Question about Toshiba Televison & Video
No sound Hello, I am in desperate need of help to figure out why I have no volume on my TV. Sometimes when I first turn the tv on there is sound for a brief moment and then no sound. Do you have any suggestions on how I can fix this problem? This just started happening a day ago. Thank you, Jamie
  • 4,234 Answers
This could be as simple as a bad solder connection or a defective audio output IC. Can you post the model number please?
Thanks,
Dan
Posted on Sep 23, 2008
Volume on tv is shut off
It may have been set in to mute mode, check it out through your remote. If you have done this and found that it is not, it may be on the cables.
Pull out all cable that is connected and pull it in again one by one and try to hear if sound is being restored.
Oct 23, 2012 | Mitsubishi VS-70803 70 in. Rear Projection...
Everytime I try to change the volume on my samsung it says "not available" in the middle of my screen. How should I fix this? Also I just had white spots on my tv and the technician came and...
Hello... Your TV speakers are turned off. If you don't have a sound bar or a surround sound system, go into the TV menu, audio, speaker settings and turn them on. If you have a sound bar or surround sound system, use the remote for that system to adjust the volume. I hope this helps!
Nov 25, 2017 | Samsung 46 in. Flat-Panel LCD HDTV
Volume fades out then may come back on-Proscan TV Model#PS35690LW
hello,
this will require you opening the back cover of the television.
Check for dry soldering and re solder in the audio section of the printed circuit board....
Good luck...
May 24, 2010 | Televison & Video
We have the stereo hooked up to the dynex 42'' tv, as we did our other tv, we can not mute the complete sound and also sometimes we cant turn the volume up and down whats going on?
Since you have it hooked up to the stereo system, you need to go to on screen audio set up and turn off the TV built-in speakers (you will be listening the TV sound through your stereo system speakers), then go to the audio output set up and set it to 'variable' so the audio output of the TV's RCA audio out put will vary with the volume control of the TV (not all TV will alow this function), you will need to set the stereo volume to certain level (around 9~10 O'clock setting) since the sound coming from the TV will be controlled by the TV remote volume control. You can otherwise set the TV output to be at 'fixed' level, which means the sound output of the TV will not be controlled by the TV remote volume control, you will use the stereo remote volume control to adjust the sound level instead. I hope this is clear to you.
Nov 19, 2009 | Dynex DX-L42-10A 42 in. LCD TV
Samsung TV - have sound/auto volume set to on. When TV is turned off and then on, tv volume is extremely low. Go back to sound menu, it shows "on" but if you go back and act like you are turning in on, the...
Hello Blindrid,
What I would suggest you do is Press your MENU button on the tv remote, Then down to SOUND and then Turn the AUTO VOLUME to OFF. Then come out of the menu screen.
Just to check that it has all work correctly. turn you volume upto a certain number for example 25
Then turn your TV off the turn it back on. Wait until it is displaying a picture then press the volume button Once either up or down and you should see that it will go to 24 or 26 depending on what button you pressed for the volume. This will keep your volume set to whatever you had it on before you turned the tv off.
Hope this Helps Please leave a thumbs up.
Cheers
Little Dish Fitter
Oct 06, 2009 | LG 37LG30 37 in. LCD HDTV
I have an onyko receiver tx ds 575 the sound from my tv to receiver to speaker is very low can't figure out why need help thanks
have you ckeck the tv config??
sometimes u need to select in the tv menu, in audio option to have continue output, otherwise when you turn the volume up in the tv the amplifiers sounds more, have you try this??
or check the cable maybe is damaged.
Good Luck
Jan 10, 2009 | Onkyo TX-DS575 Receiver
Volume makes a cracking noise. sometimes there is no volume,so i have to slap the back of tv to get sound back
Hello Sgarmekiss:
That issue sound like you will need to have your small signal board repalced by a repair center.
Aug 14, 2008 | Protron PLTV-32 Television
Emerson LC320EM81 32
i cut the tv on and then it cuts its self off.
Jan 02, 2008 | Televison & Video
Televison & Video Logo
26 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
