Question about Frigidaire FRT17G4B Top Freezer Refrigerator
Magic chef refriderator proplems
We have a magic chef model mcbr 1000w that someone gave to us. the freezer works but after awhile the bottom does not stay cold. we removed the panel inside the freezer and the coils were full of ice, do you know what the problem could be?
Check defrost termination relay
Posted on Sep 23, 2008
Hi i have a magic chef model # mcbr 1010b it was working great unti i left the door ajar overnight and now it gets very cold in freezer @ 0 degreeze and refrig part stays around 50 and seems like it will...
Since you left door open I think the evaporator is frozen up .Just shut it off for a while and let everything defrost then turn it back on and you should be fine
Jan 05, 2018 | Magic Chef CTB1722 Top Freezer...
Magic Chef Model MCBR 1020w refrigerator making a clicking noise.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 17, 2010 | Magic Chef CTB1502AR Top Freezer...
I have a magic chef freezer MCCF5WBX the power light is on, but the run light is not on and it is not working
Had the same problem for the same unit. In my case, the theromostat was sticking. Mine was still under warranty so I called Magic Chef, who in turn gave me to a local repair person. In order to save him time to travel out for a diagnosis, he asked me to tap on the control to see if the run light comes on. Sure enough the run light came on and cooled the freezer. Try tapping on the unit control to see if it kicks on. My email address is mearlj@aol.com. I'd like to know if it works.
Aug 18, 2009 | Magic Chef Chest Freezer MCCF5WBX
Magic Chef refridgerator with small built in freezer model#MCBR 980W. Defrosting instructions unclear; red button suppose to be pushed in for defrosting the small freezer, How is it suppose to actually...
I just defrosted my cooler and looked at the manual. It says that you should do it when the ice is only a 1/4 inch thick. Then it will do it without any effort. Well of course i waited till it was about 1 1/2 inches thick. The defrost button does help though. i pushed it and waited 3 hours and that loosened up the ice around the box. Then used an ice pick, flat head skrew driver, and a painters 5 in 1 tool. I cleaned the inside of the freezer fairly eaisly and let the rest of the defrost process clean the top and the sides of the box which i couldn't reach.
Jun 18, 2009 | Magic Chef Refrigerators
Our model is MCBR 415S. The top freezer acts as
You most likely have a bad thermostat control or a bad defrost timer.
Locate the defrost timer, probably inside the temp control panel.Defrost cycles should last 30 minutes then resume freezing.
Manually turn the timer control a 1/4 turn and see if it starts.
If so, replace the defrost control.
It could also be a bad temp control.
If the timer adjustment does not start the fridge. Tap the temp control. It may have stuck contacts.
Mar 10, 2009 | Magic Chef Refrigerators
Freezer works great, but the bottom takes for ever to cool
Hello. Your question didn't post right. All it says is "Freezer works great, but the bottom takes for ever..." Can you clarify.
Dec 05, 2008 | Magic Chef CTF1826AR Top Freezer...
Auto defrost failure fo Majic Chef refriderator model MCBR 1000W
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 28, 2008 | Refrigerators
Refridgerator leaking water
You will have to check the defrost drain in the freezer by removing either the back or bottom of the freezer . Thaw ice if found in freezer and check to see if the drain hole is clear. Do not use anything to chip at the ice. Clear ice by warming it with warm water or possibly a hair dryer.
Jun 26, 2008 | Magic Chef CTF2125 Top Freezer...
Frigidaire FRT17G4B Top Freezer Refrigerator Logo
249 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
