Question about Sony SPP AQ600 Cordless Phone
Handset hello. The handset on my phone isn't working. There appears to be power ( there's a red light) but it no longer gets a dial tone. The base works fine and gets a dial tone via speakerphone. Do I need to get another handset? Battery issue?  Hope you can help as I like the phone and its three voicemail boxes!
  • 3 Answers
I guess its time to get new batteries
Posted on Jan 01, 2009
I have the Dect 1683 with three handsets. We had a hurricane and the power went out and not all three handsets read "Searching" and I get no dial tone. When the phone rings it rings but you...
Hello
Just unplug the base unit from AC wall power socket for a while, say for about 5 minutes or so, replugh the base unit to power socket again. Place each handset on it and synchronise it with the base unit. As you put it on, you will hear a beep sound. Now the ahndset ahs been synchronised with base unit. Do this for the other two handsets. OK.
Aug 30, 2011 | Uniden DECT 6.0 Cordless Telephone...
I have uniden dxa1850 series phone. It was working fine, but now I can't get a dial tone. I tried the basic fix of unplugging and removing but it still does not work
Check that you have power (eg. Led indicator is on) to your Base station.
If you have power to the base station and you still do not have a dial tone, plug in a non-cordless handset to the phone socket and see if you have a dial tone on yor non-cordless handset, then you have a faulty base station.
Hope it helps and good luck! let me know how you go!
Dec 12, 2010 | Uniden Cordless Phone
The phone lights up when put to charge also the red light on the base,, but when the phone line is connected it wont work ..What do u think is the problem?
The battery in the handset could be bad . First I would test that the base unit is recieving dial tone by pressing speaker button on base unit. If there is dial tone then problem is in handset or in base unit communication to handset. Try resetting power to base unit. Check manual for any re-initialization procedure. If the base unit is not receiving dial tone then I would test that the phone line is delivering dial tone to the base unit by connecting a known good phone to the line cord. If the dial tone is not present , problem could be in line cord from outlet, outlet, building wiring, or service provider.
Dec 08, 2010 | Uniden Cordless Phone
No dial tone on hand set battery is new lights up
Make sure your connection to the phone jack is secure.
Use another wired phone to make sure connection is good to your phone.
Secure connection in back of phone, and plug it in. The base MUST have power to transmit the signal to the handset even if the handset has a fresh charge.
Although the handset is normally linked to the bases, check to make sure via the instructions. To determine if the base recognizes the handset, press the "LOCATE HANDSET" button.
If the hadset responds, the links is there.
Hope this helps
good luck and don't forget to vote!!!
Sep 27, 2010 | Panasonic KX-TG2356 Cordless Phone
No dial tone and base is constantly flashing red, I put the phone on the base to be charged and nothing is working. I turn it on but get no dial tone even though it says connecting. Constanly flashing red...
http://www.uniden.com/products/productdetail.cfm?product=ELBT595
Here is the link to the manual...
But have you tried:
1. charging the unit for 10 hours?
2. registering the handset?
Register expansion handsets to the main base
Before the expansion handset is registered, the battery pack MUST be charged for 10
hours
To register an ELX500 handset, simply place it in the main base.
To register a TCX860 handset, follow the steps below:
1) From the base, press menu/select and select S y s t e m
S e t u p menu.
2) Select R e g i s t e r H a n d s e t, and press menu/select.
3) On the handset, press and hold # until you hear a
beep.
While the handset is registering, H a n d s e t R e g i s t e r i n g will appear in the LCD. When
R e g i s t r a t i o n c o m p l e t e . is displayed, the handset has been registered to the base. If
R e g i s t r a t i o n f a i l e d . appears, please try these steps again.
Customer Hotline at 1-800-297-1023. (Mon - Fri 7 am to 7 pm,
Sat/Sun 9 am to 5 pm, CST. Phone support is closed on holidays.)
Jun 19, 2009 | Uniden 5.8GHz Expandable Cordless Phone...
Problems with handsets
Are they cordless phones?If they are they get there dial tone from the base.If there is a blinking red light on the hand sets they lost communication with the base.Check your user manual to see if you need to program them to the base.
tk46
Jun 09, 2008 | Panasonic KX-TG1033S Cordless Phone
Handset does not work
Your handset is no longer communicating with your base. Depending on your model, the solutions can be a couple of different options. If I could view pdf files on this computer I would look it up for you. But here is the link to the manual on Unidens website- http://www.uniden.com/pdf/TRU8865-2om.pdf
Nonetheless, give this a try. Power down your base, and pull the battery out of your handset. Plug the battery back in the handset and set the bad handset in the base cradle, and then power up the base. Wait about 30 seconds, then give the phone a try. If it still does not work, then you need to try to "re-register" the bad handset back to the base. Look in the manual under "registration" procedures. Hope my help fixes it for you. Good Luck, CG
Feb 17, 2008 | Uniden TRU8865-2 Expandable System...
Handset has No link to base
I was having the same problem with the same model phone, and fixed the problem by rebooting the phone – unplugging the AC and phone cord from the base station and plugging both back it, then removing and replacing the handset to regenerate the security code.
Nov 17, 2007 | Xact Communication XG2200 Cordless Phone
Handset No Link To Base error and no dial tone
I have the problem. I think it is because the battery i have in it was a Ni-MH and it should be a Ni-Cd. I am now looking for the right baterry Good luck Frank wolfgang24@verizon.net
Jan 27, 2007 | GE 900 MHz Phone
Handset ?No Link To Base? error and no dial tone
2/29 Have you registered or re-registered the handset?
"No link" can mean handset is not accepting radio wave of base unit. At Mfgr website pull-down operator's manual and look for registration instructions. Some sequence of buttons will create a radio signal from base (have handset off base) then another sequence of buttons on handset will accept radio signal. If handset has "menu" button, try "menu", then "00" (zero zero) then select an accept or "OK" button. Good luck.
Jan 14, 2007 | Xact Communication XG2200 Cordless Phone
Sony SPP AQ600 Cordless Phone Logo
191 people viewed this question
Top Sony Lands Phones Experts
Sandeep Kamat
Sandeep Kamat
Are you a Sony Lands Phone Expert? Answer questions, earn points and help others
