Question about Acer Aspire 3100-1405 Notebook
Acer Battery chaging problems
Acer 3100 would not recharge. The charger seemed to be operating ok, light etc., however, new battery did not solve the problem...still no charge.
Bought new charger, which seemed to work
  • Acer Master
  • 13,433 Answers
Seems like a old problem, but does the laptop work without a battery? possibly the powerjack on the computer is loose.
if you have already solved this problem do share with the world how you solved it.
Posted on Jan 14, 2009
I cannot charge the battery using the ac adapter or USB port on my computer even the charge lamp does not light up can you please help
If a lithium battery is too deeply discharged or the cells matching become unbalanced from many deep discharges, then it can be permanently damaged. The chargers often have over discharge detection circuits, which prevent you from recharging the battery under these circumstances. This is because the battery when overdischarged, could vent or overheat etc. if recharged.
Overdischarge can happen if you don't recharge the camera after using it and then leave it in the closet for a long time before trying to recharge.
This often happens with laptops if you don't remove the battery when storing it for months. The laptop uses a small amount of current even when switched off and this causes the over discharge.
Best bet is to try and charge a new battery, to see that the charger is ok.
May 05, 2015 | Sony HDR-CX130E FULL HD FLASH MEMORY PAL...
The charging port of my acer 5251 is broken, so I cannot charge my battery. Is there any way to charge the battery externally? Thanks
Charger connector breakage is a common problem in this type of device. The practical answer is to repair or replace the connector so that you can recharge the battery in the normal way.
Nov 28, 2013 | Acer Aspire 5241 5251 5332 5334 5338 5516...
Low battery warning
Take the battery out, plug in the charger and see if the laptop works.
If it works, the battery may be the problem.
Check the AC Adapter
Check to make sure the adapter is plugged securely into the wall outlet, connected firmly to the adapter box and to the back of your laptop.
Most AC adapters have a little light in them on that rectangular box in the middle of the cord that lights up when it's getting electricity.
If that light isn't on, try a different outlet.
Check your fuse or circuit breaker box and plug a different device into that outlet to make sure there is power to it.
If it still does not light up, your adapter could need replacing.
Also check the adapter box for signs of warmth, as it will generate heat when it's plugged in. No heat means no power.
Remove the Battery Sometimes it's as simple as a seated battery.
Remove the battery entirely and clean out any dust, lint or hair that may be clogging the connectors and preventing a proper connection.
Reseat the battery securely and make sure the little locking pins that hold your battery in place are securely fastened and there is no movement.
Fix a Broken Laptop Charger
If your laptop charger seems broken, it's most likely because the battery will not charge.
You plug in the cord, the lights come on, but the charging light doesn't change or blinks repeatedly.
When you remove the power cord, the laptop shuts off instantly due to the depleted battery. There's more than one cause for this, and it's not always a broken charger.
Check the connection between the charger and the laptop.
It should fit firmly in the DC jack without wiggling.
If it is loose, use electrical tape to hold it in place so the charger can receive power.
This is a temporary fix, however, because a faulty connection can create sparks and cause a fire or injury.
A loose connection will just get worse over time, so have it sent to a DC jack specialist as soon as possible.
Turn off the laptop and flip it upside down. Locate the latch that secures the battery and slide open.
The battery should pop out; give it a tug if it doesn't.
Apply a small amount of rubbing alcohol (Methylated Spirits)to the tip of a cotton swab and use it to clean the battery's connectors.
Dirt can build up and interfere with the connection, giving the appearance of a broken charger. Let the alcohol dry completely and re-insert the battery.
Slide the latch to secure it and plug in the power cord to test it.
See if the laptop powers on with the charger only and battery removed.
If it does, the battery is the likely culprit and should be replaced.
If the charger is truly broken, the only thing to do is to replace it or the power cord attached to it. Look on the bottom and write down the part number.
Call the laptop manufacturer for a replacement charger or search for the part number on eBay.
If you purchase from anyone other than the original manufacturer, ask for genuine parts to reduce the possibility of problems.
Troubleshoot Mag Safe adaptors
Acer laptops allow you to take your work and entertainment on the go.
You can work on a presentation during a long flight or watch a DVD in the middle of a park.
Acer laptops can do this because they are powered by batteries, allowing the laptop to run without having to be plugged into a power source.
Normally, the battery can be recharged by plugging the laptop back into a power socket.
But certain problems can keep the battery from charging.Electrical Connection
For laptops to charge, they need to be connected to a power source.
Although it may look like you have the cable plugged in correctly on the Acer, make sure that the cord is firmly plugged into the power socket.
There should be a light on the Acer keyboard as well as a power symbol on the taskbar for your operating system that tells you whether the laptop is running off electrical or battery power.
If it is plugged in, make sure that this icon shows that it is on electrical power.
Also check the socket where the Acer is plugged in and make sure that it isn't turned off at the main circuit breaker.
Turn the Acer over and make sure that the battery is properly placed in the battery compartment. Most laptops will have locks that keep the battery securely in place.
These locks can sometimes come loose.
Use a piece of strong tape as a temporary measure to keep a loose battery in place.
Clean the terminals on the battery to ensure that there is a good connection.
Remove the battery from the battery compartment.
Apply rubbing alcohol to a lint-free cloth. Rub this cloth over the shiny metal terminals on the battery.
Over time, batteries lose their ability to be recharged.
If neither of the aforementioned steps works, you may just have a bad battery.
Check with Acer or other vendors to find a replacement for your model.
BIOS Update The BIOS (Basic Input Output System) controls a number of basic functions for a computer, such as assigning the hard drives and other system functions.
The BIOS also controls the battery charging function.
Certain Acer models have a bad BIOS that operates the computer normally but doesn't charge the battery.
To solve this problem, you need to perform an operation called "Flashing the BIOS" where you download a new version of the BIOS and upload it to your Acer.
Check on the Acer support site to see whether your computer model could possibly be affected by this.
The power adapter, the part that plugs into the Acer from the power socket, can go bad.
Check for a power light on the adapter.
If the light is not lit, you probably have a bad adapter.
Replacement adapters can be purchased from Acer or other online vendors.
Jul 14, 2013 | Acer Computers & Internet
Not charging Acer Aspire 5732z, now won't turn on!
If it does not work with the Charger while the battery is out then I would say either your charger is bad, the dc power jack where the charger plugs into the laptop is bad or you've got motherboard issues. Does the charger have a light on it to indicate that it is on when plugged in the wall? Do you see any lights when you plug the charger into the laptop?
Take an ink pen and see if the little pin inside the computer where the charger plugs is loose and moves a bit. If so that is probably your problem. If the pin is tight and the charger works, then you've got motherboard issues.
Mar 29, 2012 | Acer Aspire Computers & Internet
Fuji battery charger BC-45 - red light blinks when I put in battery and battery does not charge
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Aug 03, 2010 | Duracell AA/AAA NiMH Battery Charger with...
Battery New battery won't hold a charge on Acer 3100
New battery will typically take 12 hrs for first charge.
Mar 08, 2010 | Acer Aspire 3000 Notebook
I have this phone and the battery will drop from a fully charged state to dead and i have to recharge is there something i can do to keep this from happening
The best thing to do is take your phone and charger to your local network suppliers shop.
1.try a new battery if thats ok problem solved.
2.try charging with a different charger..if thats ok problem solved
3.If itsnot the battery or charger then the problem lies with the phone ..ask for a replacement at this stage.
Hope it helps.
Dec 26, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
Netbook acer one not recharging the battery
Your charger might be dead, check his output with a voltmeter if you get some juice. It should be around 19 Volts. Then it might loose his power with a charge (when you plug it onto your laptop) so you can try to connect a car light bulb to it . If get light then probably the motherboard of your laptop has issues, if no lights then you can replace your charger.
Cost in average 45 USD.
good luck
Jul 31, 2009 | Acer Aspire One Netbook 8.9" Notebook
The Acer 3100 Series Laptop battery on light burns continously
That battery is exhausted. Best not even leave it in the laptop ever. As all this will do is to create more heat and overload the power system. Best to remove it and hang on to it until you get a new one.
Jan 16, 2009 | Acer Computers & Internet
Battery exhausted
I found this happening until I decided to change to re chargeable batteries and havnt had this problem since.
Aug 19, 2007 | Nikon Coolpix 3200 Digital Camera
Acer Aspire 3100-1405 Notebook Logo
134 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
