Question about GE Washing Machines
Washer is a top load set it hot water and starts with hot and then will go cold willnot stay on hot G E Profile ,model wwa8350g
    Genius:
  • 1,028 Answers
Most new washers sense water temp and will try to adj final tub water temp by alternately running cold or hot as needed ..most hot settings are not faucet temp but a predetermined temp so if your hot water is 140 degrees coming in the control will switch the cold on to bring final tub water temp down to preset ..which could be as low as 100 degrees the industry's way of energy conservation
Posted on Sep 24, 2008
Whirlpool model WTW5310VQO
i've found problems with the temp. switch on this washer part number W10184148 and it's around 40 dollars,also on the rinse cycle the washer only uses cold water.what happens when you use just the hot?i had a lady that her water would start to fill and then the water would stop and the pipes in the house would start making a banging sound.if you order the part from http://www.repairclinic.com/PartDetail/Switch/W10184148/1468990 repair clinic and if this isn't your problem which i think it is from how you discribe it you can send the part back and get your money back for up to a year.good luck with your washer and next time you buy something and it doesn't work right get right on it
Mar 14, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Do the profile washers have a inlet filter for cold water.Hot water comes in fine.Cold very slow
check the cold water hose the screen in the hose to the cold water,selenoid may be clogged or have hard water deposets,just clean out see if this helps
Jul 03, 2010 | GE Profile WPRE6100G Top Load Washer
Water comes out verryy slowly when using cold wash GE large capcity washer
check the fill hose washer located in the washer cold water fill hose,they get clogged with lime and such,and when you replace the washer run hot water thru the hose to clean it out thoroughly,
Apr 24, 2010 | GE Profile WPRE6100G Top Load Washer
I can't set my Neptune washer temperature to cold water wash. I press the HAND WASH button which originally used cold water but now it stays on hot water (highest temperature setting). the arrows where you...
you need to call your parts store or the factory number in your book,give the model and serial number to them and order the console,the touch pad is damaged and they sell you the whole top console on the washer
Feb 19, 2010 | Maytag Neptune MAH5500B Front Load Washer
GE Profile Top loading Washer Model # WSSR3120W1WW ---
The water diverter could be plugged. or the diverters solinoid has gone bad on the hotwater side. It is located on the diverter itself.
Feb 10, 2009 | GE Profile WPRE6100G Top Load Washer
GE washer won't fill with cold water
Cold water pipe had become frozen. FYI this model of washer has a nice feature whereas you can test each component i.e. valves, by setting the timer and reading the LED's on the front panel. Instructions are in the schematic.
Jan 17, 2009 | GE Profile WPRE6100G Top Load Washer
No Cold Water
THE SOLENOID VAVLE IS DEFECTIVE,NEED TO REPLACE IT, ITS WERE THE HOT AND COLD HOSES CONNECT TO BEHIND THE WASHER WERE YOU CLEANED THE SCREEN. NEED TO TAKE IT OUT AND REPLACE. ITS A ONE PIECE IT SHOULD BE RED OR BLUE OR SUMTHIN LIKE THAT.
GET THE MODEL NO AND SERIAL NO AND SOURCE AROUND FOR A REPLACEMENT PART. ALWAYS GO WITH THE ORIGINAL PARTS SO IT WOULD LAST LONGER, THEN TO MODIFY AND COST YOU MORE MONEY, WHEN IT SHOULDNT.
Oct 05, 2008 | GE Profile WPRE6100G Top Load Washer
Maytag washer
It sounds like you have the hot and cold water lines to the washer reversed.  Try turning off the tap for the hot water then setting the washer to just cold wash and then  hot washif you get nothing on the cold and cold water when set to hot they are probably reversed.  Typically if the auto-temp control is broken you will only get hot or cold coming out on any setting.
Oct 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Water fill temp.
check to make sure that your hot water isn't connected to the cold side this is the number one cause for your problem all washers rinse in cold so if you switch to and its hot cold then your hose is on the wrong valve just switch the fill hoses see if that don't fix it
Mar 27, 2008 | GE WBSE3120B Top Load Washer
Washing Machines Logo
116 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
