Question about Belkin (F5D5231-4) Router
Networking to desktop computers
Hi i can get on line with both computers but i cant share files or see the other computer from the other computer the main computer is running vista and the outher is running windowsxp
  • 928 Answers
You may follow the link below to set this up. In case you need further assistance you may message me directly.
http://technet.microsoft.com/en-us/library/bb727037.aspx
Posted on Sep 23, 2008
  • Thomas Lim
    Thomas Lim Sep 24, 2008
    May i ask why the rating of TFT only? May I ask why it did not work?
Purchased a gigaware cat5e crossover network cable to transfer files from one older computer to a new one. Cant get it to tranfer info.
So that you will be able to transfer your file from one PC to the other you have to share your folder first.
1. Share your folder in your old computer. Right click the folder then click Properties and Choose Sharing Tab. Check Share this folder (For windows 7 or vista you have to click Advance sharing button first) 2. Open your explorer from the other computer and Choose Network. Now, you should see the shared folder where your files are. Then start copying the files to your new computer.
*Note: you can also delete the files from the other computer by setting permission of the folder properties.
regards
Apr 02, 2011 | Computers & Internet
Have Desktop & Laptop that use the same Router & Modeum to access the Internet with no trouble, However I cannot get the 2 computers to talk to each other,ie, cannot view file or transfer file from...
Hi, If you want to share files on both computers, you need to check the shared folders option on both version of the operating system. You can right-click on the folder you want to share then choose properties and choose shared option to check both settings. On windows 7, you have to go to Network and Sharing Center to check the setting on your option. you have to to turn on the sharing options and also if there is a password on both computer when you log on , that would be the username and password you need to share the documents.
Thank you for using Fixya, your recommendation is highly appreciated for the free support.
Oct 09, 2010 | Acer Computers & Internet
Is it possible to connect my ASUS X58C laptop to a Win98SE pc
Connect the two computers using the Ethernet crossover cable.
On the computer running Windows Vista, from the Start menu, click Control Panel. Then, double-click Network and Sharing Center. Note: If this doesn't match what you see, switch yorur control panel to classic view..
At the top of the main portion of the Network and Sharing Center window, double-click the Unidentified Network icon.
If network discovery and file sharing are disabled, the following message will appear:
"Network discovery and file sharing are turned off. Network computers and devices are not visible. Click to change..."
Click the message to enable network discovery and file sharing; you may be prompted for an administrator username and/or password.
In the dialog box that opens, select No, make the network that I am connected to a private network. This allows you to initiate file sharing on the two computers without affecting the settings for any other networks.
Icons for both computers should now be visible in the Network window. Double-click a computer icon to share printers and other resources.
Mar 28, 2010 | Computers & Internet
My Advent 4211 netbook connects wirelessly to the Internet through my Desktop and a Belkin router. How do I allow the netbook to see the files in the desktop?
if you ran your network wizard to get the internet access shared then you should be able to share your files too.
and folders the same way ,
go to my network device,
veiw network computers,
if you can see the computers desk top then
go to Shared folders and try to see if your folders have been shared open something.
If you can see the desktop and not open the shared folders then run the network wizard again,shutdown and restart,to save your settings,
to share files between both machines you will need to drag the file into my shared folders or rightclick on the file your sharing and click on sharing,follow the prompts to share and that should fix your problem.
Please rate me thanks MISTERDJ
Aug 16, 2009 | Advent 4211c Notebook
Windows Vista
In the start menu click network,on the bar on top click network and sharing center,scroll down and enable network discovery.
Apr 20, 2009 | Microsoft Windows Vista Ultimate Edition
I am trying to set a network using a wired desktop and a wireless laptop (desktop using XP and laptop using Vista)I am using a Linksys WRT160N, I can get on the internet with no issues at all but when...
in the router's lan (not wan) configuration - set the dhcp server (gateway address) to be 10.1.10.1. Then set the addresses of the clients (connected to the router) to be assigned addresses from 10.1.10.10 - 10.1.10.20. Set the desktop's TCP/IP address to be 10.1.10.11 (static) with a subnet of 255.255.255.0, and a gateway address of 10.1.10.1. Set the laptop's wireless connection (TCP/IP adapter) to have a static 10.1.10.12 address with same subnet mask and gateway address of desktop. Change the workgroup on both computers to be of the same name (case sensitive here) to a name such as HOMENETWORK. Then on each computer, open up "My Computer" and right click on folders, files or printers that you want to share on your network!
Sep 26, 2008 | Computers & Internet
Making a shared folder
Go to this site http://fhctech.org/fhc/networking/xp-sharing-folder.htm for winxp or
http://kb.iu.edu/data/ahrs.html For win2000
http://www.maximumpcguides.com/share-a-folder-in-windows-vista/ for vista
Hope this helps if not please specify the Operating system of your computer
Sep 17, 2008 | Computers & Internet
To share files on network using xp, but only allow certain users over the network from several computers to have acceess to certain files. looking for a user and password prompt to access certain shared...
only the administrator has the access for sharing files on network if you are the administartor on the computer you will be able to share any files If you are working in a corporate enviornment you will have to seek permission to share files hope this solution helps you
Aug 14, 2008 | Computers & Internet
Computer sharing
Initially, I would suggest that you:
1. Make both members of the same workgroup;
2. verify that the Subnet Mask are identical to both PCs in their networking configuration; and
3. verify that the Folder or files are shared by viewing the folder or files properties making making sure that there is a check mark on "Share this folder on the network and/or "Allow network users to change my files".
Should the above be not corrective of your concern, pls post back.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 09, 2008 | Computers & Internet
Help please....printer name does NOT appear
You must have a network set up, and you must enable file and printer sharing on the desktop. The laptop and the desktop should be in the same workgroup. Some firewalls will cause this problem.
Start with the network setup wizard in Settings/Network.
Jan 25, 2008 | D-Link NETWORK CARD DFE550TXREF Network...
Belkin (F5D5231-4) Router Logo
18 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
