Question about Kirby Vacuums
The right front wheel came off my G6 Kirby vacuum, then the entire axle and wheel adjustment came loose--including a spring that was attached to something.
Thank heavens for a husband who can fix anything--and save me a lot of money for repairs and advice!
Posted on Sep 23, 2008
The wheels fell off.
The wheels are held to the axles with small c-clips. Perhaps these have come loose. If the wheel is still attached to part of the axle. The axle has broken and will need replacement.
Jan 08, 2011 | Kirby Ultimate G Bagged Upright Vacuum
My rear wheels keep poppping off. I've hammered and glued, but they won't stay on. Do I need new wheels or a new axle assembly?
Greetings,
You may need to just purchase the the little c-clips that hold the wheels onto the axle. Kirby Vacuums actually have a hub cap on their rear wheels that can be removed to access the axle end with the c-clip. If you take a flat head screwdriver, and pry off the plastic part of the wheel off of the rubber part, you should be able to see the end of the axle. There should be a little tiny c-clip at the end of the axle that holds the rear wheel in place. Is that clip there on both sides?
If yes, then you may need to replace the entire axle assembly. If they are missing these clips are available for purchase through many online websites including our own, govacuum.com.
If this repair didn't fix your Kirby, please contact me, I'm happy to try and diagnosis this further with you. If it did help, please rate the repair as helpful, thank you.
Chris J.
Mar 13, 2010 | Kirby Ultimate G Bagged Upright Vacuum
How do i attach the shampooer to my g6 kirby
Greetings,
Here's an easy to understand and follow video review on how to attach the carpet shampooer to the Kirby Generation 6 (G6). The model that's being used in this video is a little newer model, the Sentria, but the procedure to attach the carpet cleaning attachment is the same exact repair on the Sentria as it is on your Kirby G6 vacuum.
I hope this helps!
http://kirbywhq.powweb.com/videos/Carpet_Shampoo.mov
If that helped, please be kind and rate the video as helpful by clicking on the Thumbs Up Icon below. If you have any questions about how to install it, please just request a repair clarification and I'll be more then happy to help you.
Thanks for watching!
Chris J.
Jan 18, 2010 | Kirby G6 Bagged Upright Vacuum
Replace wheel axle on my kirby g3 vacuum. have a
The spring goes inside that pedal that you step on to advance the height. Place that spring in that pedal and then place the pedal into its' groove, then put the axile and wheel assembly over the pedal and put your screws back into the mounting sections.
Dec 31, 2009 | Kirby Vacuums
Right wheel slips off on Kirby Gsix . How do I fix it?
The shaft is held onto the machine with two little metal pieces on the bottom of the Kirby. They are held on with screws. The rear wheels are held onto the shaft with a little tiny "c" clip.
Marci
Jun 13, 2009 | Kirby G6 Bagged Upright Vacuum
Can NOT get Kirby G6 shampooer system lowered to use
take the attachments off and see if you can lower it then..if so .lower the vacuum and put the attachmens on then try
Apr 11, 2009 | Kirby G6 Bagged Upright Vacuum
The back wheel came off and i went to put it back on and the other wheel that connects to the mechinism/gear height ajustment that goes up/down with a spring in it came off as well. i have been looking for...
You do not need schematics, it is fairly easy. Clean and lubricate the teeth on the inside of the front wheel shaft assembly. Insert the spring into small pedal and place the pedal designated opening on the Kirby front fan casing with teeth facing out. Then take the wheel shaft assembly and put it over those teeth and onto the fan casing. Use two clamps and 2 screws to attach the shaft to the fan case. Need any parts - go HERE.
Good Luck,
Rocky
Apr 05, 2009 | Kirby G6 Bagged Upright Vacuum
Axle bracket problem
You can find parts HERE. I do not think you need new "Ratchet Lock Assm." unles yu lost it (I have never seen one broken). Make sure you have the Spring and lubricate it well (do not use liquid lubricants as they will leak on the carpet).
God Luck
Mar 01, 2009 | Kirby G6 Bagged Upright Vacuum
Replacing spring in wheel height adjustment
I just solved the problem. Go to this website: http://www.completevac.com/kirby_schemo_5.html
It will show you where the spring goes (left side inside the ratchet - when you remove the ratchet you will see that it is hollow. That's where the spring goes!) and a good picture of that assembly
Jul 30, 2008 | Kirby G6 Bagged Upright Vacuum
Vacuums Logo
276 people viewed this question
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Roger Potts
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
