The compression driver of a 2 way peavey SP 5Ti Biamable speaker does not function when the cable is plugged into either "normal" jack(there are 2). The tweeter DOES work when the cable in plugged into the "Hi" jack. Is this due to a faulty crossover or a compression driver failing?
  • tntfrly Sep 23, 2008
    Yes, the woofer works.
  • tntfrly Jun 04, 2017
    I've discovered that cleaning the input jacks seems to fix the problem
Although it is not fixed, I agree with your diagnosis of a crossover problem. I removed the compression driver from another speaker, and the problem continues. So its not the driver causing the problem. Must be the cross over. Thanks for the help!
Posted on Sep 23, 2008
  • 4,234 Answers
This is indicative of a crossover problem. Does the woofer work?
Dan
  • ABRsvcs Sep 23, 2008
    If you can remove the crossover section, it may be as simple as a blown fuse. Some of these units have a fast blow fuse for both drivers. Otherwise, you probably have a bad cap.
    Dan
I have a blown tweeter on my SP3 and I want to replace it but I don't know how to get it out of the enclosure?
There are a number of versions of SP-3, but normally you would remove the screws holding the horn into the cabinet, take out the horn and then unscrew the driver from the horn. At that point, either replace the diaphragm on the driver or the whole driver.
Aug 17, 2013 | Peavey New Peavey Sp3 15" 3 Way PA Speaker
How to take the grill off a peavey sp-5
Most versions are obvious, but the newer version where there are no screws on the grill edge require you to remove the bottom plate on the cabinet by taking off the feet and stand adaptor. Once the bottom is off, you'll see the grill is mounted in a slot. With the cabinet on it's back lift and pull the grill and it will slide up and out of the slot.
Jan 25, 2013 | Peavey SP 5 2-Way 15 Speaker
I just purchased 2 old Peavey SP-2 and SP-3 speakers. How do I wire from the crossover to the speakers so the horns and 15's are wired in correct.
These cabinets are self contained and you do not use a crossover with them. The speakers do NOT come out to separate connectors. You just drive these with an amplifier. DO PAY ATTENTION to the power rating... you are safe using an amplifier with a MAXIMUM of 150 Watts RMS per speaker cabinet. More than that and running them loud and you will be replacing the speakers. These will cover a 40 foot square room at comfortable level.
Aug 14, 2011 | Peavey SP2 PA Passive Speaker
Looking for replacement components for my peavey speakers 2 x 15 inch 2 x tweeters 2 x crossovers 2 x horns all above for 15 inch peavey eurosys 4 product 15005760 2 x 12 inch 2 x...
Fixya doesn't do prices or delivery. We only supply information. See the link for spares suppliers including Peavey themselves.
Peavey Replacement Repair Parts, Speakers, and Accessories
https://www.simplyspeakers.com/peavey-speaker-repair-parts.html
Factory replacement Peavey speaker parts, diaphragms, replacement baskets. ... Peavey 1208-8 SPS BWX Factory Speaker Basket, 12" Black Widow, 8 Ohm, 00560770. Peavey SP-15825 Factory Speaker Basket, 15" Scorpion, 8 Ohm, 00015040.
Peavey - Replacement Speakers, Raw Drivers ... - Parts Express
https://www.parts-express.com/brand/peavey/339 Results 1 - 16 of 323 - Welcome to the Peavey Store at Parts Express. Peavey was founded in 1965 and is now one of the best known names in professional audio. With innovative products such as their field replacement baskets, powerful amplifiers and PA speakers they have become a mainstay of musicians around the ...
Speaker Components - Peavey.com
https://peavey.com > Support From the Low Rider™ sub woofers, with incredible power handling capacity and impressive bass response to the steadfast Black Widow® and BWX™ speakers with replacement basket assemblies, the Peavey line of speaker components is consistent and innovative. Think it might be difficult to make up your mind what ...
peavey speaker spares Google Search
Dec 23, 2017 | Audio Players & Recorders
Wish to run sm450v2 Mackie powered speakers thru a Peavey XR8600
The Peavey XR8600 is NOT just an amp, but a powered mixer.
To SAFELY use this with your powered speakers, connect those speakers to the MAIN and MONITOR outputs on the front of the unit with 1/4 inch INSTRUMENT rated cables (NOT speaker cables).
To safely leave the power amps in the XR8600 with no output loads, plug GROUNDING plugs into the POWER AMP 1 and 2 input jacks on the front. This will prevent the power amps in the XR8600 from running with no load which COULD damage them.
Make the grounding plugs from 1/4 inch mono plugs by jumpering the centr aand sleeve terminals of the plug.
Jul 09, 2010 | Peavey Audio Players & Recorders
My JVC SP-PWM508 no longer functions.
I am looking for the cable connecting the sub woofer and the main system(CD Player)
Mar 14, 2010 | JVC SP-PW100 Subwoofer
Peavey Horn Drivers (compression drivers)
Did you sort your problem? I need 2 also, but seems quite easy to get 4ohm but 8 ohm a little harder. The woofer in the cab is 4ohm, cabinet is rated 4ohm so wondering wether to replace th 8ohm horn with a 4ohm diaphram.
Any thoughts?
Thanks.
Nov 26, 2009 | Peavey Audio Players & Recorders
Peavey PV215 Speakers
LIGHT IS PART OF SPEAKER PROTECTION CIRCUIT,CAN BLOW,MINE DID TO PROTECT HIGH FREQ DRIVER
Nov 10, 2007 | Peavey CH1 Speaker
181 people viewed this question
 Grubhead
Grubhead
