Question about HP Photosmart M415 Digital Camera
Power and image problem
My camera will not power on for more then 2 or 3 sec. and when i comes on the images on the viewer are reversed. it locks up and can do anything else.
please help do not have money for anything else or to replace.
c.twillie@gmail.com
MY couSINs cAmera uSEd 2 dO tHe sAMe thINg aNd aLL i diD tO fiX iT wAs tOOK tHe memORy cARD out aND pUt it baCK in aNd thEn iT worKed
Posted on Nov 21, 2008
No Image Through Viewer
So your camcorder has problem of No Image in Viewer. Will you let me know this problem is in Camera mode or in playback mode? and this camcorder has 2 viewer, one is LCD and 2nd is Eyepiece. Which one is not showing image?
Jun 01, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
What do i do
If images cannot be downloaded from the camera to a Macintosh, check the status of the camera and the Macintosh and resolve the problem accordingly.
1) Check the status of the camera and Macintosh.
1. Connect your camera to the Macintosh and turn the camera on.
2. Open the "Applications" folder on the Macintosh HD.
3. Double-click "Image Capture".
* If the "Imaging device not connected" message appears, follow the steps described in [Checking the connection between the camera and PC].
4. Select "Preferences" from the "Image Capture" menu.
5. The procedure for using the Image Capture Preferences window differs depending on the OS version used. Use the correct procedure for your version of Mac OS.
- Mac OS 10.4: Click "General" in the Image Capture Preferences window.
- Mac OS 10.3: Click "Camera" in the Image Capture Preferences window.
- Mac OS 10.2: Simply proceed to the next step.
6. In "Items launched at camera connection", select "FPVBridge" and then click the [OK] button.
* If FPVBridge is not among the displayed items, follow the steps in [Displaying FPVBridge] below.
7. Quit "Image Capture".
If you implement the above procedure up to step 6, FinePix Viewer launches automatically.
* To stop FinePix Viewer from launching automatically, follow the steps in [FinePix Viewer Setup] below.
2) Resolving the problem
1. Plug the USB cable into the camera and Macintosh again.
* If you are using a USB hub, do not connect the camera to the Macintosh via the hub.
1. Select "Other".
2. Click the "Applications" folder.
3. Click the "FinePix Viewer" folder.
4. Select "FPVBridge" and click "Open".
5. Click [OK].
1. Launch FinePix Viewer.
2. Select "Automatic Save Settings" in the Settings menu.
3. Tick the "Auto save images when the camera is connected" checkbox in "Operation Settings When Camera Is Connected".
4. Click [OK] and close the "Automatic Save Settings" window.
5. Exit FinePix Viewer.
6. Turn the camera off and then on again to test whether FinePix Viewer launches automatically.
Apr 28, 2008 | Fuji FinePix S5700 Digital Camera
I can't find the digital camera image files I saved on my PC.
Use the procedure below to search for digital camera image files saved on a PC. 1. In the "Start" menu on the desktop, open "Find" -> "Files or Folders". 2. In the "Names & Locations" window, enter the image file name in the "Named" field. Enter "DSCF" as the file name if you have not renamed the file. If you changed the file name, enter the new file name. 3. In "Look in" select the hard disk and then click the [Find Now] button to begin the search. The files found are listed in the search result. Check the results for the desired files. 4. If the desired files are not in the search results, the image files were not saved. --Saving Image Files-- - Downloading images from FinePixViewer or Exif Viewer: 1. Connect the digital camera to the PC. The "Viewer" window opens and the images are displayed as thumbnails. 2. Click "Select All" in the "Edit" menu. 3. All the images are selected (indicated by a pink frame). With the left-hand mouse button held down, move (drag) the images to the folder in which you want to save them and then release the button (drop). - Saving images from a removable disk: Connect the digital camera to the PC. When the Viewer automatically starts up, click the Close ([X]) button to close the Viewer window. Then open the "My Computer" -> "Removable disk" -> "DCIM" -> "100_FUJI" folder and select "Select All" in the "Edit" menu. Then select "Copy" in the "Edit" menu; open the folder in which you want to save the images, and select "Paste" in the "Edit" menu. All the selected images are copied and saved in the folder. You can also copy the images by selecting the entire "100_FUJI" folder.
Aug 30, 2005 | Fuji FinePix 2400 Zoom Digital Camera
Aug 30, 2005 | Fuji FinePix 2300 Digital Camera
Aug 30, 2005 | Fuji FinePix 1400 Zoom Digital Camera
Aug 29, 2005 | Fuji FinePix 1300 Digital Camera
Aug 29, 2005 | Fuji FinePix 3800 Digital Camera
Aug 29, 2005 | Fuji FinePix 2600 Zoom Digital Camera
HP Photosmart M415 Digital Camera Logo
41 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
