Xerox 416 Pro Copier Paper Jamming
Posted by yia2008 on Sep 23, 2008
Paper Jam occurs in different areas of the copier. Can you recommend an easy fix for this? Is there lubricant that needs to be applied on rollers or is there another problem? Using 20lb office depot brand copy paper. Also tried Xerox Brand 24 lb copy paper.
Thank you. Comment by yia2008, posted on Sep 23, 2008 Hello,
The copier appears to be in good physical condition. I purchased it used. So I'm not sure of the age of it. It has 89,000 copies on it.
It paper jams often, but will sometimes make 5 or so copies before it jams. it appears to be jamming mostly at the exit point, but sometimes will jam near the enter point from the paper tray (more regularly at the exit point of the copy process.
Hope this helps you determine the problem. Please let me know if you need additional information.
Thank you.
Solution #1 posted on Sep 23, 2008
findmeifucan
Rank: Guru
Rating: 87%, 19 votes
You should first have a check over the roller . Mostly the problem will be the roller only .
But let me know how old is your copier ?
Depending on it we can solve your problem .
SAM ANDERSON
  • 239 Answers
On this type of machine, it can be very involved and a service call maybe needed.
What you have here is some rollers are not driving, and they are stalling too quick for you to see. There is a one way clutch on the transport after the copy exits the fuser. This exit transport has many gears and rollers on it.
At about this age the rollers get bound in the plastic bearings. It is very hard to get to them because of the tight fit. Complete dissesembly of this area is a must.
On the drive roller where the gears are held, the plastic bushings are very tight causing binding. When they are turned by hand they should turn free, you will find they are not.
Also this assembly has a switch actuator. Because the assembly is close to the fuser the tip of the actuator is either broken off or decayed over time. The switch needs to be replace and even the sensor itself.
I am sure even if you try to find the parts in the service manual, they can be very hard to find in the images.
If you do have the manual you will find the parts are very difficult to see and when you order them it is not the part you expected to get.
Place the service call, this is a very involved service repair.
As long as the machine is handled good, the machine will work fine.
Posted on Oct 17, 2009
    Genius:
  • 1,550 Answers
Sorry for responding late .
As you said you have problem at entry level sheet stops before entering the rolls more likely to be dirty entry , drive problem or sensor problem.
Running sheets with dark lead edge can cause sheets to stick to rollers,try running blank sheets to clean up, if they get through then try normal copies
If it doesnot work .
Rebuild fuser and clean out recycling pump and hoses.
Posted on Sep 23, 2008
Jam inxerox workcentre pro 128 copier finisher stapl area
how do i repair a staple jam in my xerox workcentre 128?
Jan 15, 2013 | Xerox WorkCentre Pro 123/128 Copier...
Xerox 416 Work Centre Pro Paper Jam
SAM ANDERSON
Sep 23, 2008 | Office Equipment & Supplies
Work Center Pro 575 always gets paper jams
If a document jam occurs during a transmission, the message "DOCUMENT JAM" is displayed. If this occurs, follow the procedure below. It is recommended that a duplicate from a copier, of the jammed document be used to reduce the chance of a jam when resending the document.
See Chapter 3, "Loading Documents" for document specifications and recommendations which may help avoid paper jams.
Note: The power can be left ON when clearing a paper jam.
Typical Causes of Document Jams
Recommended Procedure
The document is fed at an angle.
Adjust the Document Guides to the edges of the
document.
The document paper is too thin or too thick.
Make a duplicate using a copier and use the copy
as the sending document.
Document has tape or pieces of paper taped to it.
Remove the tape or make a duplicate using a copier and use the copy as the sending document.
The Control Panel Cover is not fully closed.
Close the Control Panel Cover fully.
The document is stapled. Remove the staple(s), or make a duplicate using a copier and use the copy as the sending document.
Basic Troubleshooting
1. Remove all documents from the Document Support.
2. Open the Control Panel Cover.
3. Remove the document jam. Remove any pieces of paper, paper clips, or staples that may have caused the jam.
4. Close the Control Panel Cover.
5. Verify the display has returned to the Standby Mode.
Jul 13, 2010 | Xerox WorkCentre Pro 575 Plain Paper Laser...
What does code J1 mean on a xerox work center pro?
J1 mean any paper jam in paper feed area or sensor displace.lower cassate or multi pass tray.clear jam paper then solve your problem.
Dec 23, 2009 | Xerox WorkCentre M-24 Color Copier
My workcentre Pro 416 shows a jam, i have removed all jams that i could see. However it shows clear jam, and has 19 to dos on the screen, like open door, clean jam, close door, etc.. Is there a major reset...
On this 416 machine, there is one place you cannot see a jam.
Looking at the machine the right side doors need to be opened.
The lower trays feed paper and need to go up the by pass feeder area.
Just lower and behind the by-pass feeder the paper can get stuck, and you cannot see it.
If you try to push a card stock up from the bottom, the paper can be pushed out.
The other area is at the fuser. If the switch is worn it will not drop back into position. The tip of the switch wears and breaks off.
It is rare a sensor goes out on this machine, besides the fuser sensor. Each paper feed head needs to be checked to see if the paper sensors are bad.
Not seeing the machine, call Xerox for service repair if not resolved.
Jul 15, 2009 | Xerox WorkCentre Pro 416 All-In-One Laser...
Copier says paper jam in area 2, no jam
What is the model number of the copier? That would help a lot in knowing what to tell you. The paper feeders are all different. but I suspect bad rollers or sleeves.
Mar 19, 2009 | Xerox Office Equipment & Supplies
Paper jam in xerox copier 5328
Specify the area of paper jam or the code on display that cud help isolate the problem quicker, it cud be a C or E code. Try to clear it with code 20 subcode 03, but state code on display
Oct 30, 2008 | Office Equipment & Supplies
E3 paper jam
if the paper is crooked it will come out wrinkled. If not the print is crooked indicating a different problem.
You wil have to look at the paper as it is printing, to see where it is catching, paper ramp maybe ( before the fuser entrance), exit rollers? ( only place I know there are bristles)
E3 is : paper jam in fuser
also check fingers or claws on fuser they catch the paper if worn.
Apr 21, 2008 | Office Equipment & Supplies
Paper jamming
The fuser drive gear is most likely bad.
You can order one at this location.
https://www.partsdrop.com/store/
If you call ask for Britt, he will help you. Best parts service you can ask for. And NO ITS NOT ME. I just deal with them a lot and highly recommend them.
That gear is in the $15 range.
Apr 14, 2008 | Xerox WorkCentre XD155DF Laser Printer
Xerox 416 Fuser
Is it getting thru the "pinch of the fuser and catching on the stripper fingers? If so clean the fingers, ensure they are not worn or tips broken.(Running sheets with dark lead edge can cause sheets to stick to rollers,try running blank sheets to clean up, if they get thru then try normal copies)
If the sheet stops before entering the rolls more likely to be dirty entry chute, drive problem or sensor problem....need more detail
Jan 25, 2008 | Office Equipment & Supplies
88 people viewed this question
k24674
