Question about Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher
Dishwasher cycle "holds'
This dishwasher was installed new in April 2006. It is mostly used on the Light Wash cycle, but lately it seems to hold and it hums for several minutes at the 76 minute mark. Sometimes the cycle will continue after a few minutes, other times it has to be stopped and restarted. It drains alright, so I don't think that's the problem. Any ideas?
    Sergeant:
  • 409 Answers
check the keypad. it has a ribbon cable that plugs into the control board. it may be loose.
Posted on Sep 23, 2008
I need to know what the buttons say on the dishwasher. Mine have no letters
Some SHX46 washers have 4 wash cycle buttons and others have 5. The button on the left side on top of the door is the start/stop button regardless of how many wash cycle buttons you have.
If you have 5 cycle buttons, reading from left to right they will be as follows.
1. Top Rack Only / Sanitize
2. Power Scrub Plus - (Long wash for heavy soil)
3. Regular Wash - (Economy wash for light to medium soil)
4. Delicate Wash - (Shorter wash at a lower temperature for delicate items)
5. Rinse & Hold.
These buttons are also used for cancelling a wash cycle. Hold down buttons 2 and 4 (Power Scrub Plus and Delicate) at the same time to cancel a wash cycle and drain the water out.
If your washer does have 4 buttons, it means you don't have a Top Rack / Sanitize cycle, in which case the button configuration - from left to right - will be:
1. Power Scrub Plus - (Long wash for heavy soil)
2. Regular Wash - (Economy wash for light to medium soil)
3. Delicate Wash - (Shorter wash at a lower temperature for delicate items)
4. Rinse & Hold.
With this button configuration, the cancel cycle buttons are 1 and 3.
I hope this solves your problem. If you need any additional information, please post back.
Regards,
BElectric
Dec 12, 2010 | Bosch 24 in. SHX46B05 Stainless Steel...
I have a Bosch SHX46A05UC/33 5-cycle dishwasher whose labels on the cycle buttons have also worn away. While the Macmarkus post was helpful b/c I have some of the same buttons, can you tell me the labels...
Some SHX46A washers have 4 cycles and others have 5 cycles.
I'm fairly sure your model has the hidden buttons on the top of the door and you stated you have five-cycle buttons, in which case they will be as follows.
1. Top Rack only cycle or Sanitize
2. Power Scrub Plus
3. Regular Wash
4. Delicate Wash
5. Rinse and Hold.
These buttons are also used for cancelling a wash cycle. Hold down "Power Scrub Plus" and "Delicate" at the same time to cancel a cycle and drain the water out.
If your washer does have 4 buttons, it means you don't have a Top Rack / Sanitize cycle, in which case the button configuration (from left to right) will be:
1. Power Scrub Plus
2. Regular Wash
3. Delicate Wash
4. Rinse and Hold.
Regards,
BElectric
Nov 21, 2010 | Bosch 24 in. SHX46A05UC Built-In...
After the wash cycle dishwasher beeps
Hello, welcome to FixYa. While I don't have access to my PC files at the moment as I am on my iphone, I believe this is the procedure for most B/S/H/ built dishwashers ( that means Bosch, Thermador, Siemens and Gaggenau ). To Enable or Disable the Cycle Completion Signal... 1. Open the door, hold down the ?Quick Wash? button and simultaneously turn the Dishwasher on. The ?Quick Wash? light will blink (program mode). 2. While the light is still blinking, push the ?Quick Wash? button. ? If the machine beeps, then the Cycle Completion Signal has been enabled. ? When you push the button again and it doesn?t beep, it means that the Cycle Completion Signal has been disabled. 3. Turn the Dishwasher off to take it out of program mode. I hope this answer's your question. Thank you for choosing "fixya". Please rate the solution favorably if indeed it was helpful, if not please let me know. Good luck. macmarkus :)
Jul 13, 2010 | Bosch 24 in. SHV4303 Built-in Dishwasher
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 15912 Built-in Dishwasher
Whirlpl Dshwshr Control Lock light went on/Reg Cycle won't work
Hold the air dry button for 4 seconds. My son just fixed mine with the same problem.
Apr 07, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
Dishwasher not completing the programed wash, Now won't restart.
There is not a reset button, but you can try by holding both drain and one of the wash cycle.. hold it for a few seconds.. keeping trying drain and another, and another.... you will hear drain motor draining water out... if there is standing water at the bottom... if the cycle stopped after wash cycle, its usually your control... hope this help...
Jan 11, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Unable to reset wash program
Press and hold the start/stop button for a few seconds.
Nov 25, 2008 | Asko 24 in. D3112 Free-Standing Dishwasher
Wash cycle
momrules, it could vary depending on the water entering the dishwasher. On a heavy cycle normal time is about 85 minutes not including thermal holds ( pauses that heat the water). On a normal wash, 68 to 75 minutes not including thermal holds. If the water entering the dishwasher is not at least 120 to 140 degrees the dishwasher will pause in cycles to heat the water before advancing. So 120 minutes is not unrealistic. The heaters in the dishwasher are low wattage and will only heat the water approx. 2 degrees every 5 minutes. Catriver.
Nov 30, 2007 | Kenmore 24 in. 17512 Built-in Dishwasher
Certain cycles do not operate
YOU JUST NEED TO REPLACE YOUR TIMER NOT AS EXPENSIVE AS A NEW DISHWASHER
Nov 08, 2006 | Frigidaire 24 in. PLD2850 Built-in...
Maytag 24 in. MDB7600A Jetclean® II Built-in Dishwasher Logo
70 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
