Question about Maytag SkyBox MBV1976A Beverage Dispenser
Part for starter relay
I need to get a new starter relay that hooks up near the compressor. the repair man said this might be the problem but i am having trouble finding the right part. help
boofa_23@yahoo.com
  • Anonymous Oct 06, 2008
    Mine is shot, too. There is no part number for it.
Same problem here - no one will help - not where I bought it 2 years ago, not the local repair man, not whirlpool
Posted on Oct 20, 2008
Emerson model#CR519B. The unit just stopped working. If plugged in a motor runs for about 8 seconds and clicks off; about a minute later it repeats. Help
I had the same problem with a small wine cooler. It happened to me twice in 6 years. Both times I had to replace the starter relay.
I couldn't find any repair facilities willing to work on these small wine coolers or refrigerators, probably because the bill would be more than the used fridge is worth. If you feel confident around a volt/ohm meter and electricity, you could learn how to test this and maybe fix it yourself.
You shouldn't do any of this if you aren't familiar with using a Volt/Ohm meter and can safely and confidently work around electricity.:
  1. Unplug the fridge
  2. I first tested the compressor with an Ohm Meter (see how with youtube video below or by reading how at Davesrepair.com). It was good, but it kept starting and stopping within a few seconds.
  3. Basically my starter capacitor/relay wasn't working. It supplies temporary starting voltage to the starter relay in the compressor, then cuts off to allow the motor to run.
  4. I bought a Supco 3-in-1 on Amazon for less than $13 and hooked it up according to the supplied instructions. It lasted about 3 years.
Of course, the factory recommended repair is to buy the original replacement relay, but it will be more costly and harder to find.
I bought a Supco 3 in 1 Hard Start relay sized for the HP on my compressor. Mine was the Supco RCO810 (see link below).
NOTE: Before I replaced the starter relay and overload protection with a Supco 3 in 1, I learned how to test the compressor with a Volt/Ohm meter. If you don't have a meter, you can buy them online or inexpensive to free with a coupon at Harbor Freight.
Feb 15, 2015 | Emerson Refrigerators
How much is a new compressor for a kitchen aid refridgerator
Total repair about $500+ (average repair about $700) and would require a qualified professional to do the repair. Don't think I have seen that model need a compressor normally it's just the starter relay on the compressor.
Mar 14, 2013 | Whirlpool GS6NBEXR Side by Side...
My MFD2560HES refrigerator and freezer is not working off an on. I had the repair man come from the store I purchased it from and they said I needed a new compressor for $800.00 plus instalation. What do...
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Aug 16, 2010 | Maytag MFD2560HES Bottom Freezer French...
My repair man told me my compressor is shot. The
yes the compressor is under warranty for up to five years.how ever the over load relay and start ptc might be bad in stead of the compressor.so you can try and change them first and see what happens
Jan 25, 2010 | Refrigerators
Amana side by side fridge and freezer not cold.The model #ASD2624HES I have done some research and I think it might be the relay switch or the compresser.If anyone had has this problem with this model...
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Part 4 on this diagram is your relay. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ASD2624HES&productCategoryId=0165000&brandId=1268&modelName=AMANA-REFRIGERATION&diagramPageId=00013&componentDescription=COMPRESSOR&documentId=M0608085&backToLink=Return%20to%20subcomponent%20list Here's how you can check it. http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 22, 2009 | Amana 26 cu. ft. Side-By-Side...
Maytag Side by Side Refrigerator MSD2756DEW, freezer warm, open doors and hear clicking noise. Coils are clear in the freezer, I replaced the adaptive defrost board about a year ago. Could this be a...
Hello the clicking noise is the start relay which is mounted to the compressor, remove wires and housing pull out relay and install new one, as easy as one two three :) If you have any questions please feel free to comment again...Good Luck!!! Mike
Aug 18, 2009 | Refrigerators
Side by side whirlpool frig. model ed5phexmb00
hi jody thanks for the question these new fridges now need the exact start relay if you installed a different one could have failed again or you have a faulty compressor thanks te appliance doc
Aug 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Maytag skybox stopped cooling
I just replaced my in-pieces starter relay and thermal swich with a Whirlpool 4387535 kit. My Skybox has been working fine ever since.
Note I had the same symptoms as other posts of the compressor turning on/off continuously (but no cooling)...I believe what was happening is that the starter relay would allow current to flow to initially start the compressor, but would never stop providing current to it after it had already started (as it should) thus in a few seconds the thermal switch would sense this and trip / remove power to the compressor...then this cycle would start all over once the thermal switch cooled down again and let power back to the compressor...
This kit is evidently the newer style of what is on the original Skybox compressors (functionally speaking)...the new starter relay looks and installs like the old one, but the thermal switch is different and you need to remove the old one (follow the black wire on the top post of the compressor back a little to a small black round thing with a flexible metal piece inside). The good news is that once you remove it, it already has the correct spade lug on the wire to plug directly into the new thermal switch which sits right on the top lug of the compressor above the starter relay.
Note I'm not a service tech, just a Skybox owner who was/is tired of Maytag disowning this product and calling it a "throwaway" when any part of it stops working (and all local authorized service centers laughing when asked to repair one).
Continuing on with my rant a little, I also see other posts on the internet which also state "throwaway" when you actually have a bad compressor because you can't get direct replacements anymore - my friend who does AC work on the side said he most certainly could put another compressor in there from probably just about any other mini-fridge...he just noted that it is a small place to do it so the replacement compressor form factor will have to be considered. He stated you may get a little more or less cooling efficieny but who cares if you really want to keep your machine working that you can't buy anymore (nor get a close alternative).
Mar 13, 2008 | Maytag SkyBox MBV1976A Beverage Dispenser
Kenmore Model #106.52214104 Side by Side Refrigerator
Personally I'd go with the repair company - I had a bad experience with Sears - they did something similar to me and I'm not too impressed with their service standards.
Sep 27, 2007 | Kenmore 50522 / 50524 Side by Side...
Maytag SkyBox MBV1976A Beverage Dispenser Logo
71 people viewed this question
Top Maytag Retail Supplies Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
