Question about Samsung HLR5067WX 50" Rear Projection HDTV
Samsung hdtv hums
Last saturday my samsung hdtv started to hum. I looked into the set because I saw a small fan on the back left that was not running. It looks like this is on a temperature switch. The hum is coming from the center where the fan is located. the tv is a samsung 5067 series
  • 1 more comment
  • Chris Gibbons Sep 24, 2008
    I do not get any of the fan error messages. I do not know that the fan is the source of the noise. Do you have any other suggestions? I had previously disconnected all the cables opened the back and cleaned the set, left it for thirty minutes.
    answer number 2 was dumb.
    Yes, it was helpful and convinced me that it is the correct problem. It also convinced me to do it myself. Thanks for your direction.
    Sergeant:
  • 208 Answers
To be frank, the buzzing problem is common in these type of TVs........
The reason might be as you said , due to the coolant fan may have been stuck. The Fan might have been lost its bearings.
But the fan inside the HDTV will not run continuosly. It will run only when needed(i.e, during overheat)
So you need to look into that quickly, becoz if the fan had failed, then it may lead to future problems due to overheating.
Try these too,
You may have a ground loop problem.
Are you using three prong plugs in all your outlets on that particular circuit?
You should try having only the TV plugged in and see if the buzzing is gone.
Then reconnect items one by one to discover what is causing the problem.
One more idea.
What new electronic appliance have you added at the same time the buzzing began?
A refrigerator?
Or anything else that runs constantly, including an electronic alarm clock, digital clocks, think of anything.
And is the buzzing increases with the display brightness?
If that is the case your power supply will be the problem..........'
Hope my info helps you,
Thanx for using fixya,
CHeers.
Waiting for your response.....
Posted on Sep 29, 2008
  • 790 Answers
Hi
replace the fan, and much better to call a qualified technician to assist you!
Thanks!
Likha
Posted on Sep 23, 2008
    Novelist:
    Champion:
  • 203 Answers
This is almost always the color wheel that causes the noise. I have never seen a fan cause the noise at all. If you would like to replace the color wheel its a pretty straight forward process. you will first need to order one. i would reccomend partstore.com Once you get it let me know and I will email you the directions on how to change it. If you dont feel comforetable doing it youself you can always call a repairman but he will charge $400-$600 depending on your area. Let me know what you want to do!
Tim Nolan
Experttv@comcast.net
  • experttv
    experttv Sep 24, 2008
    Yes, its the colorwheel
    Genius:
  • 2,035 Answers
You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 2 hours and let the tv cool and replug to AC power and redo the cabling. Switch on the TV and see if it works..if the fan does not run then you may need to replace the fan as its vital part which cools the tv part ,to fix this issue....
And use his link to replace the cooling fan....
http://www.jangro.com/a/2006/09/29/samsung-dlp-how-to-replace-fan-2/
Good luck...
I hear the fan almost non stop while the tv is on.
You have a bad color wheel. The color wheel is located in front of the lamp, as the light shines through it as it spins. It is made up of different colored segments of glass, and one of the segments has came loose and causing the vibrating humming noise. The reason I know it isn't a fan is because the fans will continue to run for about 30 seconds after the set is powered off. The click you hear is the relay cutting off the fans. The color wheel cuts off as soon as you press the power button to cut the set off. I've replaced many of these at our shop for the same problem.
Jul 29, 2010 | Samsung HC-P4752W 47" Rear Projection...
After 10 sec. After start up the tv starts to make a large growling sound for about 5 secs. Then repeats every 15 sec. Sounds like if might be a fan. How many fans in this t.v. . Took the back cover off...
there's 3 fans. 1 by the video board. 1 in the middle of the set infront of the heatsink and 1 behind the lamp. make sure all 3 fans are running and put your ears by them to check. if all of them are running the sound might be coming from your colorwheel. If it sounds like a loud whinning/humming or buzzing noise then more then likely its your colorwheel. Let me know what you find and please rate me. Thanks
May 15, 2010 | Samsung HLR5067WX 50" Rear Projection HDTV
Humming noise when turned on
It is very possible that it is the fan you are hearing. They run constantly running, and their bearings tend to overheat casing a hum noise.
Jun 22, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung ldp 46 " replaced lamp humming sound fans cleaned and working set continues to turn off every 20 min or so
Humming problem with a Samsung DLP HL-P5063W
picture displays good
Humming randomly starts, but once it starts it hums
May 31, 2009 | Samsung DLP HL-P5663W 56" TV
The fan hums constantly. Does this mean that
When Fan start giving noise then it needs to be replaced.
Apr 24, 2009 | Samsung HL-S5086W 50" HDTV
Humming noise
There are only two moving parts in this set. The fans and the color wheel. Typically when the color wheel starts to break or go on the fritz, the tv stops working. Count your blessings you've still got the picture. Open the back and turn the tv on. The color wheel is located on the optics block tray. The fans are very visible with the back off. Stop the fan for a second and see if the sound goes away. If not, you might want to start looking around for a replacement color wheel. Rivervalleyelectronics.net is a good place to start. Sometimes Discountmerchant.com carries them too. Be aware that there two different wheels available. If the fan is the culprit of your problem. Radioshack will likely have a replacement for you. If you need further help, post a comment or email me and I'll send you pictures of what to look for. Cfoley@hawaii.rr.com
Good luck.
Mar 21, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Tv makes a humming noise
check for bad color wheel....may sould like a grinding sound
Mar 01, 2009 | Samsung HC-P4752W 47" Rear Projection...
Humming noise from tv
Yes a humming noise on that model is usually related to the color wheel It will get progressively louder
Jan 17, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Loud Humming Noise
Samsung is notorious for having the motor on the color wheel burn out. If the color on the tv starts to fade or shift tones when the rev'ing or noise is happening then you'll know its the color wheel. There are only two moving parts in this set, the color wheel and the fans. If you're smelling something, it could be either. Take the back off the set and put a piece of tape on the lamp door switch and turn the set on. Try to pinpoint the source of the noise. If its a fan, no big deal, Radio shack should have a replacement. If it sounds like its comming from under the set, dig a little deeper and try unhooking the color wheel motor, not as easy as I am making it sound but either way the fan is about $20 to fix and the color wheel is about $100. Sure beats a $400 tech bill. If you get stuck, comment back and I'll send pictures of the dismantle.
Nov 28, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Sporadic Hum on HLP4663W
I would guess that its the fan for the lamp, as the color wheel will power down as soon as the power is cut. the cooling fans will continue to run
Jun 12, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLR5067WX 50" Rear Projection HDTV Logo
98 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
