Question about Olevia LT37HVS 37 in. LCD HDTV
Flickerin Screen I have had the for 18 months. Yesterday, I turned on my tv and found that it is flickering like a strobe light and wont stop. I called Olevia and there werre about as helpful as a bag of S#@T. $200 to send and return the TV and $100 per hour to look at it. Any Ideas of the problem or a tech in the Fort Lauderdale area??? My 237v would flicker all the time, I replaced both inverter boards and now when it turns on it doesn't start to flicker for a few seconds. It flickers on and off til it will only stay flickering after about a minute. I have resoldered many joints on the power supply with no change in operation. Power supply output to the inverters when the TV is not flickering it is about 19.7vdc, once the TV starts to flicker the voltage jumps to 22vdc. I don't know if the problem is the power supply is there a way to verify exactly where the problem lies. Any information people can give would be appreciated. Thanks
  • aaronpfeifer Oct 02, 2008
    Has anybody had this same problem? Is it possible there are bad solder joints connecting the light tubes themselves? I haven't had it that far apart yet to investigate that possiblity. Is there a way to rule out the power supply possibly being bad without me going out to buy a new power supply? Any information would be helpful.
    Aaron
    Brigadier General:
  • 6,966 Answers
To my understanding, almost all power supply (SMPS) for use of such devices would be self-regulated. There is no way for the voltage to go up, perhaps down (a little) but never up. Based on this, it would be safe to assume that it is indeed the power supply. If the supply voltage becomes unregulated (and shoots up), the normal tendency of the electronics it supplies to would be to clamp down and auto protect/shutdown. Some are more sensitive than others and in all probability, the inverters are just doing that.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 02, 2008
  • Louie  Role
    Louie Role Oct 02, 2008
    Have you tried getting hold of a service manual or at least a schematic diagram with voltage readings? You could start looking at Syntax Olevia
  • 790 Answers
Hi
you have problem in power section! try to find out the leak filter capacitors! and also check the bias control of regulator maybe this is loosed carbon gap.
Thanks!
Posted on Sep 23, 2008
  • carlos fernandez Jr.
    carlos fernandez Jr. Oct 02, 2008
    Hi
    The SMPS or Switch mode power supply, if the regulator control adjust is bad you can get High voltages... and not low voltage.. if you got low voltage you have another problem in Hot section!
    But the main complaint is u got abnormal voltages! 19.7v sometimes jump to 22v. all you have to do is check the Bias Control in power oscillation section.
    Thanks!
    Genius:
  • 1,268 Answers
The problem is within the power supply. It sounds like a diode problem on the power supply board. Try double check any other burned components like bulged capacitor and burnt resistors. Replacing them could fix it.
2 Suggested Answers
JRE_NJ
SOURCE: Flickerin Screen
Just solved this problem for a customer.
Problem found to be a cold solder joint output transistors to inverters.
Remove then resolder cold solder joints. then your good to go. JR,
Posted on Sep 19, 2008
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
My coby flatscreen comes on and works but strobes flashing light but works good just with strobing light ! whats going on?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Feb 22, 2015 | Coby TFTV4025 40" LCD TV 1920x1080, 60 Hz,...
Lg plasma tv screen flickerin
HelloThe problem shows the refresh rate. Quite propably that you are seeing the much slower beat or heterodyne. Often caused by artificial ambient lighting like florescent tubes or faulty dimmers on halogen's etc causing the beat with plasma screens.
Otherwise you need to check power supply
Nov 15, 2011 | LG Televison & Video
RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Mar 26, 2010 | RCA L37WD12 37 in. LCD HDTV
FLICKERING BACK LIGHT
Sounds like you have an LCD tv with backlight problems. Check power board for domed capacitors and replace them. next check connections on the inverter boards. they are on the sides or just one side. Becareful there is high voltage output from these boards. If the cable from inverter board is not good to the screen you can get a strobing. the inverter boards may need replaced. or cales to screen may be bad. The panel also could be bad.
Mar 25, 2010 | Televison & Video
Please describe how to rectify flickering screen nokia 5800 problem:
flickerin screen ? wen u r gettin a flickerin scren.. in tv out mode or alwz......
Mar 16, 2010 | Nokia LCD Screen Protector Film for 5800...
Olevia 237V Backlight problems
Voltages do not dance around and should be constant and within stated parameters.. The board producing those crazy readings is the issue.
Mar 12, 2017 | Olevia LT37HVS 37 in. LCD HDTV
Flickering screen (likea strobe light)
one check your refresh rate in windows boot the pc into safe mode if flickering is gone then lower your refresh rate if not replace lcd inverter board.
May 16, 2009 | Gateway XHD3000 LCD TV
Tv not turning on
I also have this model. A few months ago, when I turned on the tv, it told me my lamp was in need of replacement. just yesterday, my tv did the same as you....the blue light flashed and then the lamp light kept flickering. All I can say is your lamp needs to be replaced.
Mar 19, 2009 | JVC HD-56G657 Television
Flickerin Screen
Apr 04, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Olevia LT37HVS 37 in. LCD HDTV Logo
355 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Dave Naylor
Dave Naylor
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
