Question about HP Office Equipment & Supplies
I bought a HPDeskjet F2100 All in One Series printer and it was missing the cord that goes into the black box and the power outlet in the wall. Where can I get one please; Thank you Nan Riggio bazberrymuch @bigpond.com
I hvae fixed the problem
thank you
Posted on Sep 24, 2008
We had a power outage, now pixma Mx410 won't come on, any ideas?
Is pinter plugged into a power strip? Try plugging directly into wall. Make sure wall outlet is working correctly, try another item in plug in. Does printer have a power module or brick that is plugged into printer? That power module is there to protect your printer during a power surge, it may need to be reset. Is there a light on that brick or power module? If so, does it light up? If not, could be a bad power module. There is no such thing as "reset" button, so don't look there...It will have to be reset in a series of ways for an "external" module.
  1. Disconnect the power cord from the rear of the printer.
  2. Unplug the power cord from the wall outlet, power strip, or surge protector.
  3. If the printer uses a power module with a detachable power cord, disconnect the cord from the power module.
  4. Wait 15 seconds.
  5. If the printer uses a power module with a detachable power cord, reconnect the power cord to the power module.
  6. Reconnect the power cord to the rear of the printer.
  7. Plug the power cord directly into a wall outlet. Do not use a power strip or surge protector.
  8. Check to see if the power module or the power cord has an indicator light and if it is on
For an internal module:
  3. Wait 15 seconds.
  4. Reconnect the power cord to the rear of the printer.
  5. Plug the power cord directly into a wall outlet. Do not use a power strip or surge protector.
  6. Check to see if the power module has an indicator light.
Not sure if this will help you..but worth a try.....
Jun 15, 2014 | Canon Pixma MX410 All-In-One Printer
X7170 not powering up
Try this approach:
1. Remove the power adapter from the printer. The power adapter is the black box where the power cord is plugged in at the back of the printer.2. Disconnect the power cord from the power source.3. Reconnect the power cord directly to the power outlet in the wall. Bypass any surge devices or power outlets.4. Re-plug the power adapter into the printer.5. If the printer won't automatically power on, press the power button on the printer operator panel.
I hope this helps.
Should the problem continue, please contact Lexmark Technical Support Center for additional assistance.
Nov 28, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
My printer won't turn on. I have tried turning everything off and back on but it still won't turn on.
There is only one way to find out if it is an issue with the printer or the Power cord or Power Adapter.
Normally every HP printer has 2 parts. One cord connects the Printer to an Adapter. the Adapter cord then connects to the Wall outlet.
Now that you have connected the printer to working outlet, Check after 10-15 mins if the Adapter ( black box ) is warm or cold. If the Adapter is warm and the green LED light on adapter is glowing, then it could an issue with the Cord or the Printer.
Try with another Adapter or power cord to diagnose.
For Other brand printers, there should be a power adapter ( black box ) and it should be warm when connected to wall outlet, if it is not warm then it is defective power adapter that you need to replaced. Else it is a problem with printer mechanism.
Regards,
Shawn
May 07, 2011 | Office Equipment & Supplies
I have a HP Deskjet D1560, and with the power cord plugged into a working outlet (I checked), the printer won't turn on. Is it just old? Is something wrong with the power cord or the printer?
There is only one way to find out if it is an issue with the printer or the Power cord.
Regards,
Shawn
May 07, 2011 | HP D1560 Deskjet Printer InkJet
I have a Lexmark Z605 Printer, got it from someone, but,..hiw do I apply power to it? see no outlet???
Behind the Lexmark Z605 printer, the power supply (rectangular black box) goes into the power supply connector/slot. Refer to the image below.
The power cord then plugs into the power supply from your power outlet in the wall.
If you don't have the power supply, please contact Lexmark technical support for assistance.
Thanks.
Dec 12, 2010 | Lexmark JetPrinter Z605 Color InkJet...
Power will not come on. OUtlet is good.
Unplug then replug power adapter from the printer. The power adapter is the black rectangular box behind the printer where the power cord is attached. Make sure the power cord is properly secured in the power adapter. Press power button if it doesn't power on automatically. Plug printer straight to power outlet in the wall. Bypass surge devices or power strips as they tend to draw away power from the printer. If no go, try to plug it to another known working power outlet. If problem continues, contact Lexmark technical support for further assistance.
Sep 15, 2010 | Lexmark X5470 All-In-One InkJet Printer
There is something missing from back of the printer. from the user manual I believe that it is some time of power source that goes in this 1 1/2 x 3 " space. there is a plug right above this hole. Help
I believe you are referring to the power supply. It is a black box that plugs in to that hole. The power supply is where the power cord is plugged in from the power outlet in the wall. If that's missing, I strongly advise you to call Lexmark. They can better assist you with that request. You can contact them at 1-800-LEXMARK (1-800-539-6275). Hope this helps. If you need more assistance, place a comment so I can get back to it. Thanks.
Apr 16, 2010 | Lexmark X2500 All-In-One Printer
Printer will not power on
Try these out:
1. Check for any physical defects on the power cord. Plug printer straight to the power outlet in the wall without using any extensions or power strips.
2. Plug the printer to a known working power outlet in the wall.
3. Unplug the printer's power supply (the black box behind the printer where the power cord is attached). With the power cord still attached to power supply and the other end still plugged in to the power outlet, it should feel warm but not hot. Then, plug it back in the printer.
4. If still no power, press the power button.
5. If after doing these and the printer is still not powering on, you might be looking at a defective power cord or defective power supply.
Apr 08, 2010 | Lexmark X2500 All-In-One Printer
HP deskjet F2100 series printer
i bought hp deskjet f2100 series printer and automatically driver was curupted from my system and now when i am trying to reinstal it again it shows error no hp printer found ...so please give me solution
Oct 10, 2007 | HP PSC 1610 All-In-One InkJet Printer
Ben Johnson
