Question about Black & Decker 5700 Powershot Forward Action Stapler
How to reattach the spring in the Surebonder pneumatic stapler?
  • 2 more comments
  • kwie Oct 08, 2008
    I have the same problem
  • Gene Maier Oct 25, 2008
    same problem took it apart to unjam cant figure out spring anyone have an interior assembly drawing
  • donaldc31 Nov 17, 2008
    same problem
  • Anonymous Dec 16, 2008
    cant get spring attached properly
.CENTRAL PNEUMATIC staples go right through insulation paper how to adjust
quite likely still too much pressure .personally I prefer a slam hammer stapler for that task .
Nov 19, 2017 | Staples Tools & Hardware - Others
I have a SUREBONDER ELECTRIC NAILER/STAPLER 5900 where can i buy the nails at
Use Surebonder® #4 or Arrow® T50® heavy duty staples, #8 brad nails and #9 pin nails. You can get the Arrow T50 items and most home stores.
Nov 08, 2017 | Electric Tools & Hardware - Others
How do you load staples into a surebonder model 9630?
Loading a 995630. Hold gun upside down with front of gun in left hand. Open track release with right hand. Lay one section of 1/4" crown staples in the bottom of the gun itself, in front of the track. Slide track over staples. Store tool at room temperature. New gun needs 6 drops of air tool oil through the air inlet just before first use. If you do not have the recommended automatic oiler installed on your airline, you will need to manually oil with three drops every 3rd row of staples. Run PSI around 80 and never exceed 100 PSI on your air compressor.
Sep 01, 2014 | Surebonder Pneumatic Stapler
How to replace the spring in the staple loader
Call the manufacturer with your email address and request step by step instructions on replacing the pusher and spring in your specific model number.
Jun 03, 2014 | Surebonder Pneumatic Stapler
Stapler trigger stuck
Check for a trigger lock/bar that slides up or down to unlock trigger. If no lock, take a small flathead screw driver and jiggle it in the back of the trigger.
Aug 17, 2013 | Surebonder Pneumatic Stapler
Surebonder 9600
Call the manufacturer with your email address and ask for detailed instructions on how to replace the pusher and spring on your specific model number.
These are instructions on replacing the spring and pusher for Pneumatic model #'s: 9600, 9610, 9615.
1. Wearing protective eyewear, remove air line supply HOSE from your gun, turn gun upside down holding the front of the gun in your left hand
2. Remove u-shaped piece that holds the track in place at the back of the bottom of the gun.
3. Slide track out of gun.
4. Take the long black spring (part # 38) and hook one side of it to the hook inside the pulled out track.
5. Feed the other side of the spring under the silver wheel in the front of the track and pull it up holding the tension. You might need to use the end of a paperclip to feed the spring through.
6. Take the u-shaped pusher (part # 33) and place the other end of the springs hoop onto the hook inside part #33. Make sure the opening of the hook faces the back of the track, and that you see the yellow tape so that it will show in your view window.
7. Carefully place part #33 with the spring attached and the opening of the hook facing the back of the track, back onto the front of the track. The springs tension will hold it in place.
8. Carefully slide the track back into the bottom of the gun making sure you are placing each side of the track into the grooves.
9. Carefully snap the u-shaped lock back onto the bottom of the track to hold the track in place.
10. With the tool upside down, slide your track open and be sure to place your staples in the bottom of the gun itself with the points of the staples pointing up towards the ceiling, not on the track.
Parts are available online at on the left hand column, select Pneumatic Parts, then select your tool. It will bring you to the ordering page.
Mar 17, 2013 | Surebonder Pneumatic Stapler
Adjust depth on pneumatic stapler
I have noticed that many nailers do not have a way to adjust the depth. Usually there is a thumb screw under the trigger or on the side of the safety foot. If no visual way to adjust, you must get creative. The bumper stops the driver at the bottom of the cylinder. Adding layer of rubber (inner tube or similar) under the bumper will cause the driver extend less and shaving the bumper will cause it to drive deeper. Another method if to add material to tip of safety to space gun away from work (less deep, using various thickness of spacers like used on flooring nailers) or grind the tip of the driver (cant reverse but if driver is too long grind away) . Buy a spare driver and make adjustment to tip for when you need different setting. Good luck
Aug 28, 2012 | Surebonder Stapler. Pneumatic 1/4 in....
Remove a jam staple from a hardwood floor stapler
on that model there should be a few bolts on the tip side of the nose , remove screws and top part of nose and remove the damaged staple,, then replace parts
Nov 30, 2009 | Surebonder Pneumatic Stapler
Surebonder 4.8 v cordless stapler
with mine there is a fine spring on the plunger which holds the staples in which i restretch every now and then you could also try checking for jammed staples and putting one or two drops of oil on the shaft that pushes the staples down after the oil operate afew times empty of staples see if this helps bestaluck glenn
Oct 26, 2008 | Tools & Hardware - Others
Black & Decker 5700 Powershot Forward Action Stapler Logo
196 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
