Question about Electronics - Others
Mad dog megavault install
I have just bought the 2.5 inch aluminum surround for my 40 gig hard drive that I pulled out of a laptop that no longer works. I have a xp emachine that im trying to connect it to. I got to START, CONTROL PANEL, ADMINISTRATIVE TOOLS, COMPUTER MANAGEMENT, AND DISK MANAGEMENT. At this point i can't get the new disk wizard to come up. can you help me?
  • 75 Answers
Maybe the connection is wrong chk it out...
Posted on Sep 23, 2008
Need manual for mad dog multimedia external wiring harnness
Unfortunately, Mad Dog Multimedia went out of business years ago, and no longer provide support services or documentation for any of their products.
Unless you can find another one of these external drive cases on a sale rack somewhere, or being sold used by an individual, your chances of finding the original manual are extremely slim.
May 03, 2011 | Mad Dog Multimedia USB 2.0 External Drive...
My Mad Dog external hard drive does not show up as a drive. How do I get this to show so I can access my information.
Connect it to a different computer, to see if the device is working at all.
If not, and if the Mad Dog is still under warranty, then exercise the warranty to get it repaired/replaced.
Otherwise, disassemble the casing, remove the disk-drive,
and connect the disk-drive as a "slave" disk-drive in a desktop computer, to see if the disk-drive is OK. This would imply that the USB-to-disk-drive interface inside the casing is the problem.
Aug 18, 2010 | Mad Dog Multimedia MegaVault USB 2.0...
Model md-aen350com not found
Sometimes the drives pull too much current to start. I understand that it worked in the other caes, but the electronics in this case may be pulling more.
Usually they come with a two-headed USB connector. Try putting the single end in the drive and use two USB ports on the other end. This doubles the current available to the drive.
Dec 22, 2009 | Mad Dog Multimedia MegaVault USB 2.0...
1TB WD essentials external harddrive timing out.
Well, never mind then. A simple usb port swap did the trick. Always something simple...
Sep 04, 2009 | Computers & Internet
Installed a 500G hard drive in the 3.5" enclosure. It doesn't recognize it as a hard drive. How do I fix?
Make sure that your HD was installed properly in enclosure. Remove the cable then atached again.
Aug 20, 2009 | Mad Dog Multimedia MegaVault USB 2.0...
Replace hard drive but can't load tablet operating system
I am pretty sure you need the Wacom Digitizer drivers. I have posted a link directly to the downloads section for your laptop/tablet. You should be able to get what you need there.
If this post helps you please RATE my solution.
May 04, 2009 | Sony VAIO VGN-FS660W Notebook
Hard drive from gateway solo pro 40 gig will it work in toshiba
I'm pretty sure it will. The only thing is that Gateways of that generationn used a custom connector which plugs onto the hard disks standard IDE / ATA connector.Just pull this extra connector off and you can use the disk in any machine.
Also ,Toshiba used similar adapters,so if Toshiba's using one on your model,then you'll need to palce the toshiba adapter onto the hard disk from your Gateway. You may also have to go into your BIOS ,and make sure the BIOS recognizes the disk if your BIOS isn't already set to "auto detect".
Mar 28, 2009 | Gateway Solo 9300 Series (5501056) Plug-In...
Enclosure does not read any hard drive.
The drive may need to be formatted. The manual that comes with the enclosure has instructions how to do this with a variety of OS's.
Nov 11, 2008 | Mad Dog Multimedia Computers & Internet
Mad Dog Hard Drive - Immediate Help
The grand majority of these external hard drives can't withstand being dropped from 3 inches, and some can't be dropped 1/2 inch. In other words, to retrieve your data, you will have to send it to a specialist, who will charge you between $300 to $1500 to get the data, with no guarantees. What a deal. I had a Fantom 120 gb, my dog knocked it over, and by by data. The fact that it is making noises means it has been knocked out of kilter. Try calling them with your warranty, but I bet it won't cover it. The whole industry is a big ripoff, as they do not warn you that you can lose everything at the drop of a hat (as it were). Only one company guarantees a drop of 7 feet that I know of. Better off to back up your data using an online secure system. Some cost only $4.95/month. Sorry.
Mar 24, 2008 | Mad Dog Multimedia Dominator...
Electronics - Others Logo
98 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
