Question about Jenn-Air ® 48" Professional Over The Range Hood, JXT9048CDP
I cant get it to turn on
I cant get the lights or fan to turn on anymore is there a reset switch
    An expert whose answer gotĀ voted for 100 times.
  • 171 Answers
Hi lillady909,
I'm Harvey the Master Plumber.
Your problem is: you cant get the lights or fan to turn on anymore is there a reset switch
First check the circuit breaker. If OK then check the transformer in the unit. It's next to the fan motor. If no power on the high side then you have a loose or broken connection. If you have no power on the low side the you have a bad transformer.
Feel free contact me again!
Please give me a rating here at before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 27, 2008
I bought my 1999 oldsmobile cutlass new and now im having problems with my motor fans coming on,my ac don't work anymore but for the fans to come on I have to turn my ac switch on,if I switch to heat
If the fans work, (I'm guessing there are two of them) only when the A/C is on, then it means that the temperature sensor is damage. If possible, have a professional take a look at it. Both fans are OK,
Oct 10, 2014 | 1999 Oldsmobile Cutlass
Cant accelerate
disconnect the neg. battery and clean the connectors ECM
Sep 27, 2013 | Hyundai Accent Cars & Trucks
Hunter fan works light broken
Check to make sure light wires are connected at light kit & remote. Otherwise it's probably a bad receiver. If there is a pull chain for the light pull it once & try the remote light button again.
Mar 10, 2013 | Hunter Ceiling Fan Light Switch Control
Some functions of switch stopped working
Sounds like you need a NEW RECEIVER. Call 1-800-307-3267(Minka Aire)
Feb 13, 2013 | Minka Aire Ceiling Fan
I have a minkaie switch model uc9040t, I went to turn the light on, on the fan and it blew the light and now when I look at the switch on th on position the green light is off like there is not electricity...
I have a minkaie switch model uc9040t, I look at the switch on the on position the green light is off like there is not electricity coming to the switch, but itested the cables and there is electricity, and of course the fan won't turn on either, is there a way to reset this switch
Jan 31, 2011 | Minka Aire Ceiling Fan
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
My ceiling fan/light can be controlled only by the remote control. our remote is not responding with the fan anymore. it has new batteries and has power, it's just not corresponding with the light/fan. it...
Turn the power off to the fan / light by flipping the breaker or pulling the fuse and keep off for 10 seconds then turn back on, it should reset the contol receiver in the fan.
Oct 27, 2009 | Hampton Bay 24002 Ceiling Fan
My casablanca fan/light wall switch only works
No . have this checked by a licensed professional it is more than likely bad switchs in the fixture but you can never be to careful with electricity
Aug 23, 2009 | Dryers
Cant turn fan on with out turning the light on
Fan power is wired to light side of light switch. Move fan wire to other side of light switch.
Jul 11, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Fan and remote not working
make sure the main switch is on ,also the chain switch on ,before using control remote!!
Dec 23, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Jenn-Air ® 48" Professional Over The Range Hood, JXT9048CDP Logo
232 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
