Question about Kenmore 24032\24036 Top Load Washer
The spinner gets off balanced make knocking sound
The other day I was doing laundry and my washer was working fine until it came to the spin cycle. It was so loud I thought the spinner was going to crash right through the thing. It wasn't overload. I had baby clothes and a few adult shirts and pants but nothing to heavy. I opened the lid I got a J error and tried to reposition the clothes and pressed start again. It sounded like it was fixed until it started about 1 minute into the spin cycle and it did it again. Loud thumping sounds. So i decided to take all of the laundry out and try it again. Same thing. It washes fine but when it comes to the spin cycle it gets offbalanced and stops. I opened the top part to see if any clothes got stuck between the spinner but nothing. Everything looks good. Dumbfounded. Help!
    Novelist:
    Champion:
  • 261 Answers
Ok first is it a top load or front load and I need the model number inside the lid or door.
Posted on Oct 08, 2008
Drum seems off balance....
You likely have a corroded/broken spinner assembly on the back of the inner tub. If your washer is out of warranty it is usually cost-prohibitive to repair. We usually quote about $350-$400 parts and labor for it. If you can wiggle the inner basket relative to the outer, that confirms a broken spinner.
Apr 20, 2010 | Frigidaire GLTF1670A Front Load Washer
My washer makes aloud noise when on the spin cycle. HELP I Started a load of laundry and it washed fine until the spin cycle. It started making a terrible noise.
sounds like the bearings have worn out at the back,to check this open door and with your hand lift chrome inner drum up and down if you feel like a knocking noise then its bearings,
Jul 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
During spin cycle washer spins fine but toward the end of the cycle it spins out of control like it is out of balance? Any help is greatly welcomed.
Some front loaders have a super high speed at the end of the spin. Front loaders don't like small loads, the laundry does not spread out evenly enough for a balanced spin.
May 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Spin speed too slow
CHECK THE PUMP. I had the same problem and after removing the pump (fairly easy) found a clump of stuffing from a hole in a quilt jammed in the impellor. After removing and installing the then cleaned out pump it worked perfectly. Suggest using a regular stainless steel hose clamp in place of the factory clamp that is hard to put into position on the hose to the pump. Be sure to put the clear plastic bag back in place over the pump assembly to protect the pump from water damage.
Or the  stater motor on the back has lost a phase because one of the windings has shorted. If the cycle sounds normal and it doesn't sound like it's struggling then the problem is probably not going to be related to the motor. I've found most of these cases to be related to the control board itself.
good luck
May 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Gallery ser. front load makes loud clunking sound in all cycles
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fgsgsgf
Apr 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Very loud spinning cycle
was the shipping bolts removed when it was delivered there are four in the back
Mar 29, 2009 | Kenmore HE2 Plus Front Load Washer
GE Washer Knocking During Spin Cycle
remove the agitator and inspect the main shaft on the gear box.and check the belt underneath.if the shaft is bend you will need a new gearbox. hope this helps.
Feb 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Knocking sound in the spin cycle off balance.
This may help. There is a plastic tab at the bottom back center of the washers (Mine is clear Plastic). This is designed to hold the Tub i n place when it is shipped. First try turning this 90 Degrees, until it is noticable loose. If that does not fix it, you can actully pull the plastic thing out with pliers, as it serves no purpose once the washer in place. I turned mine and the problem seemed to go away so I did not pull it out, but the guy at the store said I could pull it out if I wanted to.
Give that a try
Feb 01, 2009 | Maytag Performa PAV3200
Loud banging during spin cycle
please balance your washer and use smaller loads
Mar 18, 2008 | Kenmore 43052 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
214 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
