Question about Toshiba TZ50V51 50" Rear Projection Television
DOUBLE IMAGES SINCE I MOVED, THE TV HAS AQUIRED DOUBLE IMAGES ON SCREEN MORE ON SOME DAYS THAN OTHERS double images on hd tv
  • 125 Answers
There is a problem with tthe convergence section this is something a tech can do
Posted on Oct 05, 2008
I have a Hitachi ultravision digital Hd Tv(Model: 43UWXtenB V2A04one295) which shows double or triple color images at the same time. How can I fix this easily ? Thanks for any advices. Sound speaker is...
This tv problems u can't fix it easily,u must take the tv aparts and change an electronic board that call the T-CON board to fixed this problems.If this problems double or triple images not causes by U or an objects by outer forces hitting the LCD screen panel itself,if yes this problems causes by U or an objects by outer forces hitting LCD screen panel itself.This tv problems can't not be repair,because the LCD screen panel itself it is dead and damages leaking radiation,if got hit by an outer forces,if screen damages by outer forces,this tv only can used as salvage tv for it electronic circuit boards for other tvs for as parts only now,because if the tv require a new LCD screen panel will cost the same as a new tv.This T-CON board sit at the bottom in the middle of the tv LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy an refurbish T-CON board for the replacement.
Jul 28, 2011 | Hitachi ULTRAVISION L42V651 42 in. LCD...
Double images on screen
IT SOUNDS LIKE A PINCUSHION PROBLEM. IN MOST CASES IT IS DUE TO CAPACITORS GOING BAD ON THE BOARD. OTHER TIMES SOME TV'S HAVE LARGE MICROCHIPS THAT RUN THE PINCUSHION AND COLOR SYNC. HOPE THAT HELPS.
Feb 20, 2010 | RCA HD52W56 52" Rear Projection HDTV
Hitachi 57'' rear projection tv has double images on both sides.
tv looks in the center and have double and multiples colors . majic focous do not fix t
Jul 13, 2009 | Hitachi Televison & Video
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Double images
you will need to have the tv re converged to make the picture right call a repairman
Feb 16, 2009 | Samsung HCM4215W 42" Rear Projection...
Double images
you will need the remote to adjust convergence.
Mar 13, 2008 | Toshiba 57HLX82 57 in. Rear Projection...
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Cracked screen and down screen
If the double images are located at the bottom on one side, you might have cracked the mirror inside the set and it has been displaced making the picture in that area bad (especially if the rest of the picture is OK)
Dec 28, 2007 | Philips 60PP9202 60" Rear Projection...
DOUBLE IMAGES
How do we adjust convergence? I went to the service menu and all I see is alot of settings none of which help me out.
Can anyone explain this in further detail?
TIA
Aug 26, 2007 | Sony KP-53HS30 53" Rear Projection...
Toshiba TZ50V51 50" Rear Projection Television Logo
265 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
