Question about Toshiba Estudio 200L Copier
Toshbia estudio 600 error code CD20
How do you get the transport waste toner auger off of the copier?
  • Ron McAllister Oct 08, 2008
    Thanks so much Chad. The auger solution you gave for the Studio 600 CD20 error code worked! After following your instructions, I was able to remove the auger and replace it with a new one. The copier is up and running. Thanks again. I repair many brands of copiers, printers and faxes and this Toshiba was really giving me a headache, lol.
    Scholar:
  • 62 Answers
This is not an easy procedure. Most likely, the auger is stopped up with chunks of hardened toner, which is prohibiting the auger motor from turning, thereby causing your code. You are going to have to take the main board off, as well as the metal tub that the board is mounted in to remove the auger. Once these are off, you will be able to see how it comes off. If you need more info, let me know.
hope this helps,
C
Posted on Oct 07, 2008
  • Chad Houston
    Chad Houston Oct 08, 2008
    Not a problem! Glad it fixed you problem. Toshiba is my main line, so visit again if you have more trouble.
    Chad
  • Mohammed Raheem
    Mohammed Raheem Jul 25, 2013
    toshiba estudio 600 giving on the panel that sercive recommened for IQC
I have an ir6570 giving me an error code e0013, e0004 please help
This is an error code dealing with the toner auger motor being bound up. Has the waste toner message been on for along time and the waste toner bottle not being emptied. Sometimes the waste toner counter has been reset several times without the bottle being emptied. This will cause the waste toner to back up in the auger mechanism. Thsi will have to be taken apart ( very tedious job ) and the toner removed from the tube. The auger spring and even some gears may have to be replaced. I've never had to replace the motor on any copier yet. Good Luck.
Sep 07, 2012 | Canon IMAGERUNNER 6570 Copier
Appears cf70 by starting machin
[CF70] New toner transport motor abnormality
Check if the transport auger and paddle are not locked (no extraneous material or toner clod in both the toner transport sections at the cleaner unit).
Is the new toner transport motor disconnected?
Replace the new toner transport motor.
Feb 20, 2012 | Toshiba E-STUDIO 720 Copier
Phaser 7400 error 929
Xerox Phaser 7400 error codes 929 - Please check your Waste Toner Auger Assembly if motor won't turn and when you done the sensor test and passed the Waste Toner Auger Assembly was jammed. I just fixed this problem here, just now!
Jan 13, 2012 | Xerox Office Equipment & Supplies
Sir, I have Cannon IR 6570 Error Code E0000013 appear tonight, Please guide me how to solve
You have problem with waste toner assembly. You should remove rear covers, and pwb`s from backs, and then remove waste toner assy.
then check is auger damaged. It is possible to repair auger.
Sep 07, 2011 | Canon IMAGERUNNER 6570 Copier
I am getting error code L4-02. Any solutions?
L4-02 - Drum Motor Lock.
  1. Remove the process unit, remove the drum & check the waste toner auger & gear assembly.
  2. You will probably find this is seized or broken due to excessive drum cleaning.
  3. When changing the drum & developer, you must reset the rotation counters as well as the drum/dev counters. Otherwise, there is excessive over-toning, leading to waste toner filling the toner cartridge waste area too quickly & therefore leading to waste toner auger assembly blocking up.
  4. You will probably need a new process unit as the auger drive gear has been known to break off the frame.
  5. There is new firmware for this problem. Have a service professional update the firmware for this device and the problem will be gone.
Feb 16, 2011 | Sharp AR-M355U Copier
I AM GETTING ERROR ON STUDIO 520 IS CF70
[CF70] New toner transport motor abnormality (1) Check if the transport auger and paddle are not locked (no extraneous material or toner clod in
(2) Is the new toner transport motor disconnected?
(3) Check if the connector of the LGC board and connector Pins are not disconnected.
(4) Replace the new toner transport motor.
(5) Replace the LGC board.
-David.
Nov 03, 2010 | Toshiba COPIERS E-STUDIO 520 Copier
Its saying reset drum basket, the waste toner is not being transported to the waste toner box. but have taken everything out an put a new waste box in. ?????
It is the "transport" of the "waste" toner-ink from the toner-cartridge along its path to the "basket" that is the problem.
Take a look for how the waste toner "moves" along its path; the path may be clogged.
Sep 01, 2010 | Office Equipment & Supplies
Toshiba e-studio550 service code CD1, PLEASE help me to fix the problem and if there is any service call to reset it, thanks
CD1 indicates Abnormal drum cleaning brush motor.
U need to perform followings:
(1)Check if the cleaning brush, recovery toner transport auger and recycle toner transport auger are not locked (no extraneous material or toner clod in both the toner transport sections at the cleaner unit and recycle toner unit.
(2) Check if the connector on the LGC board and connector pins are not disconnected.
(3) Replace the cleaning brush drive motor and recycle toner transport motor.
(4) Replace the LGC board.
Mar 09, 2009 | Toshiba E-STUDIO 550 Copier
Waste toner message will not clear.
sir,
You open the front cover, there you can see the plastic bag. on the side of the cover you can see the intruction regarding the removing and refixing. actually it will be in white like colour and having a black bottle cap.
And also after you taken the waste toner catridge. you can see one sensor below a pipe like that which is projecting from the drum unit , it is the waste toner path. Inside this the waste toner auger will be there. you just clean the sensor because you may also get the waste toner error by the sensor.
1. sensor below the auger after the waste toner catridge.
2. waste toner catridge outside and inside. dispouse the toner and also clean the otside part will cloth , beause some projections some holes like that will be there. i told na that sensor will be passing the signals through this waste toner catridge projection. If any toner in that projection then also the same. Be causreful while you are disposing the toner. You may intake and also your properties may be having the black coating like that.
any clarifications mail me at ramanathanr@integramicro.com .
Nov 17, 2008 | Toshiba e-Studio 350 Copier
Canon 5070 - Error code E000013-0000
This is the error code for a clogged waste toner auger. If you heard a clicking sound coming from the rear of the copier before the error you have clogged waste toner . This may take a long time to clear. May have been caused by not emptying the waste toner bottle when it indicated to do so and the waste toner backed up on itself. You may have to remove most of the items at the rear of the copier to either replace the auger pipe assy or just the slip gears that drive the auger. I've never looked forward to doing this on any of the copiers that have an auger system. If you're not a tech a tech should be called and may take several hours depending on how serious it is to clear. Good Luck.
Oct 10, 2008 | Canon imageRUNNER 5000 Copier
216 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
