Question about HP DeskJet D2560 InkJet Printer
Ink cartridge error
Un able to print in PC always indicate cartridge error but when i try to print itself they print, how can i solve the problem? or how can disable the inklow level indicator from printer itself.
thanks & god bless!
  • nbuluran Sep 23, 2008
    nothing follow just only that problem!
Download a software named REG CLEANER GO TO STARTUP OPTION AND DEL ALL ITEM RELATED TO YOUR HP PRINTER.THEN U WILL GET RID TO THIS PROBLEM.
HOPE THIS WORK IF IT SAY THANKS TO ME MY IS GAURAV1693@YAHOO.COM
Posted on Apr 11, 2009
Canon troubleshooting
Hi Nolan,
Error code 5200 indicates that print head temperature error occurs. This error usually occurs in case of ink low or third party or refill ink usage.
I hope the following link will answer your question clearly. :)
Canon Printer Error 5200
Jan 11, 2014 | Office Equipment & Supplies
My lexmark x3470 wont recognise compatible ink Cartridges any know of a way round this
If the ink cartridges you purchased are not Lexmark - that could be the problem. I used to have a Lexmark printer and I did the same thing - I purchased ink cartridges that were compatible but not Lexmark brand. Everything seemed fine until I tried to print and then I would get the same error sign and low ink message and it would not print. I kept thinking I was doing something else wrong and tried everything. In the end I broke down and got ink cartridges from Lexmark and that solved the problem. Now I have a Brother printer and I never buy anything other than Brother ink cartridges because I'm always afraid of that same thing happening again. I wish I knew which printers WOULD accept those non name brand ink cartridges, but thus far I do not know of any printers that do. Hope this helps you.
Mar 24, 2012 | Lexmark X3470 All-In-One InkJet Printer
I just inserted a black PG 40 ink cart and theres an error coed 5 indicating that i need to insert a color cart. i set my ink stat to black only and gray scale and it still wont pint
I think you need to have both cartridges in your printer in order to print. If you have put the PG-40 only, the printer can't connect the electric circuit and won't work. Canon's manual explains the error code: the ink cartridges are not installed, or a non supported ink cartridge is installed or the ink cartridges are not installed properly.
So, my guess is either to pop in a Cl-41 and print or, if both cartridges are in, remove them from the printer and gently clean the electric circuit on them with a dry cloth. You can also clean the cartridge carrier. Put the cartridges back in and try printing. If that doesn't work, try holding the "resume" button (triangle in circle) for about 10 sec for each cartridge, that should reset them.
Hope that will help solve your problem!
Apr 16, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Incompatible print cartridge
Take out the print cartridge. Clean the points on the cartridge with cotton swab and try using it again.
Nov 04, 2009 | HP Photosmart C4480 All-In-One InkJet...
Canon i550 LED error sequence: 7 orange +1 green flash
According to Canon 7 orange flashes indicates a print head fault. Solution they recommend is to take it to one of their service agents. Problem is that replacement print heads are not cheap and it is usually more economical to replace the printer. You could try taking the print head to a cartridge refiller and have it professionally cleaned (cost you nothing or next to nothing) and see if that solves the problem.
Sep 19, 2009 | Canon BubbleJet i550 InkJet Printer
Not printing black anymore
The link level display doesn't always show the correct information. To begin, try to wet the part where the ink flows, with a damp paper towel or just a towel. Sometimes the ink just dry up. If that does not work, you probably need another black ink. If there was a problem with the printer itself you would had been notify by the computer, you know, like a pop up window.
Sep 01, 2009 | HP DeskJet F380 All-In-One Printer
Wont print with all new ink cartridges
If the error message is only "magenta/cyan low", it doesn't cause any error. The low message stays after replacing ink cartridges if they're replaced too early (before they're indicated as actually empty), it doesn't cause the printer to not work.
However, some other problem might be faulty, or there might be another error message. Try emptying printer queue and print from Ink Management -> Menu/set (twice) to check wether the problem is with communication from pc or if the printer actually is unable to print.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Compatibility of Ink cartidge.
The MP600 does not use the 40 or 41 cartridges, it uses individual color (and black) ink tanks. But other models (MP190, MP460, MP470, etc) do use these cartridges. The error message you are receiving indicates that the printer does not recognize the cartridge you installed as a valid black ink cartridge. This can mean that either the cartridge is faulty, or that the printer has a problem.
I would suggest trying another new cartridge, and if you still get the same error, to contact Canon for support options if the unit is still in warranty.
Oct 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
"Cartridge Error" Cartridge on right must be replaced
I had the same problem. The only difference is that I decided to try using an XL cartridge to save money on ink. This is what caused my error message. After exchanging the XL and replacing it with the regular size cartridge the error message went away.
Oct 06, 2008 | HP Officejet J5780 All-In-One InkJet...
HP DeskJet D2560 InkJet Printer Logo
184 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
