Question about AcerScan 640BU Flatbed Scanner
Acer 640BU scanner driver for VISTA
I need an Acer 640BU scanner driver for VISTA. Does one exist? I tried Vuescan but the trial version writes dollar sins all over the image and they want almost as much as a new scanner to buy the software.
kirt-home@rogers.com
  • GUILLERMOTOG Sep 24, 2008
    DRIVER SCANPRISA 640U DE ACER
  • Anonymous Dec 18, 2008
    I no longer have the CD Rom that came with my acer and now I have Vista and can't install it! Help!
Don't bother pall,
I had the same problem. The thing is that acer no longer maintain their flatbed scanners because they sold the brand for scanners to benq.Not a big surprise, huh?! ;)
So there are no such thing as a flatbed acer scanner driver for vista.
However there is always a silver lining after the cloud or something similar is the saying. Here I send you some data to register your Vuescan software:
E-mail address : dieter.lehmitz@rpr1insider.de
Serial number : 101907537
Customer number : 2025651943
Enter it where the program expects it. It works 100 %
Enjoy !
Yours Svetlozar Vasilev
E-mail - slynce@abv.bg
p.s. if you've got info on more people with the same prob, pls pass the remedy!
Posted on Jan 06, 2009
  • florindgis Jun 30, 2010
    Thanks Svetlozar, it worked as you said 100%. Now I have a functional scanner!
NECESITO DRIVERS SCANPRISA 640U DE ACER
Posted on Sep 24, 2008
    Brigadier General:
  • 5,158 Answers
Http://acer.com/support/index.htm
Posted on Dec 18, 2008
Is there a wia driver for Windows 7 for the Kodak i65 Scanner?
Well I too HAD this problem. Upgraded to Win7 64 bit and was unable to install the existing 32 bit drivers (of course) that operate in WinXP and Vista. Called Kodak and there wonderful answer was Buy a New Scanner.
Well this was just not an option. SO I searched and searched for alternatives, to creating a WinXP Virtual machine with VMPlayer or VirtualBox to remote controlling an older WinXP laptop connected to the scanner. None were solutions I felt I could live with.
Then I found VueScan at www.hamrick.com. A small chea scanning software that you can try before you buy. I read through everything on the site including the specific scanner notes for the Kodak I65, then downloaded the trial version.
Once installed you follow the instructions from the site to use VueScans own driver to run the Kodak scanner and lo and behold I got my ORIGINAL Kodak scanner menu to work on Win7 64bit. Then I used the VueScan software to scan a document and it worked like a charm. Albeit with the VueScan watermark.
Now I could have stopped there and called it a success, but I then, tried scanning with my Nitro PDF Pro software and was amazed to get a Perfect scan without the watermark.
Now NOTE, I did not buy the VueScan software at this time, as I don't need it's ability. I just used their driver and driver installation instructions from the website specifically for the Kodak I65. Most likely going to buy the basic version of the software anyway, as I think the guy deserves something for saving my EXPENSIVE I65 from becoming a paperweight.
An Elegant and Complete solution to Kodak's total support failure!
N
Jun 08, 2011 | Kodak i65
I'm trying to install my scanner on my PC, I have windows 7
From what i can see there is no driver for vista or windows 7 as that is an old scanner.
You can try a program called VueScan which basically supports a bunch of old scanners so they work with current versions of windows. They have a free trial (So you can confirm that it works). If you want to use for free I believe you can but it embeds images over your scans so most people dont like that. I think it is $40 to unlock it.
You can download VueScan here.... http://www.hamrick.com/
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
Mar 01, 2011 | AcerScan 640BU Flatbed Scanner
Dimage Scan Dual IV is it compatable with Windows 7 32 bit?
Right now, the Konica-Minolta site lists the scanner as discontinued and has no drivers for Windows versions later than XP. The Microsoft Compatibility site lists it as "Information Coming Soon" You can try the generic driver that Windows will try to install (check if you need TWAIN or WIA drivers) or download the current driver and try installing it with XP SP3 compatability mode (right click on the file, select Properties, then the compatability tab.
If those fail, there is another option in Win7 Pro or Ultimate. Download and install the XP mode from Microsoft (2 downloads/installs). Then install the scanner inside the virtual computer running XP that results. You may need to save images to external media to share them between the two computers.
I hope this helps.
Feb 17, 2010 | Konica Minolta Dimage Scan Dual IV Film...
Acer ScanPrisa 620UT
http://www.computerdriverfinder.com/drivers/acer-scanners-610u-620u-620ut-640u-640ut-640bt-640bu-1240ut-3300-492
try this one ..it apear on a search for vista comp. driver and ..indeed does not specify that its for xp ....it says just windows...
a second solution on vista is to install a Everest ultimate with license or at least a trial ...and for vista and windows & usually this programs find drivers for you ...just right click on device and update driver
Sep 03, 2009 | AcerScan 620U Flatbed Scanner
I lost my softare driver for acer flatbed 640BU scanner
first decide on which particular operating system you want to use use the scanner. Then try to install tyhe drivers. If on both check for the architecture as well 32 bit or 64 bit. Initially uninstall alln the entries for the scanner from add and remove programs or delete all the entries using microsoft cleanup utility tool. Then try installing the drivers it should work.
Jan 24, 2009 | AcerScan 640BU Flatbed Scanner
Acer scanner 620PT need vista drivers
Just visit the following URL to download the VueScan 8.5 which will resolve Vista driver issues with a lot of flatbed scanner.
http://www.hamrick.com/files/vuesca85.exe
Oct 30, 2008 | Office Equipment & Supplies
Driver For vin vista acer for Flatbed scaner 13
This solution works with the following Acer models on Vista 64.
FlatbedScaner5 ="Acer scanner 310U/620U" FlatbedScaner13="Acer 320U/340U/620U+/640U" FlatbedScaner16="Acer scanner 620UT+/640UT" FlatbedScaner19="Acer scanner 1240UT/5100U" FlatbedScaner20="Acer scanner 640BT/640BU" FlatbedScaner21="Acer scanner 4300U/3300U" FlatbedScaner23="Acer scanner 4300U/3300U"
The driver package includes the following files with file sizes ahead.
108,032 acerscad.dll 3,269 acerscan.inf 24,192 ksthunk.sys 451 Model.ini 17,683 sti.inf 30,663 u126v041.bin 30,598 u176v040.bin 32,301 u190v041.bin 31,664 u192v073.bin 30,221 u222V065.bin 27,984 u34v110.bin 31,364 u64v119.bin 31,048 u96v121.bin 27,648 usbscan.sys
All these files are derived from those on Windows XP64. Maybe it works on Vista 32.
Sep 16, 2008 | BenQ Scan to Web 3300U Flatbed Scanner
Need ac adapter
ต้องการโปรแกรมDRIVER SCANNER ACER 640BU
Aug 20, 2008 | AcerScan 640BU Flatbed Scanner
Acer scanner 640BU
hello cherylin
you dont say what o/s you running so i persume xp.
Acer 640BU driver - Acer Scanner Drivers - _SETUP.DLL
if not for xp post back i will find your req drivers
riz.
Jul 31, 2008 | AcerScan 640BU Flatbed Scanner
CanoScan Vs. Windows Vista
Tom, your solution is incorrect. I have just got my Canoscan working fine with Vista, simply using Canon's official XP drivers and unpacking them in XP compatibility mode. Is working fine with just a bit of experimentation. (You need the Canon toolbox software too, all of which is available from canon.com)
Nov 02, 2007 | Canon CanoScan N656U Flatbed Scanner
AcerScan 640BU Flatbed Scanner Logo
2,516 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
