Question about Kogi L7CH Monitor
No sound coming out of monitor
I am not able to get any sound out of the computer. There is no cable going into the 'audio in' plug on the back of the computer. This was a gift and I thought I had all the plugs to it but it seems as though I am missing a plug for the audio input. Please advise.
  • 45 Answers
Dear user, you need a 3,5 mm jack cable wich has the same connector on each side.
Plug it into the monitor and the GREEN output ( stanadard output color since pc'97) and it will sound, maybe you have to set the volume in the menu of the monitor.
Best wishes.
Posted on Mar 20, 2009
HOW DO I GET SOUND OUT OF MY DELL SE198WPFV MONITOR?
sad to tell you but they are not made to have sound OUT .
Apr 30, 2015 | Dell Computers & Internet
How get sound on viewsonic VA2446m?
Plug the audio cable from the PC to the audio input jack on the back of the unit. Then make sure audio volume is turned up on the PC side. The monitor also has a volume control setting. Make sure to have a value greater than 1 to hear anything.
May 15, 2014 | ViewSonic VA1912WB 19" WideScreen Monitor
Audio on my computor monitr does not work and would like to here music plus other things, thank you!
You probably have a usb cable or an audio cable to plug to your computer. Did you see that cable coming of your monitor? If it is already plug, you need to install your monitor driver in your computer in order to make the sound card working.
Mar 01, 2011 | ViewSonic VX2235wm LCD Monitor
How do I activate the sound for my monitor (CM2019). Our old speakers broke and I want to use the speakers in the monitor.
On the back of the monitor, look for a small jack with green color with the 'AUDIO INPUT', 'AUDIO LINE INPUT', then you will need an audio cable with mini stereo phone plug at each end (get it from Radio Shack). One end of the plug will go into the monitor AUDIO input (green), and another end will go into the PC AUDIO line out (Green jack) just like where your old PC speaker cable was plugged into. You need to set the volume level on your monitor to about mid point first and redjaut it later on.
Picture of the audio cable with pugs.
Aug 22, 2010 | Balance CM2019 19" LCD Monitor
Volume
Did it stop working or has it ever worked before?
Make sure there is a cable running from your computer to the monitor's integrated speakers. It should go from a green 3.5mm output jack at the back of the computer to one the same size in the back of the monitor. If the cable is there and still no sound, double check the connection, make sure they are plugged in securely at both ends. Be sure that headphones are not plugged into the computer at the same time or audio will only come out through the headphones.
Make sure the audio is not muted. There is a mute in possibly 3 places. One spot is the application audio: if you're trying to play from Windows Media Player, make sure the audio is not muted near the slider and that the volume is loud enough to hear.
Second place is the system volume. In the Control Panel, Audio (Start menu, Settings, Control Panel, Audio component) you can check the volume and mute of the system volume.
Third location is the monitor speakers. There may be a way in the monitor's menu to adjust the volume for the speakers. Make sure it is high enough to be audible.
If all of those are unmuted and high, you might try replacing the audio cable. Also reboot the computer with the audio cable plugged in where it should be. (Sometimes high-def digital audio can be quirky). Next try plugging in a pair of headphones into the front of the computer and see if you're getting any sound through there.
Those steps should help you diagnose the problem. If not, just post back with what you found out through these steps.
Nov 25, 2008 | HP Compaq WF1907 Monitor
My computer volume is not working
No sound from monitor speakers. Worked fine for 5 years. Can hear sounds when using headphones plugged into CPU. Hope you can help even if only to tell me I need a new monitor. Sincerely Dizzyme.
Hi...there,
First of all, check if your audio cable are still plugged into the monitor and pc output (light green) audio jack. If not just plugged it back in... Still still got no sound... Then turned off the monitor and pc. Unplugged all the cables from the monitor and pc, wait for 10 second till all the surged built up are cleared out. Then you can plugged all the cables back Monitor should have 3 cables, a audio cable, a VGA or DVI cables, and a power cord... OK! now you got all the cables plugged back in...
Turned on the monitor and PC....and a few seconds....you should hear window started. Still... had a problems....just get a external speakers. Have nice day!
Oct 08, 2008 | Hansol H550 15" LCD Monitor
Monitor audio hook-up
You should need a mini jack audio cable. One end plugs into the speaker port of your sound card in the back of the computer (usually marked green). The other end should plug into the audio input of the monitor.
Oct 06, 2008 | Proview PL713S 17" Flat Panel LCD Monitor
Sound
Is your monitor SUPPOSED to have sound? Apart from the power cable and the monitor cable, if it is a monitor with speakers, there should also be an audio cable. So 3 total. If it has a mic too, 4 cables. The audio cable is normally green and the mic cable pink.
Most monitors don't have sound though, and the ones that do, sound crappy. So unless you just plan to hear Windows dings, get some cheap speakers.
Sep 20, 2008 | Acer AL1916W 19" LCD Monitor
Relisys Sound
CJ,
1. Check make sure the audio cable are plugged in from the monitor to the PC output audio jack (light green).
2. Open your on screen display and go to Volume settings. See if it set on mute or set to 0.
3. Turn of your monitor & PC and unplugged all the cables from your monitor and PC wait for 10 seconds and then replugged it all the cables and audio cable back. Then turned on you PC...
4. If it still doesn't work.. open the back cover see if the speaker cable are plugged in.
5. If that doesn't work...then your monitor AD board built-in speakers are defective.
6. Why not just used a external speakers, it give better sound quality.
Have a nice weekend!
Aug 17, 2008 | Relisys RLT1720 17" LCD Monitor
Kogi L7CH Monitor Logo
133 people viewed this question
Top Kogi Computers & Internet Experts
Laxman Bisht
Laxman Bisht
Computer Links
jay kaye
jay kaye
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
