Question about Jenn-Air JES9800A Electric Kitchen Range
Front control panel shows "Remove Probe From Oven" & Beeps.
Our Jen Air Range has recently developed a peculiar habit. It seems that whenever we turn the oven on...the front panel begins to beep with the display reading: "Remove Probe From Oven". However, we have no probe inside the oven. The mind-numbing beeping seems to stop after several minutes. Other than this annoyance, the oven seems to be working fine. Any clues Stove Experts? Really appreciate any advice you might have!
Chad in San Diego
  • sullibury Sep 30, 2008
    I have the same problem, except mine won't turn off after a few minutes. I'm sure I will have to make a service call but was hoping I could just shut this function off.
I have the issue as well, seems like when I use the convect. feature. I have not called to have it serviced yet, but I have found that opening the oven door and truning the fan on for a few minutes, corrects it. At least until you turn it off again.
Posted on Dec 21, 2010
The oven will pre heat to set temp, then when it reaches temp the oven beeps and both oven elements turn off. At this point the control panel (clock LED) shows an F2 error.
Good afternoon.
F2 for hotpoint means oven temp sensor thinks oven exceeded 650 degrees .Did that happen?
Probably not so have your sensor checked or replaced. It should be a probe device in oven back wall.
Was this helpful?
Aug 16, 2011 | Hotpoint RB787 Electric Kitchen Range
I have a Maytag model MER5775QAW free standing range. When you press "bake" and then set the temp. and press "bake" again the numbers instantly climb to the set temp and the buzzer beeps showing oven at...
Unplug the range open the control panel to access the electronic oven control. Unplug the wires and wait 5 minutes. Replace all wires on the control and turn the power back on.
If this does not reset your oven control it must be replaced.
Your ERC(clock) is bad and must be replaced.
Nov 09, 2009 | Maytag MER5775Q Electric Kitchen Range
I get a F3 code on the control panel and the oven doesn't seem to regulate the temperature anymore model 68HN6TVW
check the temperature sensor probe and harness as f3 code refers to that..
you will need to pull the range out from the wall and disconnect from power and remove the panels that cover the control panel and sensor probe area at the back of the oven.
Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
sensor is part# 12001656 - Oven Sensor Kit 7" Long around 30-40 dollars plus shipping and tax, depending...
hope this helps,
best of luck,
ttfn
Nov 02, 2009 | Ovens
Our kenmore 790 built in oven keeps flashing an F30 code after we turn off the oven, or sometimes when the oven is on, it shuts off and then beeps the F30. I keep hearing it is the RTD probe, but where is...
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from www.searspartsdirect.com website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
http://media.fotki.com/1_p,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 06, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
I have a kitchenaid ceramic stovetop. recently I used the self cleaning oven and now it seems to not operate correctly. there is a frequent beeping noise....
is it the glasstop range with the oven control panel in the front? if so one of your over temperature thermostats is faulty.. it is probably causing an f-1 error.OR.. your temperature probe in the oven could be going bad.
Jan 01, 2009 | Crosley CE35111AA Electric Kitchen Range
I have a f30 error can i fix this myself? I have unpluged the stove and i need to know where to look for this
OK - here's a little tip that might save you a bundle of cash:
The Frigidaire glasstop slide-in Range model # PLES389ECH has a habit of triggering a F30 error, which according to the NEW table of error codes (http://www.applianceaid.com/faultcodes3.html), implies an issue with either the Electronic Oven Control (EOC) panel (located beneath the Control Panel Assembly), or the temperature probe itself (located within the main oven cavity, back wall, upper-left corner). However, a quick glance at page 12 of the Factory Parts Catalog's wiring diagram (http://www.youserguide.com/wiki/Frigidaire_PLES389ECH or http://www.serviexcell.com.mx/manuales/PLES389ECH.pdf) shows two thermal breakers wired into the circuit as well.
To check the probe, disconnect power and either pull the probe from the cavity of the oven (two screws, and a disconnect plug) and measure resistance across the probe, or take the Control Panel Assembly off the front (remove 4 cooktop control knobs and 4 teflon mounting nuts) and measure resistance at the EOC P5 quick-disconnect plug (violet wires - see wiring diagram)...it should read approx. 1091 Ohms at room temperature per ApplianceAid's table. If you measured at the probe, an open (infinite resistance) or short (zero resistance) indicates a bad probe. Replace for about $40.00 (per http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5160618).
If you get an open or short by measuring at the P5 plug, the issue is either the probe OR the thermal breakers. Also called a Thermal Cutout Switch (item #141 on p.8 of your parts catalog), one of these buggers is located near the electronic control module for the right rear stovetop burner (#54A, follow the violet wires from EOC to locate it) - since you already have the Control Panel Assembly pulled, reach over and push the button on the breaker to reset it. This may have just solved your error code! For FREE!! If it doesn't reset, you may have to replace the breaker itself (around $16.00).
However, if you measured at the plug and get the appropriate resistance for the entire circuit it's likely that your breakers, probe and wiring harness (always check for disconnected wiring) are fine, and that the problem lies with the EOC itself. This pricey gizmo runs a little over $200. My sympathies.
Good luck! Feel free to mail me any contributions should you save yourself a $350+ service call. :)
Dec 17, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Kenmore Elite made by Frigidaire 30" slide in electric range model # 790.46603501 shows F30 ERR. Oven will not work. Range top is fine. Help!!! Turkey to cook!! Lynne
Nov 26, 2008 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
Kichenaid electric stove
the probe is put into the oven to sense heat and to prevent the oven from oveheating during normal operation. the reason the probe is beeping is because it's dislogged or needs to be replaced.
the only way to make the beeping stop is to disable it but i wouldn't recommend it.
have a technician run a diagnostic on the stove. sounds like the probe needs to be replaced.
Jul 09, 2008 | Jenn-Air JES9860 Electric Kitchen Range
Jen air locked latch after cleaning
I finally got my oven to work properly by shutting off the breaker and resetting the main clock. Cured the always locked problem as well as the beep twice when self cleaning.
Have to repeat this every few months since the problem seems to come back.
Feb 24, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jenn-Air JES9800A Electric Kitchen Range Logo
565 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
