Question about Alpine CDA-9807 CD Player
Alpine cda-9807 no voice when cd plays.
Why doesnt my head unit sound when i ply cd only when raio is on i can hear the voice ? My Alpine CDA-9807 delivers only silence when set to CD input. Radio works fine, except the volume is more sensitive than it should be, blasts at level 7. This problem started after install into a 94 cadillac that used to have a dual tape and CD deck, could wiring somehow be an issue here?
all help is appreciated.
    Master:
  • 763 Answers
Try to configure the settings of your cd stereo which has left and right cause maybe that cause the problem. also if still the problem persist, then look at the wires and see if it connected properly. if the problem is the wiring then you may consult a technician to rewire it again. hope that helps!
CHARCOIS
Posted on Oct 06, 2008
    President:
  • 1,450 Answers
Your cadillac was originally a bose system?
  • TripleTauto
    TripleTauto Oct 06, 2008
    wiring may be issue on your volume problem. does cd show to be playing?
    Genius:
  • 2,035 Answers
First try to clean the lens of the cd player using lens cleaner which is easily available in dep or electronic Stores ...Clean the lens and then try to play the CD.. if this fails then check for any error on the player and please let me know....
Good luck....
Posted on Sep 23, 2008
  • Anand Kumar
    Anand Kumar Sep 23, 2008
    Check the cd player unit in the back as been connected ,this could the problem with cable which may be loose or defective ,try different cd and check .....
  • Anand Kumar
    Check the power to unit
    Power Requirement
    14.4 V DC
    (11–16 V allowable). it should within this range ...
    Sergeant:
    Champion:
  • 435 Answers
Hi, Since the problem is with the volume, I doubt if the car speaker's rating match the player.
May be the player is pumping in more power to the speakers than it should.
Check it.
Hope it helps.
thanks, K
  • 790 Answers
Hi
Try to set the cd function to settings! or menu, maybe you have not fair settings in your unit!
Thanks!
Alpine cda 9807 in yukon xl
hi david, check out the connection of the yellow and red wires on the back plug. yellow must be connected to a direct battery positive line(continuous positive), the red must be connected to a live wire from the ignition switch OR from a point that is +12v live once the car is started(switched positive). also make sure that that the ground connection is a direct good connection to the body of the vehicle!! make sure that the remote wire(blue) is insulated if you not using an automatic aerial or external amplfier. good luck.cheers.
Sep 08, 2013 | Alpine CDA-9807 CD Player
I have a Alpine CDA 7892 CD head unit I just installed and the radio works perfect but when I play a cd it sounds very muffled and I can hear bass only. Is the unit bad?
If the sound is coming out clearly with the radio on, then there is a problem with the cd drive or its connections. If your stereo has aux. inputs, you could run an mp3 player until your ready to replace it.
Apr 12, 2010 | Alpine CDA-7998 CD Player
Cda-150 alpine head unit
try pressing the source button to select ipod
Feb 07, 2010 | Alpine CDA-9885 CD Player
No sound from my 9855 alpine
There is an option in the unit itself to turn off the internal amplifier. If you push the 'menu' button, then go to the setup/settings menu, and then i believe it was under the 'general settings' tab. there's a option called INT IC or something. Make sure that is turned on.
Dec 12, 2008 | Alpine CDA-9855 CD Player
Alpine cda-w550e manual
I needed a manua for my alpine cda-7897 and went to alpine's website and just type in my unit number under there manual section and there it was in a nice little pdf. file. hopes this helps.
Aug 26, 2008 | Alpine CDA-7998 CD Player
Hooking up an MP3 to Alpine CDA-9805 head unit
ok when you look at the front of your system there is a button that has a (F) on it press and hold tell stuff comes on the screen then just keep pressing it tell you get to AUX off you should get it from there hope this helps
Jul 23, 2008 | Alpine CDA-9805 CD Player
Instaling alpine car/cd stereo cda 9807
Its probably your wiring harness that came with the stereo. Which can cause many more problems. alpine changed their wiring harness around that time. But they used the same plug, just wired different. So now there are crossed wires, but the plug fits, causing the amp chip to fry. maybe even further than the amp chip. an amp chip replacement runs about 80$ at a repair shop. if its just that.
Nov 18, 2007 | Alpine CDA-9807 CD Player
A.M. stations
What type of vehicle is it in? Some manufacturers, such as Toyota, use separate antenna plugs for AM and FM that cannot be plugged into an aftermarket unit at the same time.
Sep 18, 2007 | Alpine CDA-9807 CD Player
Alpine CDA-9807 CD Player Logo
167 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jeff Turcotte
Jeff Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
