Question about Frigidaire Refrigerators
I have a Figidaire FRT18SJGW2 and we are having a problem with it getting cold enough. We have unplugged and cleaned it out and plugged it back in and still having the same problem. What we are wondering is if there is a way to add more refrigerant to it?
We actually decided to buy a new refridgerator. Thanks
Posted on Sep 25, 2008
Why does my refrigerator keep acting up the freezer gets frosted up then the frig gets warm I have cleaned it underneath unplugged it for 24 hours then plugged it back in it works great for about a w
This problem can have many causes, but generally it is a defrost issue. If the freezer coils are frozen over, they block cold air flow to the refrigerator; and can be caused by different part failures. See the link below for a good explanation of possible failures and for parts. Also, if you turn the refrigerator temp to 0ff and unplug the refrigerator then plug it back in, it should go into defrost mode. Leave it that way for 15 or 20 minutes, then unplug and plug it back in. It may resolve the defrost mode problem. If not you'll need a part, or repair man. Kenmore Refrigerator Freezer is Cold But Refrigerator is Warm
Oct 18, 2014 | Kenmore Refrigerators
Kitchenaid KSRL25FRBL00 all lights are staying on but the refrigeration keeps shutting off
make sure that you removed all the dust - check thoroughly with a flashlight to make sure. It sounds as the unit is overheating - not drawing enough air through the condenser. Unplug the unit and clean it thoroughly and give it another shot - make sure enough air can be drown in. If this does not work for you might want to call a repair company.
Mar 25, 2014 | Refrigerators
Kelvinator Cyclic 330 not getting cold enough
Empty the refigerator and freezer, unplug it for about 8 hours, leave freezer door open so it will completely defrost. Plug it back in for 4 hours and close doors before you fill it back up with food. If you have a thermometer, check the interior temperatures before you fill it back up. Refigerator should be around 42 degrees F.
Mar 19, 2014 | Refrigerators
Fridge not freezing meats
I was writing a big note here before then hit the wrong button, it was just a bunch of jargon anyway. Yes it is the condenser fan motor causing your problems. Doesn't cool the refrigerant properly than nothing works. I would change the fan before it causes any damage to the compressor.
Sep 04, 2012 | Whirlpool Refrigerators
Maytag side by side not getting cold enough
look in the back should have a fan in the bottom probably very dusty if it is it cant cool fridge clean it and it should work unplug it to clean
Jun 21, 2009 | Maytag MSD2756G Side by Side Refrigerator
Fridge & freezer not cold enough
EASY FIX. TAKE ALL FOOD OUT OF FRIDGE AND FREEZER AND STORE IT.
THEN UNPLUG YOUR FRIDGE FOR 24HOURS WITH DOORS OPEN.
YOU WILL HAVE TO CLEAN UP ALOT OF WATER. THEN CLEAN THE FRIGE.
WHEN YOU PLUG IT BACK IN IT WILL WORK.
BUT THIS IS JUST A TEMP FIX. IT WILL HAPPEN AGAIN IN ABOUT A YEAR OR TWO.
TO GIVE U A MORE PERMANENT FIX WILL TAKE SOME TIME. TRY THIS FIRST.
Apr 30, 2009 | Amana ARB220ZC Bottom Freezer Refrigerator
Refrigerator and freezer not cold enough
Can you find the make and model numbers for me. The model is usually located inside the fresh food section door near floor. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Refrigerators
Freezes ice, but food compartment is not cold enough, have cleaned and left unplugged overnite, did not fix problem. HELP
Yes. You got it right You have plugged the defrost drain line.This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube
Jul 15, 2008 | GE GSS20IEP Side by Side Refrigerator
Freezer not cold enough to freeze items solid
Here are some things you can check yourself. Does it run all the time almost non-stop? if so check the vents under the front of the frig and make sure they are clean. Aslo check the condenser coil (either in back of the frig,or under the frig)Make sure that coil is clean. The condenser coil has to have contact with the outside air in order to release the heat it removed from inside the freezer.
Make sure you frig has plenty of ventilation ( wall too close on sides and back) Hope this helped. If not then you should have a pro look at it.
Jan 28, 2008 | Frigidaire GLRS264ZA Side by Side...
Refrigerators Logo
157 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
