Question about Dishwashers
Bosch dishwasher malfunctioning
Dishwasher turns on and the counter cycles but it never
puts out any water. I checked the inlet and it has a good supply.
    Sergeant:
  • 409 Answers
check the drain pump, located inside under the lower spray arm for anything stuck in it.
do you get any error messages on the display?
Posted on Sep 23, 2008
Bosch dishwasher doesn't work. water not coming
Hi Gilgol, The link below is a Bosh Dishwasher list of error codes, I believe your error code is E3....CHEERS..
http://removeandreplace.com/2015/10/09/bosch-dishwasher-error-codes-how-to-clear-what-to-check/
Bosch Dishwasher Error Code E3
Fault Condition: Not filling with water
Repair or Check: If the water supply cut-off valve on the dishwasher is completely open but the dishwasher will not fill with water then shut off the water supply and unplug the dishwasher. Remove the water fill line and check to see if the water inlet screen valve is plugged up. If so then replace the water valve. Cleaning the screen can make the issue worse so always replace if the screen is clogged. The valve can get stuck open from gunk and therefore flood or overfill.
Parts Required: Water inlet valve
Bosch Water Inlet Valve Assembly for Dishwasher
Apr 02, 2016 | Bosch Dishwashers
How to run self test on bosche dishwasher
Here is an excerpt from "Bosch Dishwasher Troublesoooting".
Running a Test Cycle
Bosch dishwashers have a test cycle which can be run as a troubleshooting measure. The method to run this test cycle is similar across the Bosch dishwasher range so if your dishwasher features seems different from those described below then try experimenting, as the process is fairly straight forward and will be very similar. Bosch dishwasher model numbers are usually found around the top or lip of the door. One of the most common differences between dishwasher models is simply the names of the buttons. For example in the first example below, POWER SCRUB PLUS and REGULAR WASH may be called WASH and ECO depending on your dishwasher model and the country you are in. The other key difference is whether your dishwasher has a display panel (which can display error codes) or not (in which case a program light will illuminate to tell you the fault.
To run the test cycle hold down the POWER SCRUB PLUS and REGULAR WASH buttons. Whilst held down press the ON/OFF button. The lights above them should flash. Now you can check the status of each dishwasher program by pressing its button. Now you can run the full test cycle = Press the POWER SCRUB PLUS and REGULAR WASH buttons again. The dishwasher will start up and when the cycle has ended one, if you have no display panel on your dishwasher model the indicator lights will illuminate if a malfunction was detected as follows -
CLEAN - A temperature sensor fault. If this is the case then the test cycle will be very short as the dishwasher will terminate the test once it's been detected.
RINSE/DRY - A water sensor/filling fault. If this is the problem then the test cycle will not complete as the dishwasher cannot detect the right level of water, the dishwasher will just keep filling and draining again.
WASH - A heating fault. Check your heating element.
If you do have a display panel on your Bosch dishwasher then after the cycle is complete an error code will be shown if a fault has been detected. The error codes are as follows -
0 - No errors have been detected.
1 - A water sensor/filling fault.
2 - A heating fault.
4 - A water filling fault. This can also appear as F on the display during a normal cycle.
8 - A temperature sensor fault.
When troubleshooting your Bosch dishwasher, running the above test cycle is a good start in diagnosing the problem and should give you an idea of where the problem lies with your Bosch dishwasher and what fixes and repair are in order. Our general troubleshooting page will give you some ideas on other things to check on your dishwasher. Good luck!
Mar 29, 2013 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwasher will not fill with water
depending on the make and model of dishwasher the solution can vary. A good guess (assuming the inlet hose is connected and tap is turned on), is the water pressure setting may not be matching with your normal mains pressure. Check installation instructions for setting mains water pressure. Also some dishwashers like Bosch have special inlet hoses which detect water leakage and shut of the water inlet valve. Need to check if your dishwasher has got this feature and need to confirm the hose is correctly fitted.
More importantly check when you turn wash cycle on if you hear click of the inlet valve or not.
Dec 29, 2012 | Dishwashers
F8 flashing unit will not cycle gets water then starts beeping
F8 - this code is indicated that there is your dishwasher is having problems detecting the correct water level. Often this results from an insufficient amount of water entering the dishwasher during a cycle - so the water supply is probably ok but check it as F6 (F6 means that the dishwasher is unable to fill with water. Ensure that the dishwashers water supply is turned on (double check the tap valve to make sure its open). As above, also make sure that the inlet water hose is not obstructed, kinked or twisted), just in case.
Occasionally the water level sensor might misread if there a too many bubbles in the dishwasher (i.e. if you put washing-up liquid in the machine, etc).
Otherwise your machine may be having an issue with water pressure, possibly caused by a faulty water pump.
Hope this helps.
Jun 03, 2011 | Bosch Dishwashers
Our Bosch dishwasher has water filling back in bottom of dishwasher after cycle is complete. You can empty dishwasher and no water will be in the bottom, but several hours later the water has filled the...
Check the drain line underneath the sink.
It should be suspended just below the counter top.
If it is too low,water from the sink will back fill into the dishwasher.
If the drain is OK,then the dishwasher water valve is defective.
Mar 26, 2011 | Bosch SHU3306UC Built-in Dishwasher
Bosch dishwasher water won't enter for wash cycle and YES water is on
Will it do anything else?
How about if you fill it up manually? As in fill up a pitcher, pour contents into the bottom of the dishwasher until it raises the float. Close the door and see if it runs. (don't put so much in there that it pours out the open door)
If it runs and you are sure the water is on. Turn the water off. Take the inlet line off the dishwasher's electric control valve and see if the inlet screen is covered with trash. If it is, clean it off, put it back togehter and see if it works.
Sep 10, 2009 | Bosch Dishwashers
Water refilling after dishwasher is cycled off
Leave the D/W door open and make sure the water is not coming from the water inlet .
It may be oozing up from the bottom when you run water in the kitchen sink.
Does your dishwasher vent through a counter top Y siphon. It could be clogged causing water to re-enter the D/W.
Feb 10, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch builtin 60cm SGV4313 dishwasher
many thanks however intend purchasing new machine
Sep 14, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
No water on wash cycle
YES YOU ARE RIGHT TIMER COULD BE FAULTY OR WATER INLET SOLENOID COULD ALSO BE BAD
Feb 02, 2008 | Dishwashers
Water Sitting In Dishwasher after Completion of Cycle
An obstruction in the water-inlet valve may mean that it's no longer able to shut off properly. You can easily open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!! In case cleaning will not help, you should replace the valve. Good luck !
Sep 09, 2007 | Bosch SHU5315UC Dishwasher
Dishwashers Logo
49 people viewed this question
Top Dishwashers Experts
