Question about HP Officejet 4110 All-In-One InkJet Printer
Printer will no longer printing
Printer is always indicating out of paper when loaded with paper.
  • 2 more comments
  • Dan Masters Oct 04, 2008
    Our HP officejet 4110 was working fine when all of a sudden it said that it was out of paper when in fact it still had some. Then worked breifly again, and about an hour latter did the same thing again. It seems as if the paper will not get taken into the machine, despite it apparently trying.
  • Anonymous Oct 09, 2008
    nothing visable is rolling when the "rolling" sound takes place, then says out of paper
  • saheilmann Nov 26, 2008
    Says out of paper when it HAS paper.
  • ajcb Dec 02, 2008
    Soon after fitting two new HP cartridges the 4110 all-in-one printer stopped working.
    The 'Out of Paper' message appears occurs whether printing or copying. I have also tried to copy when disconnected from the PC, it scans the page then tries to feed paper and then reports 'out of paper: load paper..'
    This suggests an internal hardware problem rather than the driver being the cause. No obvious bits of paper etc. Does anyone know where the paper sensors are?
    Sergeant:
  • 352 Answers
Hi locklia, try updating your printer drivers:
Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop. Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done
anaanymous
Posted on Oct 14, 2008
I am trying to print but its telling me to laod paper in the bottom tray. I have always loaded from the top. I cant even get the paper to fit in the tray. Help Please
check the setting on your printer properties on the computer. Check paper source setting.
The bottom paper tray can be extended to allow longer paper (page 8 in user guide ) also there is a button on the printer to select either the cassette or from the top loader. This is explained in the user manual on page 11
http://gdlp01.c-wss.com/gds/1/0900005381/01/ip3000quickstartguide_us.pdf
Apr 13, 2015 | Canon PIXMA iP4000R InkJet Printer
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
How to clean phaser 7750
Included general maintenance video and how to clear smears from the paper.
Solution: Remove Print Smears / Printing Fuser Cleaning Pages
7750 Support Knowledge Base Remove Print Smears Fuser Cleaning...
With Troublshooting highlighted on the printer display perform the following steps:
  1. Press OK.
  2. Press the Down Arrow and scroll to Print Quality Problems.
  3. Press OK.
  4. Press the Down Arrow and scroll to Remove Print Smears.
  5. Press OK. The printer will print 5 cleaning pages.
Repeat this process five or six times, to remove stubborn toner buildup from the fuser.
Always make sure you are matching the type of paper loaded in the printer tray(s) to the correct Paper Type front panel setting. When you load a tray with paper, the front panel will ask you to indicate the type of paper you loaded. For correct print quality and printer operation, be sure to set this correctly.
MAINTENANCE:
Phaser 7750 Video Instruction Maintenance for the Printer Phaser
Apr 23, 2014 | Xerox Phaser 8550/SDP Color Laser Printer
Mfc 7860dw will not print from paper tray
Check the paper level in tray 1 and keep the paper within the levels indicated by the arrows on the side. I had this same problem, and although the paper tray accommodates the extra paper, the printer obviously does not like it and defaults to the manual feed.
Mar 08, 2012 | Office Equipment & Supplies
The printing goes off the page
pls set the paper size to the actual paper size you load.. you have probably selected legal size in your pc and load an A4 size paper onto the printer...
May 26, 2010 | Epson LQ 300+ Matrix Printer
Printer will not kick out document automatically, attention lite keeps flashing. tray 2 selected but always defaults back to tray 1
Sounds like you have a mismatch in the paper you are trying to print on and the paper that is loaded in the printer. HP printers look to feed paper from tray 1 anytime the computer settings don't match the paper loaded in tray 2. Tray 1 is the multi purpose tray and prety much any size paper can be loaded in tray 1. Double check your document settings and double check the paper size loaded in the paper tray 2 and make sure they match. Also try printing a different document to see if the error persists. If it does this on everything you try to print you should also double check teh rear guide in the paper tray. There is a rear guide in paper tray 2. If it slides back too far it will make the printer think that paper longer than 8 1/2 x 11 is loaded. Push the paper all the way forward in the tray and push the rear guide until it is snug with the tail end of the paper stack.
Nov 01, 2009 | HP LaserJet 4700 Printer
Dell 926 All-In-One InkJet Printer
printer wont print anything. computer says no print documents pending even though ive clicked print a few times and on different programs and internet pages as well. printer will print only if i copy something press print test page from the printer itself but it doesnt print anything from the computer
Oct 15, 2008 | Dell 926 All-In-One InkJet Printer
Printing Labels
The MPF is simply the "Manual Paper Feed".
Your printer is set by default that the MPF paper type is "plain paper". Since you are telling the printer that you are trying to print lables, the printer is simply telling you that you need to load the MPF with lables.
If you say "ok", the printer sould continue and print the lables.
If you only print lables, the you can change the default paper for the MPF tray to "lables", and then you will no longer be prompted to load the tray.
Sep 25, 2008 | Dell 5100cn Laser Printer
Printer will not allow paper to flow freely; it jams on the left side and prints crooked.
first cancel all the prints going on and switch off and on the printer and keep the paper slowly
Aug 07, 2008 | Canon PIXMA MX310 All-In-One Printer
TROUBLE PRINTING
These are following cases for this symptom.
If the access indicator flashes in green:
The data size of the image is large and it takes longer to process it for printing. Printing will start as soon as the data processing finishes.
If the paper error indicator flashes on the LCD:
The paper is jammed. Turn off the printer and turn it on again, take out the paper tray, and then remove the jammed paper from the paper outlet. If you cannot remove the jammed paper, consult with your Sony dealer or service facility.
If no indicator is lit or flashing:
The thermal head may be overheated. Leave the printer until the head cools down and the printer resumes printing.
May 11, 2008 | Sony DPP-FP50 Thermal Photo Printer
HP Officejet 4110 All-In-One InkJet Printer Logo
55 people viewed this question
Seeker5211
Seeker5211
