Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Fisher and Paykel Intuitive Eco Washing Machine
Hi, my washing machine is showing fault 37 and there was a slight burning smell in the laundry. Just wanting to know what's wrong as i can't locate the instructions. Thanks. Rachel
  • 27 Answers
The drain pump is overheating. I suggest you do not try to use the machine until you replace the pump unit, failure to stop using the machine will result in the pump short circuiting and destroying the main control board!. Please go buy a new pump and fit it.
Posted on Sep 23, 2008
Fisher Paykel Intuitive Eco Washer IWL12 fault code 37
Pump Ohms to low will smell like burning enamal
The pump will need replacing,
Apr 06, 2013 | Fisher and Paykel Washing Machines
Code 37 -
To my knowledge, Error Code 37 on a Fisher & Paykel machine refers to "drain fault" which could either mean that the drain valve will not open or that the drain pump will not run. The easiest user intervention that could be performed is to check for any blockage/clog at the drain filter, drain pipe, drain pump impeller and drain valve.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 16, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
My washing machine IW812 has fault code 37.Could explain what that is please?
pump block error remove pump check foranything blocking or jamming it it that fails replace pump
Nov 07, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
We have a fisher and paykel intuitive eco, which says code 37,
Hi just read your posting.Now ERROR CODE 37 means PUMP BLOCK ERROR.Is your machine draining any of the water out of it?Please reply with additional information on the question and I am sure I can help you rectify this fault.Looking forward to your reply.
Aug 17, 2010 | Fisher and Paykel Washing Machines
Our Fisher & Paykel Washing Machine is not spinning. It gets to the spin cycle and sits there counting down. The fault code eventually said Service fault 37. What does that mean?
Emptied washer, tipped it on its side, detached drainage pipes underneath, and pulled out old fabric/lint/blockage with tweezers. Plugged in, switched on, all good.
Sep 29, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fault Code 37 Intuitive Washer -
you have a clogged diverter valve, its blue and looks like a Y, it will need to be replaced, if you want call 1-888-936-7872 they can order the part and walk you thru replacing it
Jul 04, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
IW712- fisher paykel intuitive eco.
I BELIEVE THAT IS A ROTOR SENSOR ERROR
REPLACE THE ROTOR SENSOR
Feb 15, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and paykel intuitive Eco. FAULT 136
blocked pump scoop the water out and remove pump from underneath just clicks out move the white plastic clip
Washing Machines Logo
510 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
