Question about Cyberhome CH-DVD 300 DVD Player
No power All of a sudden it won't power on, from power button or remote. I unplugged it, checked the outlet, let it sit for a while, checked the remote battery, talked nice to it, etc. What's up?
  • 4 more comments
  • muskymike
    muskymike Sep 24, 2008
    My Cyber Home CH-DVD300 player will not power up.
    Before it would power up and not play, but, now nothing.
    1-Have power to Black and White connector.(121 volts on meter)
    2-Fuse is checked and is good.(I took out to check)
    3-No burn marks anyplace.
    Any ideas?
    Mike
  • oxer Sep 28, 2008
    My 300 won't power up. I used the emergency slot on the bottom to get my disc out. Other than caps what's up with this thing? No support, the company went bankrupt.
    EAO
  • phillipslane Sep 29, 2008
    Same problem, unit just died. Checked the voltage and 120VAC is present up to the input of T1 which is a coil or transformer number EF20-1401.
    No voltage out of transformer.
  • dreamwvr Oct 07, 2008
    Thanks, I checked fuse, cord, etc. Then found my newer portable player will connect to my system and suffice for what I need. So will give this one away to someone else who wants to play with it!
  • Anonymous Oct 14, 2008
    the power supply is ok, but my dvd don't turn on.
  • Ludwix Oct 15, 2008
    Rearranged my TV system; pulled the plug on the player. On reinserting there was a brief flash at the 115V power. Now the unit will not power up -
    panel or remote.
    Any suggestions?
Check voltage on the two extreme wires of the CN2 connector on the power supply board. On the yellow wire has to be 12V against one of the black wires (GND - ground, negative) and on the red wire you must measure 5V. If voltages are bellow this levels there is a problem with the power supply. In most of cases the 2200uF/10V capacitor is blown. I recommend to replace all the electrolytic capacitor of the power supply board with new ones. Observe capacitances and voltages of the new capacitors! You can use higher voltages (but never lower!) but the same capacitances. You can make it with little soldering skills.
Have a good luck and sorry for my English...
Jirka
http://www.hlucnisousede.cz
http://www.youtube.com/hlucnisousede
Posted on Jan 24, 2009
    Brigadier General:
  • 6,966 Answers
If there are no indicators that it is receiving power such as timer/clock, standby light, whirring sound when first plugged in, then initially, it would be safe to say that the internal power supply is the culprit. For the moment, course of action would be:
  • confirm power availability on the outlet (which as you posted performed already);
  • check the AC cord/powerline of the unit with a continuity tester;
  • check the fuse (inside);
  • check for the presence of standby voltage (normally +5).
Of course most of the above would require opening the unit which needs a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 23, 2008
  • Louie  Role
    Louie Role Oct 08, 2008
    @dreamwvr,
    Appreciate your postback and comment, likewise the rating.
    @phillipslane, oxer & muskymike,
    My apologies for the very late reply. It is only when dreamwvr posted anew that I was informed that there are other postings of similar concerns.
    To address your problems. The power supply is basically an SMPS (switch mode power supply) very similar in design and principle to the power supply of your PCs. The 120 VAC is first converted to about 180~200VDC that supplies a high frequency circuit which then feeds the transformer, The output is high frequency high current which in turn is converted/regulated to the required DC voltage of the CH-DVD 300.
    Most SMPS design has a 2 X 2 (4) terminal optical coupler as well as an 8 pin controller IC on the secondary side. Repairs would be facilitated if you have a copy of the service manual or at least the schematic diagram. In the absence of those, data sheets and application notes of the earlier mentioned optical coupler and controller IC could provided basis for working voltages.
Philips digital tv won’t turn on.
unplug from electric, wait 30 seconds, plug back in. Check that you have power at the outlet (fuse/breaker shut off?) If it has a power word which plugs into the TV as well as the wall, be SURE it is tightly attached to BOTH. Make sure you aren't blocking the remote control receiver (you can turn most TVs on/off on the TV itself -- look for a power button). Be sure your remote has fresh batteries. Good luck!
Jan 14, 2018 | Philips Televison & Video
The Vizio TV won't turn on all of a sudden
Are you trying with the remote and the power button on the tv? The batteries might be dead in your remote if you haven't tried the power button on the TV.
Feb 15, 2013 | Televison & Video
My tv turns on and off without touching it
First of all ensure that this is not caused by the power inlet. Many a times, loose contacts in power outlet can cause this problem. Try connecting the TV to a different power outlet. If problem persists, it is better to call in a qualified service technician, since the back cover has to be opened for investigation.
Aug 19, 2012 | Televison & Video
Why does plasma tv not come on?
Check the power outlet. Try connecting it to a different power outlet. Look for any jammed buttons on remote. Retry by removing batteries of the remote and operating the TV from the control panel. If nothing works, the power supply has gone bad. It could also be a blown fuse.
Aug 03, 2012 | Zenith Z50PX2D 50 in. Plasma HDTV
ELCHW402 won't turn on
An internal relay may have failed.
Dec 08, 2017 | Element ELCHW402 40 in. LCD HDTV
My projector won't turn on, only the power light shows red, the status light is blank. Tried the remote and manually turning it on.
Hello
If the power light is ON and status light is OFF; check if any objects are blocking the air inlet or outlet grill, and remove them if any, and carry out the following.
[1] Unplug the power cord from wall outlet.
[2] Make sure that the projector has cooled off.
[3] Plug the power cord into the wall socket.
[4] Press the power button.
Check whether the cooling fan has stopped. The problem is with overheating itself.
If these does not help you, your projector need service. OK.
Nov 18, 2011 | Mitsubishi HC1500 DLP Projector
All of a sudden the MP560 won't turn on. The outlet is working but the printer doesn't respond to the ON button. I've checked the power cord it seems to be ok, the cord hasn't moved or been...
This may be a longshot, but many electronic devices like TVs, dryers with electronic computerized controls, entertainment systems like the Wii, and other devices sometimes get "confused" and won't turn on, turn off, or otherwise work properly, perhaps due to a small power surge in your AC line.
I've found that one of the first things to try when it appears to be a failure of the electronics and not a mechanical issue is to unplug the device at the wall (to make sure that any power adapter is also unplugged) and wait about 10 minutes for any residual electric charge to dissipate. Then plug the device back in and give it a try. This has worked with a television, a Wii console, an electric clothes dryer, and some other devices that I thought had died for good. This may explain why sometimes a device is taken to a repair shop and it works fine.
There are, of course, other reasons that the unit won't turn on, but I would try this first before looking for other reasons for the problem.
Jul 23, 2011 | Canon MP560 All-In-One InkJet Printer
My tv won t turn on i just purchased it today i plugged it in and it won t turn on
Check the electrical outlet which the tv is plugged into. Make sure nothing is loose at the outlet as well as on the back of the tv where the power cable plugs in. Another thing to try is plug a different device into that same electrical outlet and see if it turns on. If it doesn't turn on, it could be a faulty electrical outlet. If you've tried both the remote & the power button on the tv, a shot in the dark would be to change the batteries in the remote.
You could always try calling their tech support at 1-800-256-2487. A last resort would be to return the tv from where you purchased it.
Mar 09, 2011 | Emerson Televison & Video
Remote control for garage door suddenly stopped working.
Press and hold for 3 seconds the button on the wall control with the lock icon. There you go.
Nov 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
TV won't come on!
your system control section has failed due to sudden power failure. 1please check power to system cotrol. 2check tunning &aft ckt in system. 3check memory ic & its section 4check system ic & its section regards
Sep 12, 2007 | RCA F32650 32" TV
Cyberhome CH-DVD 300 DVD Player Logo
479 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
