Question about Dell Inspiron E1505 Notebook
Dell inspiron e1505 wont boot
I push the power button, get some lights then it goes back off. no screen activity. battey only and ac adapter plugged in, same results
  • chuebler Mar 30, 2009
    I push the power button on me inspiron e1505 and the on light turns on (green) and nothing happens on the screen, about 5-10 seconds later it turns off and nothing happens.
  • pcniedfeldt May 02, 2009
    I have this same problem... I just replaced the RAM, and when I put everything back together, I pressed the power button and get green lights, but that is it.
    Specifically, the lights above the F4-F6 keys, the left most most light stays on, and the middle and rightmost light flash on and off for 10-15 seconds until the system turns off.
  • 41 Answers
Sounds like you are having issues with the motherboard since we are talking about a laptop here. However, there is a way on how we can isolate that the motherboard is the main problem. Remove the memory by clicking this ---> http://support.dell.com/support/edocs/systems/ins6400/en/om/parts.htm#wp1103163
If in case the system would still act the same, call up Dell with the service tag or express service code to have the motherboard replaced.
Posted on Sep 23, 2008
Dell Inspiron E1505 fails to boot up. "A" caps light, and the light next to it (downward arrow in lock) both flash, but then the flash ends and the computer doesn't power up. Is this...
Please try to reseat you memory RAM and try to turn ON again.
If you want to retrieve Information on your HDD, you can take out your HDD from your laptop and use USB External HDD case. Please refer to link below :
http://shop.ebay.com/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=HDD+case&_sacat=See-All-Categories
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Thanks
Jul 20, 2011 | Dell Inspiron E1505 Notebook
Dell inspiron m5030 wont boot up, ac adapter has green light then once it is pluged in light goes out.
Try a hard reset. Sometimes it works and is always the first step to take.
Remove the battery and the ac adapter plug from the laptop.
Press and hold the power button for forty seconds.
Install the battery and ac adapter .Now press the power button to attempt a boot into the OS.
If that doesn't work then remove the hard disk to see if it gets past the splash screen and the BIOS whines that it can't find a boo-table OS. That would indicate a hard disk failure.
Also try to remove the memory module(s) from the DIMM slots and then reinstalling them. That reset the modules and cleans some oxidation off the module pins (if there is any)
Hope this helps.
Let me know if you need more information
Thanks
Apr 26, 2011 | Dell Inspiron M5030 Laptop
My laptop screen dark but working
Hi zangoka,
The easiest way to fix this problem is to perform a power drain. Please follow the instructions below.
1. Turn off the system completely.
2. Unplug the AC adapter from the power outlet.
3. Remove the battery from the unit.
4. Now, press and hold down the power button for about 15-20 seconds.
5. Put back the battery in and plug the AC adapter.
6. Reboot and observe the system.
Hope it helps.
Thank you for using FixYa.
Feb 08, 2011 | Dell Inspiron E1505 Notebook
Dell 1505 fan runs screan blank has two flashing lights
Hi frase809,
Hope it helps.
Feb 05, 2011 | Dell Inspiron E1505 Notebook
When i plug my ac adapter the screen flickers a couples of time then i goes black
Hi grice2000,
Hope it helps.
Jan 09, 2011 | Dell Inspiron E1505 Notebook
Dell 1505 laptop..amber light flashes constantly, battery shows 100% but when I unplug AC...no power
Hi there!
The problem you're having there is a motherboard issue,
The computers power button is amber and it flashes that means the power inside the computer is not being distributed properly. You said that the battery is 100% charged but when you unplug the AC the computer will have no power, that means the motherboard is failing, its not identifying the battery as a source of power anymore,
You can try to use another ac adapter and check if the computer will boot up, or try to unplug and plug the memory and hard drive see if any changes will happen,
If the computer turns on with another ac adapter and boots up to windows properly then try to update the bios.
If the ac did not also the memory and hard drive,.
You'll really need to get a new motherboard.
Hope this helps!
Apr 03, 2010 | Dell Inspiron E1505 Notebook
I just bought a replacement 9 cell battery and a 90 watt power adapter for my Dell E1505. With the new battery and power adapter my battery indicator light keeps flashing green and the battery doesn't...
If a new DELL ac adapter (3rd party Adapters are not recognized and the charging circuit is disabled) and a new battery doesn't resolve then the charging circuit on the motherboard is bad
Dec 29, 2009 | Dell Inspiron E1505 Notebook
Where can i get a schematic for a dell inspiron e1505 laptop motherboard? It was working fine on battery then I plugged in an ac power adapter and now only the 3 lights come on for about 2 seconds then...
ARrrghhh finding clear and detailed schematics on parts today can be a real pain in the south-forty -- luckily, i know a site where you can find what you are looking for quickly.
http://www.user-guides.co.uk/cddownload/Dell/DellInspiron/Dell-Inspiron-E1505-Service-Manual-Remove-Upgrade-841.html
just follow this link and you will find a resource for COMPLETE and DETAILED schematics and more.
Hope i was able to FIX YA!!! Please reply with your feedback if this helped or if you need more anwers.
Aug 12, 2009 | Dell Computers & Internet
Dell Inspiron E1505 Notebook Logo
506 people viewed this question
Alun Cox
