Question about SanDisk 2GB microSD Memory Card
MY micro sd 2 gb wont show up
I put it in the adapter and inserted it but nothing happened. i went to my computer and opened it it said i had to format it i have tryed all of the settings but it wont work.
  • Anonymous Sep 27, 2008
    No solution just the same issue.
    Tried 2 computers, Xp on one and XPPro on the other, and both say the card is not formatted but can't perform the formatting.
    Bought it purely for use on PC.
Limited solution - On the computer
Bring up Control Panel - then
Administrative Tools - then
Computer Management - then
Disk Management - then
Right click the 'Disk' corresponding to the SD card and Format it
The bad news is that it only formats to 1 GB.
I'm still trying to find out why it won't recognise the capacity as 2 GB.
Posted on Sep 27, 2008
Give me a driver
Posted on Oct 12, 2008
    Problem Solver:
  • 11 Answers
Try inserting it on the other usb panel.
Posted on Sep 23, 2008
Micro sd card too big for garmin gps nuvi 1450
A micro SD card is the correct memory card for the 14xx series. A 2 GB should be just fine. Some units can not handle a large memory SD card. This has nothing to do with the physical size however.
Are you sure it isn't a micro SD card that is inserted into a standard SD card adapter? A standard SD card is much larger and will not fit into the 14xx series. Look at the end of the SD card that does not have the gold pins and see if there is a ridge where the micro SD card may be inserted into the larger standard SD adapter. Using a fingernail, you can slide the micro SD card out from the SD card adapter. Also, the micro SD card will only insert one way. Try flipping it over and inserting it again, always with the gold pins facing the Nuvi.
Apr 06, 2013 | Garmin nuvi GPS
Doesn't show mp3 files on micro sd card
You have to drag and drop only the MP3 files into the music folder. If you have them organized and in folder by artist, drag only the MP3s into the card's Music folder.
May 05, 2009 | Lands Phones
It doesnt work when i insert the card with my micro memory card and asks for a disk
Hi likkle_miss_,
The Micro adapter has no memory in it. It is just an adapter to use so you can plug your Micro SD memory card into a larger (SD) slot. The SD Micro memory card needs to be inserted into the adapter.
Kingston Tech Support
Apr 22, 2009 | Kingston 1GB Secure Digital Memory Card
What's the biggest micro sd card that fits htc s 620 smartphone?
  • Micro SD Compatible with the following Smartphones:
  •  Blackberry 8800
  •  Blackberry Curve 8300
  •  Blackberry Pearl
  •  Palm Centro
  •  Samsung BLACKJACK
  •  T-Mobile Dash, HTC S621 & HTC S620
  • 4GB Micro SD - Secure Digital Card with SD Adapter
    Hope this helps, if it does please rate accordingly, David
    Mar 18, 2009 | HTC S620 Smartphone
    My computer nor samsung alias wont read my 4gb pny microsd chard
    I doubt that your phone accepts the 4GB version of the micro sd card, try the 2GB
    Feb 22, 2009 | PNY 4GB microSD High Capacity Mobile Media...
    I dont know where to put this
    Hi, First insert the micro SD into its adapter which resembles a SD card itself but has a small opening at the bottom to insert the micro SD. The adapter should not b locked while inserting or removin the micro SD. Now insert the adapter in the card readers slot which should be connected to a PC via a USB. If its a card reader then insert the adapter with microSD in the right side top corner of the card reader with the adapters copper pins facing down. OR if u already have slots in ur CPU to insert the SD card install it there, Now transfer files to ur card happily. NOTE: Rename ur device so that next time when u plug it in the adpter n connect it to PC, u wont get confused. Just right Click on the drive icon in ur PC n select rename n just giv any name as u lik. Rate he soln dude Bye..........!
    Jan 25, 2009 | PNY 2GB microSD Memory Card
    Navigon 7100 Fatal Application Error
    I had the same problem with my unit.
    Did you try to reload ALL the files back to the memory card?
    This as a slow process,but it seems to go a little faster if you use a card reader.
    Format card using FAT option,not FAT32.
    Hope this helps
    Jan 21, 2009 | Navigon 7100 GPS Navigator GPS Receiver
    Computer is not reading my Micro SD, but phone is reading..
    What size is the SD card in GBs? If it is larger than 2GB (4 or 8) do you have a SDHC card reader?
    Also try formating the card first in the phone and then using it. Using it straight out of the package, while able to be written, my have difficultly with other devices reading the data.
    Jul 23, 2008 | PNY 2GB microSD Memory Card
    Micro SD 2 GB just stopped working
    The PIC or EEPROM inside these cards may not be working. I guess you best bet is to buy a new one try Kingston brand or go with another Sandisk.
    Jul 02, 2008 | SanDisk 2GB microSD Memory Card
    SanDisk 2GB microSD Memory Card Logo
    246 people viewed this question
    Top SanDisk Electronics - Others Experts
    Piyal Perera
    Piyal Perera
    Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
