For initial pairing, you're the one to provide a passcode. So if the system asks you to enter passcode, you will need to enter a code that you will use as this is the enrollment process. Once the passcode went through, the paired devices will be connected and locked to the system unless deleted or removed manually, so make sure to use a generic passcode that you can easily remember so you won't have any problems in the future. Hope this helps!
By pairing your KU990 and another device, you can set up a passcode protected connection. This means your pairing is more secure. 1 Check your Bluetooth is On and Visible. You can change your visibility in the Settings menu. 2 Touch Paired Devices then New. 3 Your KU990 will search for devices. When the search is completed Refresh and Add will appear on screen. 4 Choose the device you want to pair with and enter the passcode then touch OK. 5 Your phone will then connect to the other device, on which you should enter the same passcode. 6 You passcode protected Bluetooth connection is now ready.
Using a Bluetooth headset 1 Check your Bluetooth is On and Visible. 2 Follow the instructions that came with your headset to place your headset in pairing mode and pair your devices. 3 Touch Yes to Connect now. Your KU990 will automatically switch to Headset profile.
If you have any questions you can try reading the manual here http://www.in.lge.com/Product/Manual/KU990.pdf
that motorola is in the series of bluetooths that all have 0000 for pin numbers and they are NOT changeable.
turn bluetooth off push the button with the phone on it until lited LED turns Purple immediately release and open mic, now it is ready to pair.
then go to the phone tool>bluetooth> search for device enter pin 0000
it will then verify and Voila you are set
When pairing two phones, you need to set up the connection on both phones. One will ask you to enter the password when you are creating the new connection, which you will then need to enter on the second phone to complete the connection. This ensures that only people you allow to connect (people you gave the code to) can connect to your device.
To all with problems with bluetooth pairing.when you push button to turn on bluetooth headset ,hold button until steady light stays lit,then put phone in pairing mode,when ask for passcode enter 0000,which is the standard code for pairing bluetooth.
I have the plantronics320 bluetooth I tried 0000 and it didn't work. Any suggestions?
Same as above 0000 worked
