New Computer types slow
I bought a new Compaq SR5550F computer last month and I'm experiencng slow typing. I have to wait a couple of seconds before it appears on the screen. I have changed the keyboard settings in Control Panel but this does not work.
  • qgrant Sep 23, 2008
    It's a brand new PC that has 3GBs of RAM.
  • techbwoy May 11, 2010
    you may need more memory
    or you have a program hogging you memory (example norton internet security).
    how much memory do you have in this machine ?
    Genius:
  • 1,124 Answers
If your computer is new, take it back to the seller.
Posted on Sep 24, 2008
Does not type a letter, get only a space when I press any key
if it is a phone or computer, what i has to do is a hard reset. for a computer unplug the power outlet for 30 sec and plug back in it should work. it is is a phone pull battery out and wait 10 seconds and put back in t should be a okay
Oct 28, 2017 | Computers & Internet
Tip
How to make your computer run faster for free!
Imagine that you have bought a computer that runs adequately fast. However, after a few weeks or couple of months you notice that your computer is not running as fast as it was when you first bought it.
One solution that someone may think is to buy new hardware (new processor, more RAM, bigger hard drive etc)
However before doing that try the following:
First of all go to Start, All Programs, Startup. If this contains items that you do not need you can delete them. These are just shortcuts and not the actual applications. Think if you need these applications to begin everytime you start up your computer. If not then remove them from that menu list.
Second thing you can try is a little bit more advanced:
Go to Start, Run and type msconfig and press enter.
In the dialog that opens go to Startup and see the long list of applications that startup everytime you boot your computer. You should only leave your antivirus program, and entries under the c:\windows\system32
If you are not sure about an entry leave it there or check it over the internet.
Then click on services and click Hide microsoft services. Check again which services should not be enabled and disable them. Use google again if you are not sure about the listed services.
Lastly, right click on MyComputer, select Properties. Go to Advanced tab and under performance click Settings.
Select Adjust for best performance
That's it. You should have a computer/laptop running faster.
on Jan 25, 2010 | Computers & Internet
Compaq presario fan placement
You can look for that in any computer shops at your area or try to contact a local tech. and ask where you can get a replacement fan for your computer
Jun 23, 2014 | HP Compaq Presario Sr5550f Desktop Pc
Computer can not connect to wireless modem ("Valet),has been running fine for 4-5 months. Ran network diagnostice "Windows has detected connection problem....."
If you are facing the connection problem, you need to do the following step.
Open Command Prompt, type ipconfig/release, after few seconds type ipconfig/renew. This will assign a new IP. Now you try to connect. If still facing the issue means you need to download and install a new wireless driver that is suitable for your operating system.
Please let me know once you check this.
Jan 18, 2011 | HP Compaq 6720s Notebook
Compaq Presario V2000 PC Notebook: computer is slow...
try the following
1. click on start -> then choose run -> in the run window type temp and hit enter. A new window would come up. Select everything on the window and delete it.
2. click on start -> then choose run -> in the run window type %temp% and hit enter. A new window would come up. Select everything on the window and delete it.
3. click on start -> then choose run -> in the run window type prefetch and hit enter. A new window would come up. Select everything on the window and delete it.
4. You can also Uninstall apps that you don't use anymore. This can be done by going into the control panel and select Add/Remove Prorams. Scroll through and delete apps you no longer use. 5. Restart the machine.
I am sure that this would resolve the issue. In case it does not try this
click on start -> then choose run -> in the run window type prefetch and hit enter. A new window would come up. Select the tab Startup, and click the button Disable all. Click apply and then OK and restart your coputer.
This should help. in case not click start -> Accessiories -> system tools -> Disk Defagment
In case that also does not works, scan your computer for some viruses.
You may also look at the option of increasing the RAM / Memory on your computer
This should help
May 18, 2010 | HP Compaq Presario V2000 Notebook
Crazy Compaq Laptop problem
coolness..a Crazy computer, and a compaq besides..
you are suffering from pre mousepad failure syndrome....it usually culminates from grease, oil, dirt, etc, getting into the edges, and compromising the innards..
time for a new palm rest, methinks.
check your computers warranty here 4 FREE
Mar 15, 2008 | Computers & Internet
Format a Compaq
Computer file extentions - A ASF, Sort for Advanced Streaming Format, file developed by Microsoft. ... ATO, Compaq Just Burn File. .ATY, 3D Topicscape association type after export to.
10/28/2005 - Latest questions and answer on Computer Hopes ... 10/25/2005 - MS-DOS format command help 10/25/2005 - Microsoft FrontPage help ...... 09/02/2005 - Compaq Company Information .
Read and follow instructions, Good Luck/Please dont for get to Vote/Thank You.
Dec 23, 2007 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
182 people viewed this question
David Payne
David Payne
