Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
Dish washer repair
Kitchen aid - will not turn on but has power, there is a lot of water inside.
    Sergeant:
  • 409 Answers
you'll have to manually take the water out.
do you have any error messages on the display?
if yes, please advise the exact error message.
if not, please check the drain pump for any thing stuck in it.
Posted on Sep 23, 2008
How much salt goes in dish washer
You don't put salt in a dishwasher unless you want to ruin it.
2. You ONLY use a detergent specifically for dishwasher use as the cleaning agent and you 3/4 fill the soap dispenser in the washer (normally fitted into the door on the inside) with the dishwasher powder.
3. If there is a separate small compartment in your dish washer for a "rinse aid" solution to be used, you can use a rinse aid product designed for dishwasher use only. If there is no rinse aid compartment (this is also normally fitted to the inside of the door - if fitted on your machine) then you cannot use a rinse aid in your washer.
4. Don't use any other product in the dish washer.
Jan 30, 2016 | Dishwashers
Ran dish washer without water turned on.
The first thing these units do is check the pump. Put a gallon of water in it by hand then try to turn it on. See if it makes any effort to drain.
Nov 27, 2017 | KitchenAid Dishwashers
Dishes won't come clean
Check your water inlet for the right pressure and then the water float valve for the right amount of water in the tub for washing. The tub has to have the right amount of water in it to pump it up to the top. It is also possible that the pump has debris in it that is restricting the flow. Clean out the screens and check the bottom of the washer tub for debris at the pump inlet. Use white vinegar to clean out your washer. Start your washer - open the door and pour in a lot of vinegar. Let it run for a few seconds and stop it. Let the vinegar work on the scale and debris. Start and stop it several times during the day - not completing the wash cycle until in the morning - after it has sat with the vinegar 10 -12 hours.
Mar 03, 2014 | KitchenAid 24 in. KUDP02CR Built-in...
My Kitchen Aid Dishwasher model # KUDS40FVSS0 has blinking cancel, sani-rinse and normal wash lights. It will not run at all. We replace the control board and still nothing. Please Help!!!
I have had this problem. Mine didn't work for over a week and by the time the repair man came over to 'replace the board' it suddenly worked. The guy told me that if you use ANY type of liquid dishwashing soap (for your sink) and any residue/bubble is on the dishes, it can cause your dishwasher to break. I have no idea why but I've been really careful to make sure I wasn't using dish soap prior to putting them in the washer.
I've had 3 service calls on this dishwasher since I purchased it 3 years ago. I'm having similar service issues with my Kitchen Aid Fridge. And of course no help from Kitchen Aid.
Sep 25, 2013 | KitchenAid Dishwashers
We have hard water at our home, but the new dishwasher leaves a thick film on the glasses. We use the rinse agent, but it's awful.
You have to buy a cartridge type water softener and attach it to the
inlet water line of your dish washer. In addition to this there must be
a salt compartment in the dish washer.
Refer the user guide /owners manual and locate. Fill it with the special
dish washer salt. ( Do not use kitchen salt used for food).
The dish washer salt may help to certain extent in softening the wash
tub water inside. Check the switch settings for rinse aid and salt
release settings in the machine. Refer manual!
Oct 01, 2010 | Frigidaire FGHD2471K Builtin Dishwasher
My Dishwasher leaves a white film on dishes.
check inlet water quality. If more calcium deposits in the water this could happen. Try using water water softeners.
If provision for dish washer salt check and add salt. ( not kitchen salt )
Finally check whether rinse aid compartment is filled with the liquid. If you are tablet, extra rinse aid not needed. Try all the above.
Aug 17, 2010 | Whirlpool Dishwashers
I have a kitchen aid dishwasher that is not dispursing the water enough to clean. I have cleaned the entire unit with commercial cleaners and have added vinegar to the washer without dishes. And still it...
You need to remove the wash arms by turning the nut in the centre of the arm and remove,then unblock the holes that are in the arms and replace them,test if the arms now turn and you can see a differance then also check there is salt in the salt dispensor located at the bottom of the machine.
Dec 30, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Water remains in bottom of dish washer.kitchen aid whisper quiet+
There is supposed to be some water at the bottom to keep the seals moist.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Washing Machines
Rinse aid used very fast and dishes not drying
Look for a blue or green streak on the door panel when you upen it to load the dishes. Does the washer sound different during the wash than it used to? If so your dispenser is leaking. This will also cause the water to suds up and not wash as well as it should. Start the washer with no detergent or dishes and let it run for 5 minutes, then open the door and see if there are a lot of suds in the water. Post back to let me know what you find.
Oct 20, 2007 | Whirlpool 24 in. ADP5966 Free-standing...
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
122 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
