configurations from HP at this website. All hard drives are mentioned as SATA.
Jun 06, 2010 | HP Compaq dc5100 Microtower PC Desktop
Did not see second sata harddisk
To know if your Hardisk is detected follow this steps:
In Windows XP
1. Open Control Panel
2. Go to Administrative Tools
3. Open Computer Management
4. Double Click Storage
5. Open Disk Management
All the list of Hardisk is here, your hardisk is not formatted that's why, so you have to proceed to format just right click that unformatted hardisk and choose format, specify the label for your hardisk or simply leave it blank.
Jan 11, 2010 | HP dc7600 Small Form Factor P4 640...
When formating progress error code "windows no disk" but the hardisk is still in good condition,
hi! system disk error,no disk on windows,check hard disk from your set up if your hard disk was configured by your computer, restart your compurter press F2 or delete depend how you start your cmos and bios set up,you can see this on left down corner of your windows when starting your computer,if it was there, this might have loosen connection of your hardisk i.d.e cable switch off your computer,disconnect your i.d.e cable just to refresh connection or replace if you have a new one,connect again make it sure it was properly connected,resstart your computer check if your windows will appear.if not reinstalling your windows might solve your problem you mention that your hardisk was good. ....regards
Mar 25, 2009 | Acer Aspire RC900 (91.PJB6P.UE7) PC...
External Segate 200 GB SATA Hardisk (USB 2.0 connection to PC)
I appears the volume may have been corrupted. YOu should run data recovery on the drive if you need any of the content. If not reformatting the drive, should restore it. If the contents are not important, or you have it backed up, go ahead and connect it to the MACINTOSH and format it for MS-DOS.
Unless it is physically damaged ( clicking, beeping, knocking ) it shoud be usable.
Hope this helps.
Oct 19, 2007 | Seagate Barracuda 7200.7 200 GB Hard Drive
Computers & Internet Logo
201 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
