Question about D-Link AirPlus DI-524 Wireless Router
QUERY CAN I USE MY WIRELESS ROUTER WHICH IS DI 524 FOR HIGH SPEED INTERNET? I NEED TO KNOW BEFORE I GO AND BUY ANOTHER ONE...
  • michelle1968 Sep 23, 2008
    hi.... ok my router doesnt have airplus written on it anywhere
    it was brought from **** smith electronics in australia where i live... it only has di - 524 and i already have it set up with my adsl router and have been using it but we want to upgrade our internet to the faster speed but i wasnt sure if my wireless di-524 is compatable.... thankyou
    thankyou mark.... very helpful
  • D-Link Master
  • 6,487 Answers
Yes, you can there;s no problem with it. if you already have that just connect it to your brooaadband connection of your DSL or Cable modem or any high speed internet and run the setup CD and that should cnfigure everything for you...
Hope that helps..............
Posted on Sep 23, 2008
  • Mark Gil
    Mark Gil Sep 23, 2008
    this router has a wireless ca[ability and you can use it to any Internet connection on your area no matter how fast those are, this router will still work it, this is the link for the complete specs pf this router http://www.dealtime.com/xPF-D-link-Airpl...
  • Mark Gil
    No problem...
    Don't forget to rate the solution FIXYA thank you....
Problem with WIndows 7 and DI-524 router
You need to consider the router as being the destination and your PC's the source. This means your computer connects to the internet via your router. The router contiually broadcasts its SSID (network name) and when it receives a query from a device checks to see if the device is set to the same SSID. The network created by the router should be detected by your PC's. which displays the detaiuls on your screen. All you need to do is to selct your network from those displayed and click"connect". You will be asked to supply your WEP (network key) and you're connected. The same goes for any other device you may wish to connect, including iPhones and game consoles.
Apr 19, 2010 | D-Link AirPlus DI-524 Wireless Router
Dlink router is not connecting to the internet
Check the lights on the router to make sure both out going and incoming are on.
Manual link below in case that helps
ftp://ftp.dlink.co.uk/di_broadband_gateways/di-524/di-524_manual.pdf
If not both on contact broadband supplier as IP for router may have been "altered" and will need resetting their end.
Not unknown for an outage to be proceeded by a "spike" which can blow unprotected items.
Jan 24, 2010 | D-Link DI-524 High Speed 2.4GHz (802.11g)...
Passharse
PRESS 5 MINUTES THE RESET BUTTON OF THE ROUTER
Jul 04, 2009 | D-Link DI-524 High Speed 2.4GHz (802.11g)...
Can't get my di-524 router to work
no a straight cable...you are going to need to clone your MAC address on your router so that your ISP can see it.. email me at techray1@live.com
Jun 02, 2009 | D-Link AirPlus DI-524 Wireless Router
Need passphrase from D-Link router DI-524
1. if the default login never been modified b4, u can hook a network cable to the router, type "192.168.0.1" to enter the router config. Once inside, u can edit the password or disable it.
*U may prompt for username (admin) and passsword(empty).
2. If the default login has been modified and u r not able to enter the router config, u can just reset the router by inserting a pin to the small hole to get back the factory default settings. Then u can perform above step again to reconfigure your wireless router.
Mar 13, 2009 | D-Link DI-524 High Speed 2.4GHz (802.11g)...
I got a new computer and now my wireless router does not work
If your new computer is a Vista box, my experience is that the DI-524 does not work with Vista. The DI-624 works well. Yes, I was annoyed to have to buy a new router too!
Jan 07, 2009 | D-Link AirPlus DI-524 Wireless Router
Dlink di-524 connect to RV042
Hi.
You need to cascade the Dlink wireless router to your RV042.
Suppose your RV042 has a default IP Address of 192.168.1.1, and the DLINK IP uses 192.168.0.1. Your Physical connection is from the regular port of the RV042 going to the WAN/Internet Port of the DLink wireless router.
Once you do that, your Dlink router should automatically obtain an IP from the main router. If it did, configure your wireless settings and you should be able to connect via wireless.
This is just one way to cascade your router to another router.
For more information, click here.
Jul 21, 2008 | D-Link AirPlus DI-524 Wireless Router
Connect to wireless
here you get the manual sir:
ftp://ftp.dlink.se/Products/di-products/di-524/Documentation/DI-524_manual.pdf -
or
www.amazon.com/D-Link-DI-524-Wireless-Router-802-11g/dp/B0001PFQ08 - 256k -
or
reviews.cnet.com/routers/d-link-di-524/4505-3319_7-30839580.html - 79k -
thanking you
Jul 09, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
