Question about HP OfficeJet 7410 All-In-One InkJet Printer
Hp printer HP 7410 window shows HP Invent screen with flowing gray line across bottom
  • 8 more comments
  • magician2b
    magician2b Sep 23, 2008
    I too have the same problem. When the power adapter is pluged in, the LCD lights up with the "HP Invent" logo, with a scrolling gray bar across the bottom. This stays on for about 15 seconds, and then, "reboots". This cycle continues over and over. HP is not much help. Their solution, "buy a new one from them". This one cost just shy of $400. I was hoping it would last more than 2 years.
  • jscheef Oct 22, 2008
    Have the same problem, disconnected the wifi board, and printer now works. Now, how to get a new wifi board?
  • tdoying Nov 02, 2008
    Can someone direct me how to remove the back panel to get to the wi-fi card. Thanks.
  • bigblueMurph Nov 05, 2008
    I have same problem "LCD lights up with the "HP Invent" logo, with a scrolling gray bar
    "reboots". This cycle continues over and over."
    just trying to figure out which one is wifi card - I am not technical - but have back of printer off..any suggestions to tell me how to locate don't want to do wrong thing...printer has been great up till this - no way to explain why it stopped working...
    Sorry - found it with a flash light - unplugged it - and it works...Thank you very much. Anyone figured out how to get new WiFi card ? I can use hardwired - but did use the wifi quite a bit...if so - let me know...thanks to all
  • smfont Nov 22, 2008
    Oh my God!! Thank you so much! I found and disconnected my WiFi card and now my printer works!!! Too bad HP was not as helpful.
  • billfish33 Nov 26, 2008
    same problem, but simply unplugged the wifi card
    "wire plug in far upper left of the rear of the printer" and it rebooted !
    can I get an external wireless card ?,or some other way of getting this printer to run wirelessly ?
    thanks,
  • cdburgi Dec 03, 2008
    I have the same problem, but I can't figure out how to get the back off
    the printer so that I can disconnect the wifi card. Can anyone help?
  • Anonymous Dec 04, 2008
    Takeing out the WiFi wire worked GREAT. THANK YOU!!!!!!! :)
  • Anonymous Feb 04, 2009
    I followed andrewwill's instructions (thanks for the pictures btw) and unhooked my wifi card. Now my printer is up and going. I too have a wired connection so I don't utilize the wifi capabilities. Thank you very much for the advice and great instructions.
  • 3 Answers
This is what Maggix reported to solve the problem:
"I have found with this printer that the issue is a mis configured Wi-Fi card. Not sure how to fix it so you have wi-fi but if thats not an issue you can unplug the wi-fi card and it will boot and work again. To do this take the back panel off, there will be a bunch of ribbon connectors and plastic wire connectors. There will be one plastic connector set that has 5 or 6 wires and is wrapped in a black sheath. unplug this it is the wi-fi card. plug the machine back in and see if it boots right."
I tried and it works for me. The cable is located in the upper area of the small board on the back of the printer. It's a ribbon cable made of 5-6 coloured wires, all tied together with a black wrap.
Hope it helps
Posted on Oct 03, 2008
  • 4 Answers
I have made a detailed blog with pictures describing this procedure after finding it myself. Here is the link:
http://larrycrazyness.blogspot.com/2009/01/hp-fixed.html
Posted on Jan 29, 2009
  • 3 Answers
I found the replacement wifi interface at http://www.everprint.com/online/simdetail.asp?partno=Q3395A. I have NOT yet ordered this, and therefore cannot comment on the company. In the meantime, the workaround provided by andrewwill at http://larrycrazyness.blogspot.com/2009/01/hp-fixed.html worked perfectly! We do not use the wifi at our house.
Posted on Feb 03, 2009
Great - I have tried everything else under the sun. This worked like a charm. Now I have another couple of years in my printer. Thanks a lot.
I tried unhooking the wi-fe plug and that FIXED THE PROBLEM FOR ME!!!!! Very happy and many thanks to whoever suggested this solution. Saved me $400 buying a new printer.
Lloyd
Oct. 24, 2008
Posted on Oct 24, 2008
Asdfasdf
Posted on Sep 23, 2008
  • 50 Answers
Try doing power flee(Uplug the power cable, press and hold power button for 5 sec and then plug in
the power cable and restart the printer) and then connect the printer in the wall socket directtly without the surge protector if it is connected.
The screen on my 7410 says HP invent with a moving bar on bottom and wont respond to anything. I have turnrd power of and it keeps coming up with same. Any idea?
When the software is installed for the printer, one of the applications that is added to the system is the HP Director. There are times when this application does not open on systems that are running the Windows XP operating system. One way to correct this is to run the program from the HP program group from the "All Programs" option on the Start menu. The application will load into the computer's memory but does not appear on the screen. Press "ALT" + space bar to view the shortcut menu. Select "minimize" to display the program on the taskbar. Another option is to update the program by visiting the HP Software Download Page (see Resources).
Dec 21, 2010 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 has power, screen is lit, but power button is not. None of the functions (print, copy, scan, etc. will work. Any ideas?
Seems like something a lot of us are experiencing. I have the exact same problem. Has anyone found a solution?
Dec 07, 2009 | HP OfficeJet 7410 All-In-One InkJet...
When turned on, it wont go past the HP Invent splash screen
your windows is corupped try that to repair your windows with your system disk
Oct 06, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP Officejet 7410 All-in-One Blue screen error message 00000020
I did everything you said, even the angry part lol and still nothing. Sigh...well, I've been wanting an air printer anyway :D
Oct 05, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP 7410 stuck on HP Invent Screen
if you have external jet card remove it and restart
Aug 24, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP Officejet 7410 Display HP logo and Invent
Hello.
I'm afraid this one is a critical issue. If your product is in warranty or out of warranty , it would be better to upgrade to a newer model as this is a serious flaw in the printer.
all the best.
Sep 11, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 7410 All-In-One InkJet Printer Logo
554 people viewed this question
Ben Johnson
