Question about Whirlpool GHW9300 Duet Washer
F 13 PROBLEM ON MY DUET
WHAT SHOULD I DO?
F13--PROBLEM IN THE DISPENSER CIRCUIT
  • 1 more comment
  • jonhdoe187 Sep 23, 2008
    F 13 ERROR CODE ON WASHER COMPLETE MESS CAN'T WASH STOP ON THE MIDDLE OF THE CYCLE AND DISPLAYS F THEN 13
  • jonhdoe187 Sep 24, 2008
    i check the harness connection looks good and free or rust ,when you say dispener motor is that the actuator or the flow meter? the motor from the actuator spins and looks normal the only thing i still don't know how to check is the inlet valve or the flowmeter those two things i don't know if i should even mess with it ,any suggestions will be appreciated
  • stabbs May 01, 2009
    I have the f13 problem as well. I just fixed the chronic f-11 and f-dl error by following these instructions:http://www.flickr.com/photos/mysteryonio...
    But now I am getting the f13. The drain linkage seems to be moving fine but it just keeps cycling.
  • 116 Answers
You have a problem with the dispenser motor. Could be electrical or mechanical - check that the wires are securely connected, check that the mechanical linkages from the motor to the top of the dispenser are not jammed
Regards
Posted on Sep 23, 2008
F13 and F11 codes pop up
F13 is
Dispenser Circuit Error
If the dispenser motor is not able to be driven to it's proper position.
Check mechanical linkage from dispenser motor to the top of the dispenser
Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
Check Dispenser Motor
i snagged this answer from another site
i think its a worn bit of plastic
as it becomes britten when not always wet
much like a boat out of water
Mar 05, 2015 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/13 error code on...
The error F/13 is shown on the display due to Dispenser Circuit Error detected in the washing machine.
In this problem check the dispenser motor .Either is blocked or its not running in proper direction.
This will Help.Good Luck.
on Mar 11, 2010 | Washing Machines
Washer was just moved to a new house and doesn't work. It has F-13 code.
F13 Dispenser circuit error
Possible causes/procedure:
1. Unplug washer or disconnect power.
2. Check mechanical linkage from dispenser motor to the top of
the dispenser.
3. Check wire harness connections to the dispenser motor and
Central Control Unit (CCU).
4. Check dispenser motor for powered rotations.
Jul 02, 2011 | Washing Machines
I have the f13 error, on whirlpool duet ht, 9150. I have removed the top and I'm trying to run a drain and spin. The motor seems to work fine as it cycles through all four steps, but never seems to...
F13 codeindicates that the dispenser motor is not able to be driven to it's properposition.
*Check mechanical linkage from the dispenser motor to the top of thedispenser.
*Check wire harness connections to the dispenser motor and CentralControl Unit (CCU).
*Check the Dispenser Motor.
Toremove the error display, press Pause/Cancel twice. IfPause/Cancel does not work: *Unplug washer or disconnect power for oneminute.
*Plug in washer or reconnect power.
*Re-select the cycle and press Start. Hopethis helps.. Good luck! :)
Jun 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a F13 fault that wont reset on a AWOE9759. I do not know what a F13 fault is but i have tried what it says to do in the manual. Please help.
F13 Error = Dispenser circuit error
Potential Causes
• Check mechanical linkage from dispenser motor to the top of the dispenser.
• Check Wire Harness connections to the dispenser motor and Central Control Unit (CCU)
• Check Dispenser Motor
Replace failed component.
Dec 26, 2010 | Whirlpool Washing Machines
My code is f13
Remove you base panel and hunt for your tech data sheet. A list of the codes and solutions is given along with diagnostics. atypical F-13:
the dispenser.
Dec 15, 2010 | Washing Machines
What is F13 code?
f13 is a Dispenser circuit error
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Aug 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
When you turn on washer it says f13
HI. This code is in reference to the dispenser circuit. If the dispenser motor is not able to be driven to it’s proper position, the F-13 code will appear. The necessary actions are to Check the mechanical linkage from the dispenser motor to the top of the dispenser assembly. You will also need to inspect the wire Harness connections to the dispenser motor and Central Control Unit (CCU). Make sure that these connections are tight and secure. The last area of concern will be to check the motor that is located and mounted on the dispenser assembly. The possible culprit will usually be a failed motor, but you will need to inspect all that I have stated to isolate the motor. Make sure that the linkages are ok and the wire harness is securely connected to their respective connection points.
Here is a link to the service manual for this unit. This manual will guide you through the disassembling process and it will have a proper testing chart for the dispenser motor circuit, as well. I would suggest to read the dispenser details at the bottom of page 3-1. The title will be "Dispenser Distribution System". This will familiarize you with the dispecner assembly and its parts. Read the entire summary before starting your inspection procedure and repair. The summary will end on page 3-2. The dispecer can be easily accessed y removing the top. The top removal procedure will start at the top page 4-2.
Aug 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool washing machine keeps saying f13 whats wrong and how do i fix it
Hello, the F13 means "Dispenser Circuit Error", if the dispenser motor is not able to be driven to its proper position.
Check the following:
1. Check mechanical linkage from dispenser motor to the top of the dispenser.
2. Check wire harness connection to the dispenser motor and Central Control Unit and lastly
3. Check dispenser motor.
Thanks
Jun 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Fault codes f 13 Whirlpool Washing Machine AWO/D 5716
If the dispenser motor is not able to be driven to it’s proper position.
Potential Causes
Jan 29, 2009 | Washing Machines
Washing Machines Logo
172 people viewed this question
Dan Webster
Dan Webster
Sal De
