Question about Dell Inspiron 1000 Notebook
Windowsxp I have windows xp i want to know what i have to disable to get faster startup ?
  • 928 Answers
Click start then run then type in msconfig
Go to startup. you can basically disable anything that has no relation to the operating system. You can see the ones that are related to the OS are the ones that are in folders C:/Windows...... all others you can run manually. In any case you can play around there since you can restore or put a check on them in case you need them again.
Posted on Sep 23, 2008
How do i make my pc fster
Slow Windows Machine! Try disabling startup programs. Go to Start > Run and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate. Consider increasing RAM.Uninstall any extras like those pushy toolbars, and add-ons.
Dec 06, 2012 | Microsoft Office 2010 Professional 32 64...
Tip
How to make your computer faster
1. Defragment your computer hard disk using free tools like SmartDefrag.
2. You should also defragment your Windows pagefile and registry.
3. Clean up hard drive disk space being taken up by temporary files, the recycle bin, hibernation and more. You can also use a tool like TreeSize to determine what is taking up space on your hard drive.
4. Load up Windows faster by using Startup Delayer, a free program that will speed up the boot time of Windows by delaying the startup of programs.
5. Speaking of startup programs, many of them are useless and can be turned off. Use the MSCONFIG utility to disable startup programs.
6. By default, the size of the paging file is controlled by Windows, which can cause defragmentation. Also, the paging file should be on a different hard drive or partition than the boot partition. Read here on the rules for best paging file performance.
7. In Windows XP and Vista, the Windows Search indexing service is turned on for all local hard drives. Turning off indexing is a simple way to increase performance.
8. If you don’t care about all the fancy visual effects in Windows, you can turn them off by going to Performance Options.
9. You can optimize the Windows boot time using a free program called Bootvis from Microsoft.
10. Clean your registry by removing broken shortcuts, missing shared DLLs, invalid paths, invalid installer references and more. Read about the 10 best and free registry cleaners.
11. One of the main reasons why PC’s are slow is because of spyware. There are many programs to remove spyware including Ad-Aware, Giant Antispyware, SUPERAntiSpyware, and more.
12. If you have a deeper spyware infection that is very hard to remove, you can use HijackThis to remove spyware.
13. Remove unwanted pre-installed software (aka junk software) from your new PC using PC Decrapifier.
14. Disable unnecessary Windows services, settings, and programs that slow down your computer.
15. Tweak Windows XP and tweak Windows Vista settings using free programs
16. Disable UAC (User Account Control) in Windows Vista
17. Tweak your mouse settings so that you can copy and paste faster, scroll faster, navigate quickly while browsing and more. Read here to learn how to tweak your mouse.
18. Delete temporary and unused files on your computer using a free program like CCleaner. It can also fix issues with your registry.
19. Delete your Internet browsing history, temporary Internet files, cookies to free up disk space.
20. Clean out the Windows prefetch folder to improve performance.
21. Disable the XP boot logo to speed up Windows boot time.
22. Reduce the number of fonts that your computer has to load up on startup.
23. Force Windows to unload DLLs from memory to free up RAM.
24. Run DOS programs in separate memory spaces for better performance.
25. Turn off system restore only if you regularly backup your Windows machine using third party software.
26. Move or change the location of your My Documents folder so that it is on a separate partition or hard drive.
27. Turn off default disk performance monitors on Windows XP to increase performance.
28. Speed up boot time by disabling unused ports on your Windows machine.
29. Use Process Lasso to speed up your computer by allowing it to make sure that no one process can completely overtake the CPU.
30. Make icons appear faster while browsing in My Computer by disabling search for network files and printers.
31. Speed up browsing of pictures and videos in Windows Vista by disabling the Vista thumbnails cache.
32. Edit the right-click context menu in Windows XP and Vista and remove unnecessary items to increase display speed.
33. Use the Windows Performance Toolkit and the trace logs to speed up Windows boot time.
34. Speed up your Internet browsing by using an external DNS server such as OpenDNS.
35. Improve Vista performance by using ReadyBoost, a new feature whereby Vista can use the free space on your USB drive as a caching mechanism.
36. If you have a slow Internet connection, you can browse web pages faster using a service called Finch, which converts it into simple text.
37. Use Vista Services Optimizer to disable unnecessary services in Vista safely.
38. Also, check out my list of web accelerators, which are programs that try to prefetch and cache the sites you are going to visit.
39. Speed up Mozilla Firefox by tweaking the configuration settings and by installing an add-on called FasterFox.
40. Learn how to build your own computer with the fastest parts and best hardware.
41. Use a program called TeraCopy to speed up file copying in Windows XP and Vista.
42. Disable automatic Last Access Timestamp to speed up Windows XP.
43. Speed up the Start Menu in Vista by hacking the MenuShowDelay key in the registry.
44. Increase the FileSystem memory cache in Vista to utilize a system with a large amount of RAM.
45. Install more RAM if you are running XP with less than 512 MB or Vista with less than 1 GB of RAM.
46. Shut down XP faster by reducing the wait time to kill hung applications.
47. Make sure that you have selected “Adjust for best performance” on the Performance tab in System Properties.
48. If you are reinstalling Windows, make sure that you partition your hard drives correctly to maximize performance.
49. Use Altiris software virtualization to install all of your programs into a virtual layer that does not affect the registry or system files.
50. Create and install virtual machines for free and install junk program, games, etc into the virtual machines instead of the host operating system. Check out Sun openxVM.
on Apr 06, 2010 | Computers & Internet
Compaq dx2000 mt freezes on startup
Boot into Safe Mode by pressing F8 during boot and...
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Nov 12, 2012 | HP Compaq dx2000 Microtower PC Desktop
How do i free up ram
Crtl-Atl-Del and kill / end any unwanted processes.
Nov 06, 2012 | Microsoft Windows Vista Home Premium for...
Msvcrt.dll error message(Msvcrt.dll error message("the procedure entry except handler4 common could not be located dinamic link library msvcrt.dll")
Two possible solutions.
Roll back system with System Restore. Win 7 - Start > Search type System Restore. XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
Oct 23, 2012 | Microsoft Windows XP Professional
Start up is so slow.what should i do?
There is a lot you can do ... I assume it used to run fairly well? This place is good advice..
http://www.wikihow.com/Make-Windows-XP-Startup-Faster
This is deeper and good too..
http://www.microsoft.com/windowsxp/using/setup/expert/northrup_restoreperf.mspx
Here is a lot of different post by different people. These you need to know a little about to act on..
http://www.softwaretipsandtricks.com/forum/windows-xp/5264-extremely-slow-boot-up-windows-xp.html
Feb 06, 2011 | Computers & Internet
I am trying to reinstall my visioneer 4800 old scanner on my XP. I am told it doesn't find Twain and I do not know how to instll it safely. I think it was uninstalled at a time when the computer was...
Before you install try this.
1. Start -> Click Run
2. Enter msconfig and click ok
3. Click Startup tab
4. Uncheck program that you don't want to startup
You can disable programs that you don't want automatically load when you start your computer. By disabling these programs will help your computer startup faster.
5. Click Ok and restart
Now you should notice that your computer startup faster.
My Hot Tips to Make Your Computer Faster:
* Regularly check your startup folder to prevent malicious programs installed itself without your knowledge.
* Delete the temporary files from Temp folder (Start > Run > %temp% > delete all files).
* Upgrade your RAM to makes your computer boot faster : )
I hope this helps you to make your computer faster..
Sep 16, 2009 | Visioneer 4800 Flatbed Scanner
Diamge Scan II, Error = 5 Windows 2000, Error = 1 on Windows XP
Sep 14, 2009 | Minolta Dimage Scan Dual II Film Scanner
I'm having problems with WindowsXP loading at start-up
I don't think you have a virus, Norton 360 is a very good antivirus program and would have caught it. Try disabling all of the Norton 360 features then load the Windows XP disc. Sometimes anti-virus programs interfere with the processs. I am assuming you have the Windows XP original disc. This should work.
Dec 28, 2008 | HP Compaq Presario SR2011WM PC Desktop
How to make Vista faster?
You can try changing your Windows Theme to a more plain less animations ect..
To do this click on the desktop right-click now click on Personalise and now there are many things you can adjust to improve your computers performance like screen saver settings, wallpaper settings, theme settings and many more.
If your using the theme Vista Aero (with glass effect) then i would recommend you to change the theme to the Vista Basic theme.
The glass effect uses lots of your computers RAM and will slow it down dramatically.
Here is a guide so you can change your theme with example pictures so it's much easyier to understand what to do - http://grok.lsu.edu/Article.aspx?articleId=638
Good luck. Hope my solution was helpful.
Nov 03, 2007 | Microsoft Windows Vista Ultimate Edition
Dell Inspiron 1000 Notebook Logo
21 people viewed this question
Alun Cox
